Question about Poulan Pro " Pro" Self Propelled Mower
Wont start smells flooded on the 675 - Poulan Pro " Pro" Self Propelled Mower
How to fix lawnmower
what wrong with it if it wont start check for spark at plug if works try squrting starter flood into carb if tries to start rebuild carberator tecuseh engines are bad about clogged up carb with dirt
Aug 16, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Flooded wont start
Sounds like you aint getting no spark, spark plugs or cap is what I would check.
Sep 22, 2017 | 1999 Chevrolet Tahoe
After hot engine wont start and smells like gas
Most likely causes are bad engine coolant temp sensor OR leaking fuel injectors. Bad engine coolant temp sensor will give computer false reading and computer provides wrong air fuel mixture. Leaking fuel injectors will load the engine with raw gas--just like flooding it. Try pushing the gas pedal to the floor and holding it there when cranking when hot. That forces the computer into "clear flood" mode and it shuts off the injectors. If it starts up with pedal down, that would be a sign of leaking injectors.
Jul 21, 2017 | 1999 Dodge Intrepid
Flooding starting
Check fuel pressure. You may have a bad fuel pressure regulator. Pressure may be too high, or the regulator diaphragm may have failed-if it is vacuum operated, pull off the vacuum line-if any evidence of gas in the line, the regulator has failed, and letting gas get sucked into the engine through the vacuum line. That could explain the gas smell and the flooding.
Dec 26, 2013 | Land Rover Discovery Cars & Trucks
Ford Focus SE 2002 wont start, no smell of it flooding?
If it was the fuel pump it wouldnt move at all but you can test the pressure on the fuel rail on top of the motor. Have you changed the fuel filter?
Feb 12, 2013 | 2002 Ford Focus
Got stuck in snow storm left over night and engine compartment filled with snow tryed starting didnt start towed to heated garage for night and still wont start it smells like fuel in air box might be...
It probably is flooded from trying to start it.Originally the the air tube probably was packed with snow so the engine wasn't drawing air in. If you turn the key on and push the gas pedal to the floor this should activate what is called clear flood mode.If it will not still start would suggest removing all the sparkplugs and cleaning or replacing them also make sure that the air induction tube is clear and dry.
Mar 13, 2011 | Dodge Journey Cars & Trucks
Wont start 1996 jeep grand cherokee laredo inline six4.0 fuel inj
The first thing I would do since you think it was flooded is to replace the sparkplugs, sometimes if a spark plug has been washed out with gas you cannot get it completely dried out. After you replace sparkplugs try to start the engine. If the engine starts I would still recommend that you change your oil because of fuel saturation. If your engine fails to start I would suspect that you have a bad crankshaft position sensor as it is known to give problems. The crankshaft position sensor is located on the top of the transmission bell housing on the drivers side.
Oct 02, 2009 | 1996 Jeep Grand Cherokee
1995 nissan pulsar wont run properly
What your smelling fuel for is the fact that once you start it your flooding the **** out of it.. your fuel relese valve needs to be closed up a bit, your intake for fuel is to high basically, this can and will happen due to racing, vibration, or just over time. Its one of those problems that occurs now and then, it is a simple fix!!
Jan 06, 2009 | Nissan Pulsar Cars & Trucks
Poulan Pro " Pro" Self Propelled Mower Logo
23 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
