Question about GE Profile PSI23NCR Side by Side Refrigerator
Ice maker doesn't work
I get water but the ice maker is not making ice. It is totally empty and there is not apparent problem. Help!
  • 3 more comments
  • rebc Nov 13, 2007
    Where is the fill tube and if it is frozen shut, how do you correct the problem?
    Bob
  • needyas Nov 19, 2007
    I have a kenmore side by side refrigerator. I can get water from the unit but it won't make any ice. The red light keeps blinking. Please help.
  • Anonymous Jul 11, 2008
    water no ice
  • jadcoach Jul 23, 2008
    I have a GE Profile side by side fridge and I am getting water to the system but the ice maker is empty and it will not procuce any ice...any suggestions?
  • Anonymous Sep 05, 2008
    G.E. Side by sude refrg. does not make ice. I get water but no ice
  • 473 Answers
When you say you are getting water do you mean you are getting water in the ice maker tray? If so then unfortunately you will need to replace the ice maker. If not getting water to the ice maker then make sure the fill tube to the ice maker isn't frozen shut. If so, thaw it out and see what happens. If it isn't frozen shut then replace the ice maker. New ge ice makers, when installed, will not cycle until the ice maker gets below freezing so you will have to wait once it is installed.
Posted on Oct 07, 2007
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Ice maker not producing any ice and need help
Have you tried turn it off and totally defrosting the unit. Sometimes the ice making mechanism leaks a bit of water where it shouldn't and it just frezes the mecahanism.
Oct 11, 2014 | Marvel Appliance Ice Maker
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Rfg297aa won't make ice
Ice maker quit making ice. Ice tray in feeder was empty when I pulled it out. Water is working when I choose water but apparently no water is getting to freezer unit. What else can I check or do?
Oct 28, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker stopped making ice. I emptied ice holding tray and since then, if will not make ice. I adjusted arm in hole correctly. Arm is down and is in correct position to make ice. Still no ice. Please...
Fill the ice maker with water. If it freezes and dumps the the water control valve on rear of the refrigerator and near floor is defective and will need replace. If the water just freezes then the ice maker thermostat is the problem, Let me know,Thanks Sea Breeze
Aug 17, 2009 | Refrigerators
Not producing ice
There are several possibilities. The dual water control valve is defective going to the ice maker, defective ice maker thermostat; frozen water fill tube leading to the ice maker is blocked with ice. You can see if ice maker is working by filling it with tap water and waiting to see if it dumps. If it does not empty the icemaker of the ice I would think ice maker thermostat. If it dumps ice and does not refill I would say you need a new dual water control valve. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker is not working but water dispenser is.
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Self-Diagnostics
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
GE Profile PSI23NCR Side by Side Refrigerator Logo
1,596 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
