Question about Garden
Camshaft timing marks 6.75 hp eager 1
Need location of crankshaft timing mark
  • 883 Answers
SOURCE: camshaft timing mark
here's a graphic:
please rate me solved!
Thanks!
Posted on Jun 26, 2008
  • 4 Answers
SOURCE: HELP!!!!need timing marks for pajero 94 2.8 auto *** import
there is a little mark on the crankshaft which you line up with the 'o' mark on the casing ..
remove the cam cover and look at the cam you should see a nob on the cam about 3 th lob and that should be facing just left of the engine ..
if you have a turbo there is two notchs on the injection pump pully ..if turbo there is a 't' mark on the rear of the cover the notch on the pully should mark up with the 't'..
the timing is set..
Posted on Mar 09, 2009
ZJLimited
  • 17970 Answers
SOURCE: I need the timing marks to set the crankshaft to top dead center
1986 Dodge Truck RAM 50 4WD 2.6L 2BL 4cyl
Fig. Timing belt and components-2.0L engine
Fig. Location and correct alignment of timing marks for the timing belt (camshaft)
Fig. Timing marks-2.3L diesel engine
Fig. Timing marks-2.4L engine
More details, autozone.com (free register). Good luck.
Posted on Sep 29, 2009
motor1258
  • 6674 Answers
SOURCE: camshaft timing mark crankshaft timing mark
Belt covers need to be on. Timing mark on crankshaft (while on compression stroke) should line up with TDC mark on cover. then Camshaft mark, needs to line up by looking through access hole of cover, and align mark on cam sprocket with pointer on inside of belt cover.
Posted on Oct 22, 2009
emissionwiz
  • 79865 Answers
SOURCE: 1992 Volvo 960 Broken timing belt
IF U BROKE THIS BELT WHILE DRIVING U HAVE BENT THE VALVES IN THE ENGINE, THIS IS WHAT IS CALLED AN INTERFERENCE DESIGN ENGINE, THAT MEANS WHEN THE TIMING BELT BREAKS THE PISTONS HIT THE ENGINES VALVES
Posted on Nov 11, 2009
Testimonial: "THanks - was not able to accept this last answer, but thankfully I found another way to say THANKS. That notch was suspicious!"
1977 ford pinto timming marks
Hope this helps. Please don't forget to rate....thanks!
Crankshaft, camshaft, and distributor timing marks-2300 cc engine (© Ford Motor Co.)
On 2000 cc engines, turn the crankshaft until the two round locating holes in the camshaft pulley are visible from the rear side of the pulley, looking forward from the left-side of the car. When these two holes are parallel to the ground, the timing pointer on the crankshaft pulley should point to TDC. If the drive belt is dislocated, the crankshaft damper will be retarded or advanced 19° per cog on the belt.
If the engine you are working on does not have the two locating holes on the rear side of the camshaft pulley, then you will have to remove the drive belt cover and observe that when the crankshaft timing marks are aligned to TDC of the compression stroke of the No. 1 cylinder, the distributor rotor is pointing to the index mark on the upper lip of the distributor housing which coincides with No. 1 spark plug tower, and the pointer on the camshaft pulley is aligned with the index mark on the cylinder head.
On 2300 cc engines, there is an access plug provided in the cam drive belt cover so that the camshaft timing can be checked without removing the drive belt cover. Remove the access plug, turn the crankshaft until the timing mark on the crankshaft damper indicates TDC, and observe that the timing mark on the camshaft drive sprocket is aligned with the pointer on the inner belt cover. Also, the rotor of the distributor must align with the No. 1 cylinder firing position.
CAUTION:
After any procedure requiring removal of the rocker arms on the 2300, each lash adjuster must be fully collapsed after assembly, then released. This must be done before the camshaft is turned.
Checking 2000 cc overhead camshaft timing (© Ford Motor Co)
May 08, 2011 | Ford Mustang Cars & Trucks
I need the timing marks 2001 sonata 2.5
Welcome to Fixya
Turn the crankshaft clockwise, using the Hyundai crankshaft wrench, until the crankshaft sprocket timing mark lines up with the timing mark on the block at the 1 o'clock position. Check the camshaft timing marks. If they are not lined up, turn the crankshaft over again until the crankshaft mark lines up. The camshaft marks will be lined up. The left camshaft mark (as you are looking down at the engine) is at the 11 o'clock position. The right camshaft mark is at the 1 o'clock position. Thank you for using Fixya!
