Question about Kitchen Ranges
How to remove the control panel cover on a Thermador GCR48 6GD range
The griddle knob screw is broken off from inside the control panel cover.
SOURCE: remove panel behind ignitor knobs
I found the solution at Fixitnow.com. Apparently the knobs are VERY difficult to remove and must be pried off using two screw drivers on either side of the knob and working back and forth. I sprayed them with WD40 before replacing them.
After getting past this poor design issue, the remainder of the repair was very simple, as I expected it would be.
Posted on Oct 10, 2008
SOURCE: Flashing Lights on Thermador Oven/Range
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
SOURCE: Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Posted on Jun 03, 2009
EllaWatson25
  • 725 Answers
SOURCE: I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Posted on Nov 10, 2009
On a Blue Star 48" range. I need to replace the griddle thermostat assemble but can't access the assembly behind the front panel. Can I remove the front panel to get to replace the unit?
If the back does not come off then, yes, the front must come off. You may be able to take the whole console head off and work on it from underneath if the first option is not possible.
Feb 20, 2015 | Kitchen Ranges
How do I replace a broken stem on the griddle knob of a forty-eight inch Viking range?
You would remove all of the knobs and then you remove the screws holding the face panel on there. Then you can access burner valves. The new part may not come with a preset orifice because the factory does not know which type of gas you have. So what they do is tighten the orifice all the way down. Lets see if I have a viking service manual:
Viking Stove Manual
Viking parts outlet
Oct 29, 2010 | Viking Kitchen Ranges
Thermador cooktop ignitors won't stop clicking
I have the same range top. I am looking for the switch assembly. Do you know where I can buy this part? Please email me if you do. prboardman@yahoo.com
Dec 30, 2009 | Cooktops
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
try this.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
Thermador PGR486GDZS Griddle not igniting
I would consult a qualified Gas Safe engineer as the small computer thing on the side of the electrode is a sensor to shut of the supply if there are errors with the flame.
Feb 26, 2017 | Thermador PRG484GGUS Gas Kitchen Range
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
JENN-AIR CVG4380W SPARK IGNITER
You should be able to remove the hose from the blower and lift the unit out of the countertop. Then there should be screws around the sides to take out that will give you access to the inside.
Oct 09, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
