Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JD 3320 error code 06
Long delay on shuttle
2 Suggested Answers
  • 146 Answers
SOURCE: JD 3320 tractor with error code 57
From what I can find, that is a 'timeout' error indicating the expected signals from the hydrostatic transmission are not being received. That would suggest that some of the wiring is still not repaired. Could it be the nice doggie pulled out a connector partially and you didn't notice? Make sure all connectors are firmly seated.
Some have seen this error code occur for the simple reason that the battery voltage was borderline low -- those computers are sensitive. So before you take it to the dealer, put the battery on a charger overnight to see if that resolves it.
Hope this helps. If so, please rate my solutions, thanks and good luck!
Posted on Jun 09, 2010
John deere 3320 error code 63
You just go to the link I attached I'm sure you will get the solution of your problem.
John deere 3320
May 29, 2017 | John Deere Garden
John Deere 3320 error codes
John deere 3320
Error code 68 on a 3320 john deere
a code 68 0nthe dash display means the relay that supplies power to the engine controls has Not cycled correctly, most all the new stuff in the first two seconds of turning the key tests more stuff than a human could dream of , this is one of them , seems the computer turns on/off this relay so fast its looking for it to cycle ,before it turns it back on to start the engine , Jd calls it a "Hold In " relay , this problem is gonna require a Jd scan tool to figure out whats wrong , but do try and remove the relay and give it a few taps on your palm to see if anything s loose inside of it , silly as it sounds but relays do stick , but I feel this ones electrical
this fault should lock out the starter the book says
Feb 16, 2015 | John Deere Garden
Jun 09, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 3320 dash lights flash, no start.
sounds like you are all too familiar with battery terminal isues but I think you're on the right track sounds like a cooked solenoid left side of the tractor if memory serves the JD part is good quality but I,ve replaced a few with a standard automotive one and had no problems a little cheaper too ...Ok alot cheaper Good Luck
Oct 12, 2009 | Garden
My 3320 john deere jerks and also shuts off the
You can call a local John Deere distributer. Talk with the parts department and tell them the error code you are getting. Give them your serial number and model number and they can tell you exactly what the error code means. This will allow you to run a search for the error itself and find a part replacement or fix for the error code.
Oct 10, 2009 | Garden
Ir 3320 error code e602-0001
I not familiar with the model of copier but the error is a Standard Canon Hard Disk Drive failure that will have to be dealt with by a technician. He will have to reformat and install new system software or go as far as having to replace the HDD.
Nov 19, 2008 | Canon imageRUNNER 2200
Canon 3320 Error message
you also have to high lite service mode and clear that or the error will return
May 15, 2008 | Canon ImageRunner 3320N Copier
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
37 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
