Gateway nv76r laptop screen goes black after resolution change
  • 8 Answers
SOURCE: gateway laptop wont display my desktop -screen is black
Does backlight stay on, or does it look like the screen is turned off? If it looks like it is turned off, can you look extremely closely and see your desktop if held in good light?
Posted on Jan 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: Gateway laptop screen is black?
This could have several causes, including malware installed on your system, but is frequently the result of some kind of hardware driver conflict. Have you recently installed any new hardware or software to your system? If so, disconnect it and try again.
The black screen is an indication that the windows os is not booting onto the system. If you have the recovery console installed, or have the cds, you can run the recovery console to troubleshoot or repair your installation of windows. This procedure is different for xp or vista, so we need to know what os you're on, as well as any error messages you see when it fails to boot.
To begin with, try tapping F8 as it boots up and see it you can get into the OS options screen, then choose Last Known good configuration to boot windows.
Here's a great article to help you troubleshoot the situation, then let us know how it goes and what comes up..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
SOURCE: Gateway W323-UI1 Resolution
Try to upgrade the display driver from gateway.com
Posted on Jul 21, 2009
Geekman
  • 32281 Answers
SOURCE: power stays on but screen goes black on my Gateway
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Posted on Nov 22, 2009
  • 691 Answers
SOURCE: Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Posted on Jan 08, 2010
My gateway nv76r laptop will be working fine, then pops up a message saying "no bootable device"
When start up press, f10 or f12 to change the boot start up.
Take out any usb if any connected.
Oct 16, 2014 | Computers & Internet
Where is my wifi button located on the keyboard to turn it on? For gateway laptop NV76R Series.
Press F3 or if your want go to wifi sign ( icon ) on the right down ,left click and you can see you avaaliable conection
Jul 30, 2014 | Computers & Internet
Changing screen resolution
Please boot the computer on to Safemode and change the resolution. To do so,
1. Turn Off the computer
2. Keep on tapping "F8" key as soon as you hit the Power button
3. From the menu use arrows keys to select Safemode and hit enter.
Thanks!
Jan 28, 2014 | Gateway Computers & Internet
I changed my resolution on my dell gateway laptop and now all i get at normal start up is a black screen with windows vista 7 win 32
Boot up your laptop and immediately press the F8 and then select Safe Mode. Then open Control Panel - Display and change your screen resolution to what you had before.
Feb 17, 2013 | Computers & Internet
Gateway laptop stopped picking up signal from tv monitor. how do I fix problem?
maybe it change screen resolution! try press press auto adjust from the monitor!
Feb 02, 2013 | Gateway CX210X Notebook
Jan 08, 2010 | Gateway MT3705 Notebook
Jul 21, 2009 | Computers & Internet
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
Gateway Laptop
It sounds like you may be adjusting the monitor out of its usual range that its capable of displaying. Try a slightly lower resolution to see if it does the same thing. Also check device manager to make sure your video card is being detected properly. It should have the name of the video card listed but no ? or ! next to it. You can try updating the video driver by going to the Support page on the manufacturers website and entering your product model name/number or its serial number/service tag number.
You can try adjusting the screen size, but if it goes black leave it for about ~30 seconds. Windows pops up a box when you change the resolution to make sure it's working OK or else it automatically changes the resolution back in about 30 seconds.
Jun 22, 2008 | Computers & Internet
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
