Question about Southwestern Bell FA970SN Digital Answering Machine
DAY AND TIME SET
How do i set the day and time on the ansering machine. my manual was lost in the move and i can not remember how to do it.
Press & hold the repeat button. It will tell you the day & time, then repeat the day. Let go of the button. It will repeat the day. Press play until you get the right day and move thru until you have the right time of day. Good luck!
Posted on Dec 22, 2007
Lost manuel....how do I set the day and time....
1. Turn on the system. Hold down
SKIP/TIME SET/CHECK. The
system sounds a tone after 1
second.
2. While holding down SKIP/TIME
SET/CHECK, press REPEAT/ANNC/
DAY. The system announces
"Monday" and &'?appears on the
display. Repeatedly press REPEAT/
ANNC/DAY until you hear or see the
correct day.
3. While holding down SKIP/TIME
SET/CHECK, press MEMO/2 WAY/
HOUR. The system announces "1
AM". &' appears on the display.
Repeatedly press MEMO/2 WAY/
HOUR until you hear or see the
correct hour.
4. While holding down SKIP/TIME
SET/CHECK, press PLAY/PAUSE/
MIN. The system announces "01".
Repeatedly press or hold down
PLAY/PAUSE/MIN until you hear or
see the correct minute.
5. Release SKIP/TIME SET/CHECK.
The system announces the day
and time you set.
6. To hear the current day and time,
press SKIP/TIME SET/CHECK while
the system is on or off.
Thanks!
Mar 29, 2011 | Radio Shack 3808 Digital Answering Machine
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
I have an Intermatic timer Model HB71R and I've lost the instructions. Could you please send them to me? please send to the following email
Slide the middle left switch to TIME SET. Use the DAY, HOUR and MINUTE buttons to set the current day and time.
Slide the middle left switch to PROG.
When you set the switch to PROG, the number on the right on the LCD display will be a 1, and it will say ON above it. Adjust the DAY, HOUR and TIME for when you want your first program to turn on. Then press the bottom left EVENT button to proceed to set the OFF time for program 1. Adjust the DAY, HOUR and TIME for when you want your first program to turn off.
Press the bottom left EVENT button to move on to your 2nd event, and set the ON time. Again, press the bottom left button to move on to your second event OFF time. Continue in this way until you have programmed up to six different ON/OFF events. When you have programmed as many events as you need, slide the middle left switch to RUN at the center position.
To use the timer now, slide the upper left switch to AUTO at the middle position. The upper left switch, when moved to the right hand AUTO RAND position, will run the programs, but randomly start and stop them within a half hour of their programmed settings.
To use the timer manually, slide the upper left switch fully to the left to MAN, and press the bottom left switch to cycle between ON and OFF.
Dec 12, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I lost the manual, how do I set the day and time, and rings to answer. It picks up after 4 rings, can I set it for more rings? Thank you
I have this answering machine...
To set the day and time press the "REPEAT" button and hold it in. It will say something like "Time not set." and if you keep holding it it will say, "Monday." Now release the "REPEAT" button and use the "ON/OFF" button to cycle through the days. When it says the correct day, press and releasethe "REPEAT" button. Then it will go on to set the clock and you're done.
To adjust the rings, there is a slide switch on the top where the cords plug in. You can switch it to 2, 4 or TS (Toll Saver). Toll Saver generally lets it ring for about 5 rings before answering.
Nov 24, 2010 | Conair TAD2018CG Digital Answering Machine
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
Oct 11, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
UNABLE TO PROGRAM MY AIR CON AS NO CODE OR INSTRUCTIONS. HAVE LOST MANUAL
At a minimum there should be a manufacturer name on the control. And possibly some sticker with model number inside the control (or on the pc board). You may google their website and find the manual there. Most are fairly straight forward. For example, first set time and day, the set control to heat and hit program button. set start time and temp, set end time and temp, set day. Some can program each day, some 7 days, some 5 days and the weekend. Some have multiple events for each day depends on the model.
Sep 18, 2010 | Heating & Cooling
How do I set the time and date on my 43-3829 answer machine?
Hi, here are the instructions for setting the time on a 43-3825, which is a very similar model. They should work for your machine too.
1. Press and hold TIME SET/CHECK/>> until you hear it beep twice. 2. Press ANNC/DAY/<< and the machine will say a day. Keep pressing that button until you hear the correct day. 3. Press REC and the machine will say the hour. Keep pressing it until you hear the right hour. 4. Press >= (the play/pause button) until you hear the right minute. 5. Once you've gotten the correct day and time, press TIME SET/CHECK/>> to save it.
While you're doing this, you can't let the machine sit idle for more than 5 seconds at a time, otherwise it will exit the time setup and you'll have to start over again. Good luck!
Mar 15, 2010 | Radio Shack 3825 Answering Machine
How to set time on the southwestern bell answer machine FA982B
I went to the southwesten bell freedom phone site on the web. Found answering machines.  My old machine was not listed, so I found instructions for a later machine.
The method for setting time was similar.  I tried it and it worked fine.
Your high prices prompted me to be less lazy.
Jun 10, 2009 | Southwestern Bell Lands Phones
Model#fa972 southwestrn bell freedom phone answering machine
Press the >>/Time Set button for about 2 seconds. The system will announce "Monday" press the >>/Time Set again to choose the correct day. Press <</Time Check to change to hours. Select the correct hours by pressing the >>/Time Set, then press the <</Time check to change to minutes. I can't get the mail box 2 to operate either.
Jan 06, 2008 | Southwestern Bell FA972 Digital Answering...
Southwestern Bell FA970SN Digital Answering Machine Logo
169 people viewed this question
Top Southwestern Bell Lands Phones Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
