Question about Dreamline SHCM-2358-00 Aluminum Five Handle Shower Panel With Rainshower H
Grohe instruction manual
Replace o ring
I need anInstallation Manual for Grohe Concetto faucet..where can I find one?
contact the plumber and have him fix his mistake the faucet came with instructions . what did he do with them
Oct 16, 2014 | Grohe 3427 Concetto Single Hole Bathroom...
What causes grohe tenso to leak at the body and spout location
Most likey the "O" rings on the spout body are bad, need replacing.
Aug 10, 2014 | Grohe 32924000 Tenso Single-Handle...
I have misplaced my Grohe Rainshower 28767B instruction manual and need to obtain a new one asap... Thanks
Here ya go:
http://www.grohe.sg/m/25_7311/page/modules/search/index.php
or
http://www.grohe.sg/icms_dyn/lib/general/wrap/download/~/7295/18/PDF/Brochure_AU_new.pdf
Mar 29, 2011 | Dreamline SHCM-2358-00 Aluminum Five...
I have a grohe 19 614 thermostatic valve / mixer. I want to adjust it so that the wateris hotter than what is coming out right now. I have the diagram showing how to take the trim off, and shows where to...
http://docs.homeclick.com/PE-Links/Grohe/Grohe-19614-manual.pdf
1. Turn thermostat handle (L) to the 100 °F (38 °C) safety
check, see fig. [6].
2. Unscrew handle (N) or lever (O).
3. Unscrew cap (M).
4. Pull off thermostat handle (L).
5. Remove screws (H) and escutcheon (G), see fig. [4].
6. Close both isolation valves (I).
7. Pull sleeve (F) from the mixer shank by pressing
down the tongue (D2), see fig. [7].
8. Extract clamp (D1).
9. Pull stop ring (D) until resistance is encountered
(approximately 3/8" [10mm]), see fig. [8].
10. Unscrew stop ring (D) complete with regulator
nut (K).
11. Unscrew thermoelement (47 050, 47 582) with 24mm
open-ended wrench, see page 2.
It is not too clear to me, but I'm not looking at it. lol
Gary
Dec 14, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
My grohe faucet leaks when turned on from around the base of the device where it goes through the counter top. Wiggling the spiggot makes it leak worse. It is 4 years old The cartridge looks clean. It is...
There are two O rings in the spout body that need to be replace with new and lube the
new O rings with vaseline. If your water is too hot, this will dry out the O rings. Normally
your hot water shouldn't be more than 120 degrees F. You can check this by holding a
thermometer in the stream of water with the hot on only.
Grohe has a lifetime warranty on them. I have taken many Grohe's back to the wholesaler
and they just give me a new one, no questions asked.
Nov 02, 2010 | Grohe Plumbing
Freehander leaks at shower heads
Hi
Thank you for your query
If you just grab the showerhead with one hand and then unscrew anticlockwise the pipe underneath it should just screw off, once this has been done simply replace the O ring and rescrew
I hope this has been useful
Mar 14, 2010 | Grohe 27.007 FreeHander Shower Head Shower...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Whenever i pull out the head on my grohe ladylux faucet, water starts to run back along the hose and down under the sink. i've replaced the head itself and the o ring but it still does it. can anyone help...
call grohe and have them send you the hole unit hose and all they warranty it it for life it is obvious there is a slite crack in the head base, they will send it for free
Apr 13, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Dreamline SHCM-2358-00 Aluminum Five Handle Shower Panel With Rainshower H Logo
49 people viewed this question
Top Dreamline Home Experts
Donni Steen
Tom Chichester
Are you a Dreamline Home Expert? Answer questions, earn points and help others
