Question about ASUS EAX1600PRO/TD RADEON 1600PRO, (512 MB) PCI Express Graphic Card
512M DDR2 on board memory with affordable price (EAX1600 PRO/TD/512M
What are some best cheapest electric drums?
Electric drum set are expensive tools in music instrument world.I can't assure you that will get electric drum with cheapest price.If you got your budget near 500$ then you may get best electric drum sets.Here is some best electric drum lists http://www.musicskanner.com/best-electronic-drum-set-under-500-performance-budget/
Oct 30, 2016 | Dryers
Tip
HP Pavilion dm3-1130us Features
If you have a choice for getting beststylish HP Pavilion laptop at affordable price, then go through the details:
· Processor:1.66 GHz 6GHz AMD Athlon Neo X2 Dual-Core
· Memory:4GB DDR2 System Memory (2 DIMM)
· Videographics: ATI Mobility Radeon HD 3200 Graphics with 128MB Display Cache Memorywith up to 2046MB total graphics memory
· Operatingsystem: Genuine Windows 7 Home Premium 64-bit
Mobile users can enjoy extendedwireless feature with 802.11b/g/n WLAN and Bluetooth. Presence of 6-celldurable battery with 6 hours working backup makes it extraordinary.
on Feb 17, 2010 | Computers & Internet
I want to now which ram is used for dell latitude 640, latitude 520, latitude 430, latitude 420 and inspiron 2200 is it ddr2 or ddr1 and max capicity for upgrade
Here are the max memory and speeds:
Lat C640 is Max 512M per stick DDR-266 (PC2100) or DDR333 ( PC2700 ) for a total of 1024 Meg
Lat D520 is either 2 or 4 Meg total. DDR2-667 ( PC2-5300 )
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.Maximum memory for systems with the Intel 945GM chipset is 4096MB, maximum memory with the Intel 940GML chipset is 2048MB
Lat D430 has only slot with a Max of 1 Meg. You can use DDR2-667 (PC2-5300)  or DDR2-533 (PC2-4200)
Lat D420 is a max of  1.5G    . Use 1GB DDR2-533 (PC2-4200)
Inspiron 2200 is one slot with a max of 1280 Meg. recomended is 1GB DDR-333 (PC2700)
Here is a link to find almost any memory you need:
http://www.crucial.com/index.aspx
NOTE:
When mixed speeds in the same PC, the memory will run at the slowest speed installed or the highest speed allowed by your system, whichever is slower.
Good Luck
Dec 17, 2009 | Dell Latitude C640 Notebook
Can I use DDR2 800 MHz RAM on GA-K8NS-Ultra-939-Socket-939 MBoard
I don't think that that motherboard will accomodate the DDR800 you probably need a DDR333 or DDR400.
Calling the manufacturer support will render better information because they made the board. The memory you refer to may not fit the slot for this particular motherboard.
Aug 13, 2009 | Computers & Internet
Kingston KVR667D2N5/1G funciona como si fuera de 512M
Algunas placas madres tienen solamente 1 ranura de la memoria de funcionamiento aunque haya 2 ranuras en el tablero. Está usted usando 1 viruta o 2 virutas en la placa madre.
Jul 11, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Replaced 512M DDR with 2G DDR2, only sees 512M
This often occurs as a result of fast/quickpost settings in your bios.
You will need to shut down your system, boot it, then quickly read the black and white screen.
Then press whatever button your system displays as the setup or bios button, generally Esc, Del, F1 or F2 but can be anything.
Once in your BIOS just browse around until you find the setting marked Quickpost, Fastpost, Quiet Post, etc.
When you find the setting, Disable it, save the settings and reboot. Once you're done rebooting, check the system properties. This should do the trick, then repeat the steps to re-enable the quick mode, and reboot again. It only needs to be disable for one boot sequence to allow the computer to find and add the new hardware to it's BIOS setup.
Hope this helps FixYa,
Chris
May 05, 2009 | Computers & Internet
RAM Memory upgrade
K8V SE Deluxe DDR400 Memory Qualified Vender List
The following table lists the memory modules that have been tested
and qualified for use with this motherboard.
Size Module Vendor Model Chip Brand
SS/
DS
Chip
256M Micron MT8VDDT3264AG-40BC4 Micron SS MT46V32M8TG-5BC
512M Micron MT16VDDT6464AG-40BC4 Micron DS MT46V32M8TG-5BC
128M Infineon HYS64D16301GU-5-B Infineon SS HYB25D256160BT-5B
256M Infineon HYS64D32300GU-5-B Infineon SS HY25D256160BT-5B
512M Infineon HYS64D32300GU-5-B Infineon DS HY25D256800BT-5B
256M Infineon HYS64D3230HU-5-C Infineon SS HYB25D256800CE-5
512M Infineon HYS64D6320HU-5-C Infineon DS HYB25D256800CE-5
512M Samsung M368L6432ETM-CCC Samsung DS K4H560838E-TCCC
256M ATP AG32L64T8SQC4S Samsung SS K4H560838D-TCC4
256M Brain Power B6U808-256M-SAM-400 Samsung SS K4H560838D-TCC4
512M Brain Power B6U808-512M-SAM-400 Samsung DS K4H560838D-TCC4
512M Apacer 77.10736.464 Samsung DS K4H560838D-TCC4
256M ADATA MDOSS6F3G31YK1EZZ Samsung SS K4H560838D-TCC4
128M NANYA NT128D64SH4B1G-5T NANYA SS NT5DS16M16BT-5T
512M NANYA N512D64S8HB1G-5T NANYA DS NT5DS32M8BT-5T
256M Hynix HYMD232646B8J-D43 AA Hynix SS HY5DU56822BT-D43
256M Kingston KVR400X64C3A/256 Hynix SS HY5DV56822BT-D43
512M Kingston KVR400X64C3A/512 Hynix DS HY5DV56822BT-D43
512M Winbond W9451GCDB-5 Winbond DS W942508CH-5
256M Kingston KVR400X64C25/256 Winbond SS W942508BH-5
256M ADATA MDOWBFF3G31JB1EAE Winbond SS W942508BH-5
512M TwinMOS M2G9J16AGATT9F081AA4T TwinMOS DS TMD7608F8E50D
256M TwinMOS M2S9I08AFAPS9F0811A-T PSC SS A2S56D30ATP
256M KINGMAX MPXB62D-38KT3R KINGMAX SS KDL388P4EA-50
512M KINGMAX MPXC22D-38KT3R KINGMAX DS KDL388P4EA-50A
256M CORSAIR CMX256A-4000 XMS4000V1.1 CORSAIR SS
ive found the best prices at tigerdirect.com and they ship it right to your door. make sure the tiger ppl have the exact match and dont replace your order with more expensive replacements as some of these substitutions require voltages that your motherboard CAN NOT produce and will not work.. you also want to make sure to buy low density ram, it performs better, is a few bucks more than high density, but worth EVERY penny. E-bay is notorious for selling cheap high density ram on thier site.
If you stick to the list above, you shouldnt have any issues.
This should fixya up! please rate...
Oct 28, 2008 | Computers & Internet
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
Gigabyte GA-8IPEI000 pro-g DDR2?
Sorry your board does not support DDR2 memory. The dimm slots that you mention above are only showing you which slot is number one & number two. This does not mean the memory is DDR2. See your spec's at this link.
http://www.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ProductID=1759
Jan 27, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
ASUS EAX1600PRO/TD RADEON 1600PRO, (512 MB) PCI Express Graphic Card Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