Mar 06, 2011 | Toys
Como poner la banda de tienpo de un toyota camery
Installation
1.Install No. 2 idler pulley (if removed). Install and tighten bolt to specification. See TORQUE SPECIFICATIONS . Ensure idler pulley is clean and rotates smoothly. 2.Install No. 1 idler pulley and tension spring (if removed). Pry No. 1 idler pulley away from timing belt area as far as possible. Temporarily tighten No. 1 idler pulley bolt. Ensure idler pulley is clean and rotates smoothly. 3.Using crankshaft pulley bolt, rotate crankshaft so timing mark on crankshaft sprocket aligns with timing mark on oil pump housing. See. This will position keyway in crankshaft sprocket at 12 o'clock position.
CAUTION:If reusing timing belt, ensure reference marks on timing belt align with reference marks placed on crankshaft and camshaft sprockets. Ensure timing belt is installed in original direction of rotation.
4.Ensure all sprockets and idler pulleys are clean. Install timing belt on crankshaft sprocket, oil pump sprocket, No. 1 idler pulley, and then No. 2 idler pulley in sequence. 5.Install timing belt guide with cupped side away from crankshaft sprocket and flat side toward timing belt. Install No. 1 timing belt cover and new gasket. 6.Align crankshaft pulley key groove with key in crankshaft. Install crankshaft pulley. Install and tighten crankshaft pulley bolt to specification. 7.Rotate crankshaft clockwise so cylinder No. 1 is at TDC on compression stroke. Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover. If reusing timing belt, ensure reference mark on timing belt aligns with upper edge of No. 1 timing belt cover. 8.Rotate camshaft, and align hole in camshaft sprocket with alignment mark on camshaft bearing cap. See Fig. 2 . Install timing belt on camshaft sprocket. If reusing timing belt, ensure reference mark on timing belt aligns with the reference mark on camshaft sprocket. Ensure tension exists on timing belt between the crankshaft and camshaft sprockets.
CAUTION:DO NOT rotate crankshaft counterclockwise, as viewed from timing belt end of engine.
9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence.
Dec 23, 2010 | 1993 Toyota Camry V6
2005 f250 5.4 gas need to know specs for timing a diagram would be awesome
To Install:
  1. Install balance shaft drive gear onto the left camshaft.
  2. Install the camshaft sprockets and new bolts finger tight.
  3. Using a vise, compress the timing chain tensioner plunger.
  4. Install a retaining clip on the tensioner to hold plunger IN during installation.
  5. If timing chain copper links are not visible, mark 2 links on one end and 1 link on the other end to be used as timing marks.
  6. Install right and left timing chain guides. Tighten bolts to 89 in-lbs (10 Nm).
  7. Rotate the left camshaft until the timing mark is at the 12 o'clock position.
  8. Rotate the right camshaft until the timing mark is at the 11 o'clock position.
  9. Position the crankshaft using the special tool. Then remove the tool.
  10. Install the crankshaft sprocket with flange facing forward.
  11. Position lower end of left (inner) timing chain on the crankshaft sprocket. Align the copper (or marked) chain link with the timing mark on the outer flange of the crankshaft pulley. NOTE: Upper half of timing chain must be below the tensioner arm dowel.
  12. Position the left timing chain on the camshaft sprocket. The timing mark on the camshaft sprocket must be aligned between the 2 copper (or marked) chain links.
  13. Place the left timing chain tensioner arm on the dowel pin and install the timing chain tensioner and bolts. Tighten bolts to 18 ft-lbs (25 Nm). NOTE: Lower half of timing chain must be above the tensioner arm dowel.
  14. Position lower end of right (outer) timing chain on the crankshaft sprocket. Align the copper (or marked) chain link with the timing mark on the outer flange of the crankshaft pulley.
  15. Position the right timing chain on the camshaft sprocket. The timing mark on the camshaft sprocket must be aligned between the 2 copper (or marked) chain links.
  16. Place the right timing chain tensioner arm on the dowel pin and install the timing chain tensioner and bolts. Tighten bolts to 18 ft-lbs (25 Nm).
  17. Remove the retaining clips from the right and left timing chain tensioners.
  18. Verify alignment of all timing marks.
  19. Install crankshaft sensor ring on crankshaft.
  20. Locate index mark on balance shaft and mark corresponding gear tooth with chalk.
  21. Position balance shaft on journals. NOTE: It may be helpful to use an inspection mirror to view the marks timing marks.
  22. Align the chalk mark on the balance shaft with the camshaft timing mark.
  23. Install the balance shaft bearing caps in their original locations. Follow the tightening sequence as shown in the illustration. Tighten bolts to 89 in-lbs (10 Nm).
