Connecting a dlink dir 615 router to zyxel p-660hn-t1a internet access
jkhtkd
  • 4 Answers
SOURCE: DLink DIR-615 can forward ports
You probably have a 3rd part firewall software on the PC, configure that firewall to allow the same ports. what AntiVirus do you have?
Posted on Jan 29, 2009
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
  • 10 Answers
SOURCE: sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Posted on Sep 13, 2009
Testimonial: "tanks v. much for answer, i'll try it right away"
  • 91 Answers
SOURCE: I can access internet direct. But no internet Model dir 615
  1. Turn off everything.
  2. Turn on your cable/dsl modem and let it finish it's self test.
  3. Using a cable, connect to the router to your laptop
  4. Turn on your router and let it finish it's self test.
  5. Turn on yor PC and let it finish it's boot process
  6. Configure the router as directed in the manual (defaults should work)
  7. Turn off the router
  8. Connect the router to the cable/DSL modem
  9. Turn on the router
  10. Reboot your PC
Posted on Jan 02, 2010
Zyxel P 660HN T1A as a wifi router to be connected to a modem
Website says its 802.11n Wireless ADSL2+ 4-port Gateway, so yes.
May 27, 2013 | Computers & Internet
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
How can i change the admin name and password of my ZYXEL P-660HN-T1A
ZyXEL P-660HN-T1A
how to change the passwoord of admin-1234 account everyone who know this may access na iformation ng wifi although limited access but still makikita pa din and ma eedit uhg wifi pass
Nov 06, 2012 | Computers & Internet
My instruction manual is in Chinese, i am using a mac and i cannot connect wirelessly to the internet, I have a DIR-605 router.
well here is a link to obtain the manual http://www.dlink.com/products/?pid=DIR-615
you need to select Support Resources Tab and choose the revision type you have. then you select product manual. One example is this one "DIR-615 no rev. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | D-Link DIR-615 Wireless Router
How do I connect a Dlink wireless router to a Netgear WiFi Internet adaptor?
Hi there is two way to connect best is to connect via cable ,DIR 615 login to router setting by typing 192.168.0.1 enter user name and password uaser name will be admin and password could be admin or blank or you need to enter text " read the manual to access the router via internet explorer" make sure WAN connection is DHCP connect LAN cable from your main router to the WAN port of your Dlink it should be ready in 1 miutes also if it support WDS you do not cable it can find the main router signal and connect to it and boost it , should you need any help please post me your question to http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-615 Wireless Router
I have followed instructions (several times) to connect my dlink router dir-615 and once I unplug the ethernet cable and attach to dlink (blue slot 1) and plug in power to the router....it no longer can...
the blue socket should be connected to your modem, it is this modem that supplies the internet for your router to distribute to your computers so if you disconnect the blue cable from your router you are disconnecting the internet
Apr 17, 2011 | D-Link DIR-615 Wireless Router
Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
May 19, 2010 | D-Link DIR-615 Wireless Router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
