Question about Audiovox MMD11A Car Video Player
Reset button audiovox mmd11a
Where is button?
How do I deactivate my aps57c mobile audiovox alarm
  • Locate the push-button LED switch on the alarm box under the driver's side dash. The small red or black button is used to manually disable the alarm.
  • Put the key in the ignition and turn it to the "on" position. This activates your vehicle's battery, but doesn't start the engine. Press and hold the push-button LED until the LED light stops blinking. Once the LED stops blinking the alarm is disabled until you manually reset the alarm.
  • Start the car. Then, press and release the push-button LED switch once, to reset the alarm.
Apr 01, 2017 | Audiovox Vehicle Parts & Accessories
How to reset audiovox remote starter
REPROGRAM REMOTES BY FINDING THE VALET SWITCH AND
TURN KEY TO ON
PRESS VALET SWITCH 3 TIMES
PRESS BUTTON ON REMOTE
PARKING LIGHTS WILL BLINK ONCE TO CONFIRM
TURN KEY OFF
DONT LET MORE THEN 5 SEC PASS BETWEEN STEPS
Oct 18, 2009 | Car APS921 Remote Starter - Keyless Entry
My audiovox remote will not turn on tv or change channels - I put in new batteries. I pressed the TV function button to reset but is does not reset to use the tv or dvd
Try put again the batteries.A very simply and efficiently mode to see the remote control is work or not to tested of pressed taste next on radio posted on FM or MW.
Aug 21, 2009 | Audiovox Televison & Video
Screen got really hot and now it won't play DVD's
I was going to see if you DVD player has a reset button on it but it isn't popping up on Audiovox website.
If you open up the player see if there is a reset button on it. Hold it down for about 5 seconds and see if that works.
Unplug power from the unit and remove the battery as well. Put them back in.
Try a different DVD in case its warped or damaged.
If those don't resolve the issue you should take it in and have someone look at it.
Jun 17, 2008 | Audiovox DT102A
How do you hard reset audiovox ppc-6700
Press the two - buttons on either side of the windows and ok buttons while at the same time take the stylus and poke it in the hole at the bottom of the phone on the left of the usb jack.
Jun 01, 2008 | Audiovox PPC 6700
Audiovox PPC 6700
No when you hard reset the phone by pressing the reset button while holding the Soft keys it will keep the Program Codes. This will delete all info on phone.
Apr 15, 2008 | Audiovox PPC 6700
Fatal error, unable to open application database
Have you tried the reset button? It would be found on the lower right side on the rear panel. Don't really know if this will fix your particular problem, but it might be worth a shot.
Dec 13, 2007 | Audiovox NVX226 GPS Receiver
Audiovox MMD11A Car Video Player Logo
19 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
