Question about Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range
Large oven does not work
Grill in large oven works but the oven it's self does not
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: cant get the ovens to work
Make sure timer is set to manual and noit auto
Posted on Dec 15, 2008
SOURCE: main ovens dont work
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Posted on Feb 05, 2009
AER5630BAS died
Check the fuse/ circuit breaker in the fuse box first if that's ok some electric cookers have a fuse or a fusible link inside the back panel, you will need a multimeter to test it (be careful electric cookers are dangerous to work on) if you are not familiar with them.
Apr 21, 2014 | Amana AER5630BAS AER5630BAS 4.8 cu. ft....
HITACH MIcrowave MCE30
There are large transformers that supply the high voltage needed for the microwave to work. They are normally what goes when they stop working. You need a high voltage meter to check them. A tech. that is equipped for microwave oven repair may be your best bet.
Jan 22, 2014 | Microwave Ovens
The grill element has fallen down because the two
What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
Apr 06, 2010 | Zanussi ZDQ695 Electric Double Oven
Could anyone tell me why the microwave aspect of the model (morphy richards)AC925EYG is not working , yet the convexion oven and the grill are working, cheers.
just had this problem, open up the caseing ond you will find a large fuse for the fan and a large black cylinder atached to the transformer coil, remove that and you will find in it a 0.8A glass fuse bet that has blown, remeber do not run machine with cover off
Mar 04, 2010 | Microwave Ovens
My double oven has stopped working, its only the large fan assisted oven which is producing no heat. The top oven/grill works okay. Is it an element problem ?
If the fan is working o/k, then you need to fit a new oven element, located at rear of oven behind removeable cover.
Please rate my solution.
Thanks.
Nov 18, 2009 | Whirlpool RBD305PD Electric Double Oven
I have a baumatic bc3510ss double oven. everything works fine except the large oven. you can turn on the grill or oven but when you turn on the temperature the rcb blows on the fuse box.
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Thanks.
Nov 01, 2009 | Baumatic Ovens
Does the upper oven grill, etc run off the same electric main and the large oven
no it does not, large oven elemnts are much thicker hence use up more amps.
Oct 05, 2009 | Ovens
My large main oven will not work on my AEG U7101- 4- M. The small second over/grill is working fine.
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Nov 27, 2008 | AEG U7101-4 Electric Double Oven
GE oven self cleaning
try fix found here http://www.fixya.com/howto/h155060-dreaded_f7_error
worked for me
Jun 30, 2008 | GE Profile JTP18 Electric Single Oven
Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range Logo
27 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
