Question about Dryers
970 c87072 10
Beeping while in drying cycle
My Kenmore electric range model #970-6784 displayed an F10 error during the cleaning cycle and started beeping. I can't clear the error or stop the alarm from beeping. Any Suggestions?
that means the temperature was "run-away" or unable to be controlled safely. To reset, unplug the main power or turn off the main circuit breaker. I would test it again as you may need a repair person if the error happens again. It can relate to a bad temp sensor.
Jan 02, 2018 | Kenmore Kitchen Ranges
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
Dryer beeps during dry cycle
if the dryer is beeping on it's own most likely you have a bad board part WP8563974
Oct 28, 2017 | Whirlpool Cabrio WED6400SW Electric Dryer
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
970 washing
make sure your door is closing good and tight
Mar 08, 2014 | Kenmore Washing Machines
KENMORE DRYER SQUEAKS ON DRYING CYCLE. WOULD LIKE TO FIND THE PART # SO I CAN ORDER A NEW BEARING. MODEL 970-C98802-10, IT 12 YRS OLD. STACKING SET. THANKS
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 17, 2011 | Kenmore Dryers
Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
Jan 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
18 people viewed this question
Top Dryers Experts
