Question about Canon PowerShot SX50 HS Digital Camera"
Lens barrel cover falls off - Canon PowerShot SX50 HS Digital Camera"
Lens will not retract not batteries
Hello
You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
hope it helps, if not take camera to the technician, if so
DO RATE THE SOLUTION
Good Luck
Jan 21, 2011 | Kodak EasyShare Z712 Digital Camera
Lens error on vivitar x327 , lens wont go in
Hello
Good Luck
Jan 10, 2011 | Vivitar ViviCam X327 Digital Camera
My lens is stuck half way out of the camera, when i try to turn it on it says there is a lens error. i have tried all of the suggestions, what else could it be?
Hello
Good Luck
Jan 06, 2011 | Nikon COOLPIX S610 Digital Camera
CAMERA LENSE WILL NOT RETRACT.
Hello
Good Luck
Jan 02, 2011 | Canon IXUS 80 IS Digital Camera
The lens on my canon powershot A480 will not retract, I have tried to restart the camera but this does not work, I have a 'lens error' restart camera' message but this does not help
Hello
Good Luck
Jan 01, 2011 | Canon Powershot A480 - Silver Digital...
When u turn on camara it says lens error and shuts off and the lens wont go in
Hello
if so DO RATE THE SOLUTION
Good Luck
Dec 24, 2010 | Sanyo Vpc-s1070w Digital Camera
Cannot close lens
Hello
Good Luck
Dec 22, 2010 | Kodak Easyshare C813 Digital Camera
The lens cover does not open or close completely. just started happening. the camera is 2 years old and the battery is fully charged
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 26, 2009 | Cameras
Lens protective cover won't close after I dropped it.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 30, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
'Please turn camera off and then on again'
The barrel is defect inside,dit it fall on the lens? A new barrel will cost about 175 euro.
Jun 07, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon PowerShot SX50 HS Digital Camera" Logo
16 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