  24. Tighten the camshaft phaser sprocket bolts in the correct sequence using 2 steps, as follows:
    • Step 1-30 ft-lbs (40 Nm)
    • Step 2-tighten an additional 90 degrees
  25. Position the crankshaft keyway in the 11 o'clock position.
  26. Lubricate and install all camshaft roller followers. WARNING
    Engine front cover replacement procedure must be completed within 4 minutes or entire procedure must be repeated. Failure to do so may result in future leaks
Oct 07, 2010 | Ford F-250 Cars & Trucks
Briggs and Stratton 6.5 hp 120000 series mover engine. How do I set the valve timing gear ?
The crankshaft should have a marked "tooth" either with a "dot" or a "-"mark, the camshaft will also have a corresponding dot or dash. By rotating the crankshaft, align the marks on the crankshaft & the camshaft so that they are directly opposite each other. Drop the camshaft into place and the engine is now "timed"--if the marks are not exactly opposite one another, lift the camshaft (just enough to disengage the gear teeth) and try again, being "one tooth" out can make a huge difference--so take your time and make sure the "marks" are directly opposite each other.
Aug 08, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I am planning to replace the timing belt on my daughter's 95 Corolla and was wondering what I need to align where before removing the belt eg How do I find TDC? Camshaft pulley and Crankshaft pulley...
TDC is top dead center/ remove spark plug on cylinder no. 1/ rotate the crankshaft pulley using a socket wrench and power handle and check if the piston on your cylinder no. 1 reach the top center that is TDC/ remove timing belt cover and locate a synchronized marking on your camshaft and crankshaft pulley/ remove old timing belt/ install a new one but make sure that the mark on your camshaft and crankshaft is perfectly synchronized before putting the cover/ manually rotate the crankshaft pulley again and see if it rotates 360 deg. freely then you can be sure you did the job correctly.
Apr 06, 2010 | 1995 Toyota Corolla
Timing belt timing marks, 1997 ford escort where are they?
Ford Escort/Tracer 1991-1999 Repair Guide
REMOVAL & INSTALLATION 1.8L Engine
(see Figures 1, 2, 3 and 4)
  1. Disconnect the negative battery cable.
  2. Remove the timing belt covers.
  3. Rotate the crankshaft and align the timing marks located on the camshaft pulleys and the seal plate.
  4. Remove the crankshaft pulley and hub.
  5. If the timing belt is to be reused, mark an arrow on the belt to indicate its rotational direction to enable correct re-installation.
  6. Loosen the timing belt tensioner lockbolt and remove the timing belt.
To install:
  1. Temporarily secure the timing belt tensioner in the far left position with the spring fully extended, then tighten the lockbolt.
  2. Make sure the timing marks on the timing belt pulley (crankshaft sprocket) and the engine block (oil pump housing) are aligned.
  3. Make sure the timing marks on the camshaft pulleys and the seal plate are aligned.
  4. Install the timing belt.
  5. Loosen the tensioner lockbolt. Using a suitable prying tool, position the timing belt tensioner so the timing belt is taut, then tighten the tensioner lockbolt.
  6. Turn the crankshaft two turns clockwise and align the timing belt pulley mark with the mark on the engine block.
Fig. 1: Timing marks are located on the camshaft pulleys as shown-1.8L engines
Fig. 2: Make sure that the crankshaft sprocket (timing belt pulley) and oil pump timing marks are aligned-1.8L engines
Fig. 3: Align the timing belt pulley mark with the tension set mark, at approximately the 10 o'clock position-1.8L engines
Fig. 4: Check the timing belt deflection at the location shown-1.8L engines
  1. Make sure the camshaft pulley marks are aligned with the seal plate marks.
If the timing marks are not aligned, remove the belt and repeat the procedure.
I hope help you with this; remember rated this help. Good luck.
Sep 11, 2009 | 1997 Ford Escort
Timing for tropper 6cly and 4 camshafts and 24 valves model 2000
Timing Belt
Removal
1. Disconnect battery ground cable.
2. Remove air cleaner assembly.
3. Remove radiator upper fan shroud from radiator.
4. Move drive belt tensioner to loose side using wrench
then remove drive belt.
850RW001
Legend
(1) Crankshaft Pulley
(2) Cooling Fan Pulley
(3) Tensioner
(4) Generator
(5) Air Conditioner Compressor
(6) Power Steering Oil Pump
(7) Drive Belt
5. Remove cooling fan assembly four nuts, then the
cooling fan assembly.
6. Remove cooling fan drive pulley assembly.
7. Remove idle pulley assembly.
8. Remove serpentine belt tensioner assembly.
9. Remove power steering pump assembly.
10.Remove crankshaft pulley assembly using
5–8840–0133–0 crankshaft holder, hold crankshaft
pulley remove center bolt, then the pulley.
