Question about HP Office Equipment & Supplies
Error code 0x61000000b Printer failure - HP Office Equipment & Supplies
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
Reason of occurring this error message is listed below:
  • HP printer setup may not be installed properly.
  • Printer cartridges low message.
  • Printer cartridge is damage or not inserted properly.
How to Solve "0xc19a0013" Error Code for HP Printer
  • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
  • Make sure the printer cartridge is installed or inserted correctly
  • Remove the printer cartridge and reinstall that.
  • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
  • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
1 800 436 0509 HP Printer Technical Support Phone Number
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
Ink system failure, failure code Oxc19a0035, if i turn it off and back on it will work for a day then the code comes back up.
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
Solution
Wait two minutes.
Dec 03, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
114 people viewed this question
Seeker5211
Seeker5211
