My febo flame electric fireplace shuts down and displays a error code E3
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heat n glow fireplace comes on fine with all
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Posted on Nov 05, 2009
  • 6 Answers
SOURCE: I have a pyromaster electric fireplace model HEF
Unplug the motor wire connector and jump it with a 9V. battery. If the motor spins it's good. Chances are the FLAME SPEED CONTOL (Part Number 10001589) circuit board is bad. I had to replace mine. It's at the bottom of the fireplace behind the contols panel.
Good Luck
Perry Gibbs
Posted on Dec 05, 2009
  • 3 Answers
SOURCE: Charmglow electric fireplace flame does not
You will have to connect a 12v dc power supply to the flame motor. The controller on the board has fried. I built a regulated 12 v dc power supply and tapped it into the bulb circuit so it will power the motor when the bulbs come on. You may have to find an electrician or techie to rig this up safely.Good luck!
Posted on Dec 28, 2009
  • 90 Answers
SOURCE: Flame does not flicke in
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Posted on Nov 28, 2010
I have a FEBO Flame electric fireplace.Model ZHS30-A . im in need of a remote for it, can you help
There are several vendors of replacement OEM remotes on the internet.
Nov 11, 2016 | Heating & Cooling
What kind of a light bulb is needed for the febo flame electric fireplace?
Flickering flame fires generally use a fairly ordinary tungsten filament incandescent bulb, except the Fireglow bulbs are coated with an amber coloured lacquer. The heat from the bulb causes an upward current of air causing a small "windmill" to turn and cause the light to flicker.
That is the traditional method but ultra modern fires might use a higher-tech solution.
Oct 22, 2016 | Heating & Cooling
How do you change a bulb in a Febo flame electric fire place
FEBO Flame Electric Fireplace - YouTube
? 2:12
www.youtube.com/watch?v=o5A-QowBVbs
Nov 24, 2014 - Uploaded by Phatkat Allure De ****
FEBO Flame Electric Fireplace. ... I love my electric fireplace, more of a focal piece it is really pretty. Read more ...
How to Change a Light Bulb in your Electric Fireplace
Nov 07, 2015 | Heating & Cooling
Where do I get a remote to a febo flame electric fireplace model # BLT-999A-15-2
from the manufacturer of the authorized service agent for the product
Oct 26, 2015 | Heating & Cooling
Classic Flame 39EB500GRS Error Message E3?
I had same problem. Just stopped worked and blinked E3. I used the troubleshooting wizard on ClassicFlame's website. Shut power off (it's hardwired to 220v) for a couple minutes and it started back up. Never did find out what caused the error.
Dec 10, 2013 | Classic Flame 39EB500GRS 39 inch Builders...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
