Question about Schwinn Mesa Gs Mountain Bike
How to operate a revoshift
How do I operate the shifters
How to use revoshift gears
Twist grips usually work when pedaling. at first, try one side only, then the other.
Mar 14, 2015 | Cycling
My revoshift is functioning properly. Any suggestions for correction?
The reason its rotating out is because there is slack in the cable. To tighten the cable put shifter in lowest gear and chain on smallest chainring, Loosen derailler bolt, with a pliers pull slack out of the cable. Be careful not to pull so hard that you move derailer to next chainring. If you are unsure of this operation, consult your local bike shop.
Nov 02, 2014 | Cycling
Tips on installing the 7 speed revoshift sis shifter
Obviously, you must remove old shifter. With old cable removed, make sure you derailleur is on the smallest gear (7). String cable through cable housing, checking to see if there is any tight spots. The tight spots are places in the housing where the cable doesn't move freely. These are rust or bad spots in the housing, If you have a bit of problem, put some oil in the housing work it back and forth. If you have several problems consider replacing housing.
Now back to the installation, you gave the cable through the housing, set shifter on 7 or highest gear. Simply tighten cable at the derailleur. Tighten the derauiluer cable bolt. Check your work by running through the gears, if shifter doesn't shift thru all gears, check for slack in the cable. If slack, redo the operation again. If you continue to have problem, consider your local bike shop for assistance.
Minolta di3010
LCC Shift Failure
• The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set period of time has elapsed after the shift operation has begun (shifter is moved to the right). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set period of time has elapsed after the return operation has begun (shifter is moved to the left). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left).
1 Check the connector for proper connection, and correct as necessary. 2 PC8-LCC sensor check. 3 PC11-LCC sensor check. 4 PC12-LCC sensor check. 5 Replace PWB-C1 LCC.
Sep 09, 2014 | Konica Minolta Office Equipment & Supplies
Does not operate in reverse
If the vehicle will not go in reverse, but works in both low and high forward speeds you most likely have a bad shifter switch.
The shifter switch is only available in a shifter assembly found here: http://www.mendingshed.com/j4390-9209.html
Replacing the shifter should get your Power Wheels running correctly.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 26, 2013 | Fisher Price Power Wheels Barbie Mustang...
The 6 speed revoshift gear wiring is in need of repair and we aquired the bike with no owners mannual. can ya point me it the right direction? Thank ya. jen
One of these should get you going...
http://techdocs.shimano.com/techdocs/index.jsp
http://techdocs.shimano.com/techdocs/blevel.jsp?FOLDER%3C%3Efolder_id=2534374302052334&ASSORTMENT%3C%3East_id=1408474395181679&bmUID=iS2s7KN lists a lot of Revo Shifters
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Nexus/ShiftLever/SB-7S45/SI-65R0C-001-ENG_v1_m56577569830630954.pdf
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Nexus/ShiftLever/SL3S41E_SMBC06/6NL0A-001_SL3S41E_SMBC06-EN_v1_m56577569830625399.pdf
http://www.parktool.com/blog/repair-help will describe some of the techniques and tools required (they sell tools).
Since you'll need to go to a bike shop to buy the right shifter and brake cables anyway you should have them show you some of the fine points and ask about the special tools (cable cutter, for example) required. You may find that unless you intend to become a regular self-service bicycle mechanic the cost of equipping for that is prohibitively expensive and the occasional paid repair or tune-up would be worthwhile. In fact, a tune-up would address your problem and others of which you may be unaware.
Jan 18, 2011 | Cycling
Manual for shimano revoshift
All available manuals are listed at www.shimano.com
Dec 08, 2010 | Cycling
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
Schwinn Mesa Gs Mountain Bike Logo
18 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
