KM photocopier display error code- 0180. What is the solution of the problem?
5 Suggested Answers
SOURCE: c-7 980 error code
i think in km1500 there are no waste ink bottle
may reset in copier its slove
Posted on Jun 29, 2009
KingDWS
  • 1606 Answers
SOURCE: ''HP Laserjet 4600, Error code 81 0180 E10 1 Error''
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Posted on Jul 09, 2009
SOURCE: How do I clear machine error code E04-01 on a
How do I clear machine error code E04-01 on a Panasonic DP-3030 photocopier?
Posted on Sep 20, 2010
Prefab
  • 152 Answers
SOURCE: My Kyocera KM-5035 receive error
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
Posted on Feb 05, 2011
How do I fix error code C-6 with a KM 2020 copy machine
It is resettable to enter simulation so .....
Press and let down "Clear / Stop", "Start" button on the left to darken or clear, then "Stop / Clear" "U163", "Start" appears "CLE" and there you hit "Start" other time and now.
Feb 22, 2015 | Kyocera Office Equipment & Supplies
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
My Kyocera KM 1635 / 2035 displays error message: error call 600
Needs a service, either call your photocopier service company or find one on google.
Mar 19, 2012 | Kyocera Office Equipment & Supplies
I get an error message on my photocopier Kyocera KM-1500 Error C-06
The code 6 is a 'fuser' error code. It means that their are defective parts (like a blown lamp or thermistors/fuse, etc. It will require service.
Sep 24, 2011 | Office Equipment & Supplies
I have an error code C6 020 in my copier kyosira KM 1635. Please give me the means of this and what I can do to reslove the problem. Thanks
goto service mode by pressing 10871087. then press 163 then start 4 times.the machine will restart and wola
Jun 03, 2011 | Kyocera Copystar CS-1635 Copier
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
KEOCERA MITA photocopier KM4035 have problem. My Machine is showing error code C6000. How to tackle this proble. Please help me as soon as possible.
KM/CS 2530, 3530, 4030, 3035, 4035, 5035
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Press EXCUTE on the touch panel. It is displayed in reverse.
Press "Start / Print key.
The machine will turn off and then back on then come back to ready. If not then you need to replace the fixing unit.
Feb 02, 2011 | Kyocera Mita KM-4035 Printer
Which numbers can i press when i get error c-6, 400 om a KM-1620 photocopier?
Put the machine on and press 1087, 1087 until the display shows U000. Press 163 and the press start .display shows CLE, press start again. The machine will initialize and become ready for copying
Nov 15, 2010 | Kyocera Copystar CS-1620 Black and White...
11 people viewed this question
jasbo
jasbo
