Question about Rainbow Technologies D4 Bagless Vacuum
Meter Switch for Rainbow D4 Vacuum
The unit died while in use. My wife thought the cord came out of the wall outlet but after trying different outlets, we realized it's the unit. the brushes are worn down and probably need replacing but I want to eliminate the on/off switch as a possibility. I removed the switch and the toggle piece(on/off printed on it) but can't see how to get inside to meter it. Is there a way to meter the switch and, if so, how and what should a correct reading be? thanks.
5 Suggested Answers
RockyNR1
  • 324 Answers
SOURCE: dissasimble a rainbow vacuum
See this
Rocky
Posted on Sep 19, 2009
renevacdoc
  • 84 Answers
SOURCE: I need to know how to attach the aquamate
You should have a non-electric hose which you want to attach to the vacuum suction, then take the long skinny hose and hook it to you kitchen faucet. You may have to unscrew the end piece from your faucet. turn on youir hot water. On the handle of the aquamate, there is a little holder. Unhook it by releasing the yellow button. Put your shampoo to the line, no need to dilute, the Aquamate will mix the right amount to the water. Now you are ready to shampoo. You can pick up water until you hear the machine stress out. That is time to change the water in the basin. It is probably best to change it before that, but don't worry, the separator keeps it out of the motor. Hope this helps fixya! Thanks, Let me know, Rene (the Vacuum Doctor)
Posted on Nov 17, 2009
  • 41 Answers
SOURCE: Need wiring diagram for Rainbow D4C vacuum to
You can get a wiring diagram at http://www.rainvac.com/schematic.html
You can get all of the manuals, and the full breakdown schematics, of every model there.
If you need me to tell you which wires go where, exactly on the switch, let me know. I am a Rainbow vacuum expert and know everything about almost every model ever made.
If you have any more questions, let me know.
Thank you,
Posted on Jun 13, 2010
  • 41 Answers
SOURCE: D4 Rainbow leaking water around the water basin
Clean the water separator. Use a tooth brush if you do not have the Rainbow separator cleaning brush. It is the same thing, and works perfectly. :-)
Ralph
Posted on Jan 12, 2011
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
My rainbow vacuum e series won't turn on.
it could be the switch . or brushes
Feb 01, 2015 | Rainbow Vacuums
Rainbow power head works but canister dont model d4
Chances are the motor died or went bad.
You would have to get a new motor.
You can find one here:
Rainbow D4 SE motor 120V
Or a more cost effective refurbished D4 motor unit here:
Rainbow D3 D4 SE motor unit
GoodVac.com
800-775-6586
Jul 04, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How does the Power Head wire up to the switch on the Rainbow SE?
Here is the wiring for a D4 switch:
Rainbow D3 D4 SE power switch
Rainbow no longer makes the switch with 6 wires, it comes now with only 4.
GoodVac.com
800-775-6586
Jun 29, 2014 | Rainbow 75th Anniversary Canister Vacuum
Why rainbow vac wont turn on
There are numerous reasons. If there was no smoke or burning smell, first try a different outlet. Then you can try wiggling the cord and check cord for damage, if you can get it to start and it turns off again cord is loose or damaged. Try the switch, sometimes switch wears out, if it is not making a click sound or is very loose it may be the switch. The most common reason for an E series to not start after working just fine is a broken actuator on the water basin or missing from the bottom of the vacuum. There is a raised part on the water basin that depresses a little black plastic actuator on the bottom of the vacuum. This is a safety switch to make sure the water basin is there so the vacuum will turn on. You can try pressing in on that and trying to start your vacuum, if it starts you will need to check and see if the part is broken off of your basin or if the little black actuator is missing. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Rainbow E series Canister Wet/Dry Vacuum
D3C RAINBOW VACUUM POWER CORD
if you mean you wont to replace the cord this video will show you
Jan 05, 2013 | Rainbow Technologies D4 Bagless Vacuum
Power cord leaks green oil
I suggest that you replace that corroding internally power cord. It may not be safe to use that power cord.
You can get your model information, at the bottom of your vacuum canister, from underneeth, where the water pan attaches to it.
It is probably a D3, or a D4
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 10, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I just purchased a rainbow D4C, after purchasing i was told i should have purchased the SE model. whats the difference?
There is only one difference between the D4 and the D4 SE, which stands for D4 (Special Edition). It is the exhaust plug screws in on an SE and snaps in on a regular D4.
Then the SE-PE came along, which stands for (Special Edition-Performance Edition) which has a more powerful motor, with larger motor brushes, for more power and runs on 9.8 amps, where the regular SE and D4 run on 8.8 amps. It also has the newer PN-2 power nozzle, which is very much like the latest E and E2 series Rainbow vacuums, instead of the earlier rectangular ones, that have the bottom metal plate, which will rust. You can upgrade your D4 to one of these, though you will need the electric hose with gas pump style handle, with the built in power corn in it.
They are all D4 models.
Thank you,
Ralph
Apr 02, 2010 | Rainbow 75th Anniversary Canister Vacuum
Vacuums Logo
321 people viewed this question
Top Rainbow Technologies Vacuums Experts
JoeVacs
Are you a Rainbow Technologies Vacuum Expert? Answer questions, earn points and help others
