Question about Polaroid Televison & Video
Polaroid tdac-02212 22 inch DVD combo powers up then welcome screen comes on then no video or audio and black screen. If TV is unplugged for a week or two it start working again for a while started after a power outage
SOURCE: POLAROID FLAT PANEL TV PICTURES JUST GOES!!!!!!!!!
Its under warranty
Posted on Jan 24, 2009
dsacco86
  • 1077 Answers
SOURCE: Vizio Plasma 42HDTV - Power, No Video
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. If by chance the TV is still under warranty, go that route.
2. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 09, 2009
RNS-Systems
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
  • 8457 Answers
SOURCE: dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Posted on Dec 05, 2009
  • 20 Answers
SOURCE: Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
Posted on Jun 03, 2010
It missing the fitting on back to attach coax cables to
Missing it or does not have one? Either way you can fix the missing connector that just popped through the casing If it never had one then it has what is called a composite input. That will be the yellow colored RCA input. There should be a red and white next to it for red and white audio. Now, if you have a coax cable with an Fconnector ont it (screw in type) you can go to a radio shack or a home improvement store and get an F to RCA adaptor to make your cable fit in the back of the tv.
Feb 03, 2016 | Polaroid 19 Class 720p 60hz Lcd Hdtv/dvd...
We have a 22" Polaroid flat screen combo TV model #TDAC-02212 and the remote IERC03 does not work. Can I get another remote - the TV works with the built-in controls.
Dear Colleen,
Yes You Can, Try Typing "TDAC-02212 Remote" In The Amazon Search Engine. About $40 To $45 Bucks. It Should Come With A Manual On How To Program It To Your TV.
Sep 16, 2014 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Missing part
I thought the same with mine but the little square part you looking for is in a piece of the styrofoam
Dec 29, 2012 | Polaroid 22 Class 720p 60hz LCD HDTV/DVD...
Wrong region
You maybe able to get a region free code from one of these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Dec 25, 2012 | Polaroid 22 Class 720p 60hz LCD HDTV/DVD...
Dvd say disk error on all my dvd
Either the dvd drive's laser readers lens is dirty or its faulty and would need to be replaced. sometimes the issue can be the powersupply, but in most cases the drive is the issue.
Aug 11, 2012 | Polaroid TDAC-03212B - TDAC-03212B 32...
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
Jul 06, 2011 | Polaroid TLX-01911C LCD TV
Televison & Video Logo
47 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