11. Remove right side timing belt cover then left side
timing belt cover.
12. Remove lower timing belt cover
13. Remove pusher.
CAUTION: The pusher prevents air from entering
the oil chamber. Its rod must always be facing
upward.
014RW011
Legend
(1) Up Side
(2) Down Side
(3) Direction For Installation
(4) Locking Pin
14. Remove timing belt.
CAUTION:
1. Do not bend or twist the belt, otherwise its core
could be damaged. The belt should not be bent at
a radius less than 30 mm.
2. Do not allow oil or other chemical substances to
come in contact with the belt. They will shorten
the life.
3. Do not attempt to pry or stretch the belt with a
screw driver or any other tool during installation.
4. Store timing belt in a cool and dark place. Never
expose the belt direct sunlight or heat.
6A–30 ENGINE MECHANICAL
Installation
NOTE: For correct belt installation, the letter on the belt
must be able to be read as viewed from the front of the
vehicle.
014RY00042
Legend
(1) Crankshaft Timing Pulley
(2) RH Bank Camshaft Drive Gear Pulley
(3) Water Pump Pulley
(4) Idle Pulley
(5) LH Bank Camshaft Drive Gear Pulley
(6) Tension Pulley
014RY00043
Legend
(7) Alignment Mark on Oil Pump.
(8) Alignment Mark on Timing Belt
(9) Alignment Mark (notch) on Crankshaft Timing
Pulley.
(10) Alignment Mark (groove) on Crankshaft Timing
Pulley.
014RW006
Legend
(1) Timing Belt
(2) Engine Rotation Direction
(3) Cylinder Head Side
1. Install timing belt.
1. Align the mark (notch) of crankshaft timing pulley
(2) with mark on oil pump (1).
Align the mark (groove) on the crankshaft timing
pulley (3) with alignment mark (white dots line) on
the timing belt (4).
NOTE: When timing marks are aligned, No.2 piston will
be on Top Dead Center.
014RW003
Legend
(1) Alignment Mark on Oil Pump
(2) Groove on Crankshaft Timing Pulley
(3) Alignment Mark on Crankshaft Timing Pulley
(4) Alignment Mark on Timing Belt
ENGINE MECHANICAL 6A–31
2. Align the alignment mark on the RH bank
camshaft drive gear pulley (2) to the alignment
mark of the cylinder head cover RH (3).
3. Align the alignment mark (white line) on the timing
belt (1) with alignment mark on the RH bank
camshaft drive gear pulley (2) (on the left side as
viewed from the front of the vehicle) and put the
timing belt on the camshaft drive gear pulley.
Secure the belt with a double clip or equivalent
clip.
014RW00004
Legend
(1) Alignment Mark on Timing Belt (White line).
(2) Alignment Mark on Camshaft Drive Gear
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover RH.
4. Align the alignment mark on the LH bank
mark of the cylinder head cover LH (3).
5. Align the alignment mark (white line) on the timing
belt (1) with the alignment mark on the LH bank
camshaft drive gear pulley (2).
When aligning the timing marks, use a wrench to
turn the camshaft drive gear pulley, then set the
timing mark between timing belt and camshaft
drive gear pulley and put the timing belt on the
clip.
NOTE: It is recommended for easy installation that the
belt be secured with a double clip or equivalent clip after
it is installed the timing belt to each pulley.
014RW00005
Legend
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover LH.
6. Install crankshaft pulley temporarily and tighten
center bolt by hand (do not use a wrench).
Turn the crankshaft pulley clockwise to give some
belt slack between the crankshaft timing pulley
and the RH bank camshaft drive gear pulley.
2. Install pusher and tighten bolt to the specified torque.
Torque : 25 N·m (2.5 Kg·m/18 lb ft)
1. Install the pusher while pushing the tension pulley
to the belt.
2. Pull out pin from the pusher.
NOTE: When reusing the pusher, press the pusher with
approximately 100Kg to retract the rod, and insert a pin
(1.4 mm piano wire).
014RW011
Mar 18, 2009 | 2000 Isuzu Trooper
Need instructions to replace 1993 Toyota Camry Timing Belt
Hi Kmcarroll77
TIMING BELT REPLACEMENT - 2.2L -1993 Toyota Camry
Installation
9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence. See Fig. 6 . On MR2, tighten engine
Hope this helps, don't forget to rate.
Lazaruselite
Feb 25, 2009 | 1993 Toyota Camry V6
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
