Whirlpool washer model wtw4800bqo fills really slow
SOURCE: Whirlpool washer: Very slow fill cycle on the
I had a similar problem - unscrew the water hose feed lines from the back of the machine and clear out any sedimentation build up from the filters. You can use a turkey baster to siphon off. If filters are clear you may have to replace watervalve. Look at vitual repairman,com as to how to remove the back. Replacement cost about $26.
Posted on Mar 28, 2009
ginko
  • 19396 Answers
SOURCE: won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Posted on Nov 14, 2009
SOURCE: The tub on my whirlpool washer fills with water but will no spin
I am not a appliance repair technician, but before one starts taking apart motors, and drives, it would be imparitive to simply check the lid switch I have repaired several washing machines by simply checking this part.
Posted on Jan 05, 2010
  • 46 Answers
SOURCE: our front load whirlpool washer gradually fills
water inlet valve in the machine is either sticky or faulty. get it replaced. till the time, after wash, keep your water valve (which supplies water to the machine) closed
Posted on Mar 19, 2010
dburns60
  • 410 Answers
SOURCE: very slow filling
Right where the two supply hoses screw on the back of the unit. Remove them and clean out the little screens that keep chunks of dirt out. Your water supply will be back to normal. Remove them only if you h-a-v-e to.
Posted on May 12, 2010
Washer wont drain- model whirlpool wtw4800bqo
Pump malfunction,check for blockage or timer.
Jul 26, 2014 | Whirlpool Washing Machines
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Very slow filling
May 12, 2010 | Washing Machines
Whirlpool top loader: very loud pumping sounds when filling
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
Whirlpool washer will not stop at end of cycle
Turn off extra rinse switch or pull wire going to it. If water is slow the water valve may have a restriction in it. Remove hoses and check for blockage in the hose screens.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
Mar 27, 2009 | Washing Machines
Yes if its filling slow do to a blockage in a screened hose it will .If it never stops filling and doesnt over flow than its syphoning the water and you need to elevate thr drain hose higher than the water level and it will kick into wash. Please rate This !!
Jul 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Top Load Washer
Your washers lid switch could be worn and need to be replaced. Depending upon the model you may see a small peg on the washer lid that mates with a hole on the machine. The switch is located beneath this hole. You can try poking the switch with a pen or similar object to see if it activates the wash cycle. it will only work if the switch indicates that the lid is closed.
Jan 24, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
276 people viewed this question
Top Washing Machines Experts
