Question about Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE POLE CIRCUIT BREAKER 200 amp, 120/240 vac
Would like to know who carries a 200 amp main 4 prong breaker
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Habit-Forming:
  • 112 Answers
Probly no one. start call electric house and asking you may find a used one or a left over if it can't be ordered
Posted on Sep 15, 2016
2 Suggested Answers
  • 5245 Answers
SOURCE: using 4 individual breakers tied together with bar accross switches, what size individual breakers will I need to use to use for a 200 amp breaker
50 amps for each breaker?
What are you doing?
http://waterheatertimer.org/Color-codewire.html
Something sounds wrong with your question, and I see a code violation in the making.
Add a comment March 2013 and give more detail about what you are connecting to 4 breakers.
I am concerned about fire hazard.
Posted on Mar 27, 2013
1998 Thor Wanderer travel trailer. Has no breakers or fuses. How can I find out what to install?
You have a main breaker in the panel, most often 30 amps. (Possibly 50, depending on your hookup. If your cord you plug in outside has 3 prongs it's 30 and 4 prongs it's 50) then you have a 20 amp breaker for your air conditioning and a 15 amp for your microwave or outlets. As far as fuses go, usually you have a 30 or 40 for the main converter fuse(s) and then mostly all 15's in all the other slots.
Feb 24, 2016 | RVs
200 amp
I am pretty sure you would have to order that breaker to get it. if its 200 amp panel it will hold 200 amps. why do you think u would have to derate it for the solar panels. they do not create any electric load as I would think they would actually feed power into the panel and feed it back to the power grid. that would in itself lighten the load on the 200 amp main. I am going to sign up for the mobile app thing. as soon as I read up on it and will be able to discuss this more as u wish and offer assistance if need be.
have a great day and good luck
Jun 18, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
Using 4 individual breakers tied together with bar accross switches, what size individual breakers will I need to use to use for a 200 amp breaker
What are you doing?
Mar 27, 2013 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
I recently had new service installed. 200 amp load center at the top of my stairs, and a QOM2E2200NRB 200 amp enclosed breaker next to the meter socket. Idiot electrician bonded the neutral in the load...
Problem is not clear.
You have 200 Amp cut off by meter, with 3 wires from meter box:
2 Hot wires and a ground.
http://waterheatertimer.org/See-inside-main-breaker-box.html
You have 200 amp service panel.
Does the ground wire enter service panel from cut off box?
Feb 24, 2013 | Electrical Supplies
Crouse - Hines Murry Style MP or MD 200 Amp Main Breaker Difficult to Reset
A 200 amp circuit breaker has a large spring to assist in rapid opening and closing a load of this size to minimize damaging arcing every time is it operated under electrical load
The larger the circuit breaker is and the more poles (1, 2 or 3) that are being opened / closed; the more force it will require to operate - both by hand or when tripping. Compare the tension or force you need to apply to a similar sized circuit breaker at Home Depot, etc.
The troubling issue about this for me is the fact that the 200 amp service disconnect / main is tripping. This is an indication of an overloaded panel / circuit. I usually see individual circuits that trip in a panel - but often find the that main breaker has only 20% - 60% of its rating on it at any given time. If you're tripping a 200 amp service disconnect / main breaker repeatedly - something has got to give - and eventually the circuit breaker will fail. That may be where you are now with this breaker. You may be in need of a service upgrade (if it is the service disconnect) as clearly, you have out grown the 200 amp size one you currently have or need add a new sub-panel to ease the load that this 200 amp main is trying to supply now.
Either way, you should call a reputable electrical contractor to have your service / sub-panel evaluated very soon. Good luck!
Feb 21, 2013 | Bryant /murray Bj2200 Main Circuit Breaker...
Can i replace the main (100 amp) is a sq d QOC20u100F panel with a 200 amp main--i will up grade meter socket and entrance cable to 200 amps cwalker
First the part number QOC20U100F is a flush mount panel cover. The panel you have is most likely a :QO116M100. No you cannot replace the breaker as the bus in the panel is only rated for 100A. In addition I believe this is a 20CKT panel. If you're gonig to a 200A service you'd probably want more spaces than that. Home Depot and Lowes both carry 200A panels with starter set of breakers at reasonable price. The QO panels are a bit better than the Homeline
Here is a link to manual for their panels. :
http://static.schneider-electric.us/assets/DIGEST/load-centers.pdf
Aug 21, 2010 | Your One Source 100 Amp Main Lug Load...
Bought wrong panel
no, not to code plus the expense would not justify , you can purchase the 200 amp panel with the main already installed cheaper than purchasing the 200 amp breaker in most cases and still meet the code check on a panel package called a home owners kit ge makes one square d , makes one either good quality , you get the 200 amp panel, several breakers such as 20 amp 50 amp 30 amp by far the best route for you
Dec 05, 2008 | Electrical Supplies
Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE POLE CIRCUIT BREAKER 200 amp, 120/240 vac Logo
204 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Steve
Hippy_dd
Craig Butler
Craig Butler
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
