The pop up flash has stopped firing on my 18 month old D50. The flash metering is still reading ok but the bulb is not going off. I suspected the bulb had gone but Nikon's service department stated the flash PCB needed replacing - at some expense. I had the camera returned un-fixed and the D50 is still controlling an external mounted flash gun. I'm not sure how Nikon did its diagnostics but, in lieu of investigating a mis-diagnosed repair job, does anyone know whether I can replace the pop-up flash bulb at home / DIY?
I had the same issue. The flash is set to go off, the camera assumes it went off, (as the record metadata shows) but it doen't go off at all, and the piture is underexposed.
I bought the 100 page repair manual, which is ONLY a dissassemble/reassemble manual with NO diagnostics. (Got it on ebay) So I was atleast able to get to the capacitor and flash bulb. I saw 300V across the capacitor leads, and the same 300Volts across the flash bulb leads. SO I am assuming that there is a transistor or relay that drops to ground to fire the flash that isn't working, or the electronic signal to drive that isn't working.
It seems most people replace the entire flash circuit board(which is near the capacitor under the left hand side). But it seems Nikon only sells parts to it certified repair facilities.
Ugh.... Looks like I'm buying a SB-600, as this is the cheepest solution. Too bad, because the on-board flash is more than decent. I hope the SB-600 thrills me enough to change my mood. :)
Posted on Oct 07, 2008
I just read a few forums about this, and apparently it is a common problem on D50s. The flash pops up with such force that eventually the wiring and/or bracket that pops it up comes loose or breaks, and the camera needs to go in for repair. It probably isn't the bulb.
I'm looking into getting a D80 or better anyway once I have some money saved up, but until then I am using my SB-600. I'd suggest taking it to a repair center if it's still under warranty. If not it will run you around $150-160 to get it fixed, and takes about a month, according to what I read.
Hope this helps!
Posted on Oct 14, 2007
Nov 03, 2010 | Canon PowerShot SD1100 IS Digital Camera
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
May 20, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Dec 31, 2009 | Cameras
Oct 23, 2009 | Nikon Speedlight SB-600 TTL Flash
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Sep 27, 2008 | Nikon D50 Digital Camera
Aug 03, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Feb 08, 2008 | Nikon D50 Digital Camera
Sep 25, 2006 | Nikon D50 Digital Camera with 18-55mm Lens
Mar 06, 2014 | Nikon D50 Digital Camera
Mar 30, 2013 | Nikon D50 Digital Camera
2,256 people viewed this question
I have exactly the same problem with my nikon d50. The flash pops up, but there is no light coming from it.
I have the nikon D 50 and my pop up flash is very dull compared to when i bought it. I was looking around for a replacement bulb but no luck. All the stores said i would have to send it in for repair and it would be around $200-$250 and would take 6-8 weeks. Is there a better way?
Man, that sucks. My mother just gave me her "hand me down" D50 and the flash never worked. Maybe I can get her to foot the bill for a new flash or an aftermarket flash. This sucks!!!!
Ok so it seems that everyone on here has the same problem with their Nikon D50. My husband bought it for me for xmas 2007 and I had used it alot all through 2008 just fine. Until.... xmas morning 2008 it just stopped working. Talk about bad timing! And my sister in law just gave birth to a beautiful baby girl, and now I don't have a camera! It's the same problem, it takes pictures, but no flash. I used to be a manager of Ritz camera, and we sent out for repairs all the time. Some results were good, and well lets just say some customers were not happy after waiting 1-3 months! So basically i'm stuck with trying to have it fixed. I am going to call Nikon and reference this website about this problem to see how far I can get. I will let you all know what kind of news I get. You are all very helpful. Thank you.
Secret Service dropped my d60 flash acts like its going off, won't though... I should send a letter to Obama right?
Secret Service dropped my d60 and the flash hasn't worked since. I figure the blub broke I should send a Letter to Obama right?
