Question about Dishwashers
Samsung dishwasher model DMT610. It has a error code oE which is Over level water error. What does that mean and how do I fix it?
  • 3230 Answers
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
  • 3230 Answers
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
Krazytech
  • 725 Answers
SOURCE: LG dishwasher with error code OE
Drain Error OE
Not fully drained out in spite of 5 min. drain operation
The Drain Hose kinked or blocked. Wiring connection is OK? The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled.
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Posted on Sep 27, 2009
SOURCE: how to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
Posted on Apr 18, 2010
  • 500 Answers
SOURCE: getting an error code OE
Hi Ged Lunny,
The OE error code means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
Posted on Jun 09, 2011
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
    I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • 4E/4E1
  • 5E
  • oE/9E
  • LE
  • 6E2/PE
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
    The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
    LG themselves have some information on this error code..
    http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
    Dishwashers Logo
    132 people viewed this question
    Top Dishwashers Experts
