Question about gmail.com
Ellen.garton - gmail.com
I wanted to know if Ellen received a gift. It was something I thought she should have.
Ask her yourself. http://www.ellentv.com/be-on-the-show/#Getting in Touch with Ellen
Oct 06, 2014 | Cell Phones
The keyboard latch on my Studio 1555 snapped in half. What can I do?
Ellen, Ellen, Ellen,...............if I've told you once, I've told you..........
WAIT!
Where am I?
OH, I'M JUST KIDDING!
(Ellen?............................Ellen?.....................darn!)
This = Not good.
Most of the time you are looking at motherboard replacement.
However I have read a few 'tricks', and believe this may help you,
http://www.laptoprepair101.com/laptop/2009/11/17/fix-broken-keyboard-connector-on-laptop-motherboard/
We're talking STICKY tape here. Not Christmas wrapping present tape.
More like the stuff the Post Office uses.
The kind that NEVER comes off! (Or so it seems, lol!)
For additional questions please post back in a Comment.
Regards,
joecoolvette
Mar 20, 2013 | Dell Studio 1555 Laptop Computer 15.6-Inch...
NETGEAR Wireless router: I installed it as per instructions on my PC - didn't really know what exactly I was doing....I have Time Warner cable (RR). Now my i phone and NetBook show a wireless network...
You router is sending out the signal under the network of Ellen-p. you need to enter the password to both your cellphone and netbook. Once entered, both devices will remember the connection.
The password is normally issued with a router from an internet provider (Time Warner) and is called a 'WPA2' password is normally a set of random upper and lower case letters and numbers like AAP7CD81. It may be that you set up a password when you set the router up, in which case you use that password.
Another possibility is that the password is on a sticker on the router or on a sticker that came with it.
Jun 22, 2017 | NetGear Wireless router EN Fast EN
How to fix linkage in 2002 9-3 turbo. Car does not go into reverse, 1st r 2nd gear.
Assuming this is an Manual, there is an adjustment next to the firewall in the engine compartment. You have to lock the transmission with an object like an ellen on the top of the transmission and then with a very long extension and 13mm socket, loosen the bolt near the fire wall and make very small adjustments to the shifter and then tight the bolt again to see how it goes. This is a trial and error method to get shifter realigned. Once done, remove the ellen from the locking hold in the top of the transmission (and when testing shifting).
Jun 05, 2010 | 2002 Saab 9-5
Will not print material from the internet.
Open up the Printer Properties icon on your computer. Its location varies with OS versions, but typically click on Start, then Control Panel then Printers. Make sure your printer driver is correctly installed. Select the FAX choice and see what is set up to function as Fax; the only reason that programs call up the Fax would be if the Fax is defined as your default printer. Suggest an actual printer and set the printer as Default; printer problems should be solved. Problems? contact Jaye Ellen at jaye.ellen@gmail.com
Apr 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
When scrolling a page the graphics roll up like a slow moving blind
Hi Linda,
Have you solved your problem? I have exactly the same computer - and exactly the same problem ... I would be very grateful if you could tell me if and how you solved your problem!
Thanks,
Ellen
ellen(dot)pay(at)hotmail(dot)com
Apr 19, 2009 | Computers & Internet
INSTALLING DISC FOR MFC210
Hi Ellen, not sure if your problem is that you can't download ar that you don't know where to find the software.
The Full Driver & Software Package can be downloaded from the Brother website (63Mb).
hope this helps
Albert
Nov 09, 2008 | Brother MFC-210 All-In-1 Print/...
gmail.com Logo
21 people viewed this question
Top gmail.com Computers & Internet Experts
David Payne
David Payne
john cordey
john cordey
Thomas Stauber
Thomas Stauber
Are you a gmail.com Computer and Internet Expert? Answer questions, earn points and help others
