Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Hoover cyclonic uh70040w brush roll will not cycle on; belt seems oko
Brush roll will not turn or hesitates for a long time before slowly moving
reddevil6
  • 1673 Answers
SOURCE: Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Posted on Sep 18, 2008
SOURCE: hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Posted on Aug 30, 2009
SOURCE: Re UH70040W seriesZF12.0.I can't seem to get the
I followed the instructions,you have to release the handle as though you were vacuuming and it works automaticly you can't put it on ON when it's upright!! Duh
Posted on Oct 30, 2009
SOURCE: My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Posted on Dec 29, 2009
SOURCE: Repalcement of belt on Hoover F7425-900 Steam Cleaner
To help out here the hood has 6 screws on the underside of the machine and 2 post snaps at the rear of the hood. They pop out when lifting the rear of the hood. The air motor is as described above, 2 on bottom and 2 on top. When removed the air motor again has 2 screws on the cover of the gear set and a couple clips which come loose readily when the screws are removed. This exposes the gear set. Remove the gears and free the air motor shaft. Clean, lubricate and reassemble. You should be good to go. The Air motor is the only weak link in the machine. The bearings seize due to exposure as moist air is pulled through the air motor to drive the gear set. Great idea! Hoover should have used a stainless drive gear and bearings or a plastic bearing that would hold up to the RPM of the motor. Regardless, as is it will be plagued with the problem for the life of the machine unless you upgrade. Hoover may have solved this for all I know. Hint: The motor will not create any torque until the suction tank is in place. Oh, and keep the screen clean. That is the motor intake.
Posted on Jan 27, 2010
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
Is there suposse to be two belts on this vacuum
yes there are two belts this link below is the manual will give you full instructions on page 11/12.
http://hoover.com/file/640/
Feb 27, 2014 | Hoover UH70040W Bagless Upright Cyclonic...
My brush stopped spinning, but instead makes a loud plastic grinding noise.
Both ends of the brush roll should spin freely. You need to replace the brush roll.
Jan 21, 2014 | Hoover SH40060: Multi-Cyclonic Canister
My Hoover makes louder noise when the brushroll is on. I just cleaned but no result.
What kind of Hoover is this? There are a few things that will cause excessive noise and vibration such as a worn belt, the wrong belt, damaged end caps, damaged brush roll housing and worn bearings. Inspect the brush roll area. Remove the belt, if you have a spare, check the size. If it's more than 6 months old, replace the belt. Spin the brush roll in the housing, does it spin free or hesitate or not turn at all? If it spins with effort there could be debris under the end caps; if one end cap will not turn there is enough debris to cause the end cap to internally melt to the roller. If you cannot turn the brush roll by hand, replacement is your best solution. You should also inspect the housing where the roller spins, specifically where the end caps sit; look for damage to the slots in the plastic, it the roller will not sit snug this could cause enough vibration to make the sound you're hearing.
Sep 20, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Hoover UH70040W Wind tunnell mach cyclonic has stopped sucking up debris. At the brushes you feel no suction and when you disconnect the tube on the side it has some suction but not much at all. The...
Well if the vac motor is good then its either a clog or a leak ,if you say no clog then it has to be a leak. Make it blow out and see where the air is coming out or try and find it while it is running with a piece of typing paper loosly around the hose and piping. Seals at the connection areas go bad so check them as well.
Mar 31, 2011 | Hoover UH70040W Bagless Upright Cyclonic...
The brush does not move when turned on. The model number is UH70015. The belt appears loose.
There are two belts on this machine. The belt on the brush roller will appear loose when in upright locked position. Releasing the handle to an in use position releases a spring loaded idler pulley which increases tension on the brush roll driving belt. Check whether pwr on/off button flashes when attempting to turn on. This may indicate an obstruction or faulty sensor.
Feb 22, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
The roll brush will not turn when on floor. Too much pressure stops brush. Changed belts and still not working
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Jan 22, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Replacing a hoover windtunnel vacuum belt U8147-900
This has no belts, there are 4 small brush rolls, if the ends are bad and not turning then you will need to replace them. The newer ones have metal instead of plastic so are better. Should be able to buy the brush rolls at a local shop or from http://vacuumsuperstore.com/U8120.html
Jun 11, 2008 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Oct 23, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
