Question about Samsung RF261BEAESR
Ice maker not working
Tryed the reset button and nothing happened
TJBENGR
  • 121 Answers
SOURCE: Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Posted on Apr 21, 2008
22yooper
  • 828 Answers
SOURCE: Samsung Side by Side RS2544SL Freezer will not fill tray with water
Your problem may be in the water supply. Where the water connects to the back of the unit there is an electric valve, not a pump. The electric valve inlet orifice may be restricted, Shut off water supply and clean or replace the electric solenoid valve.
Posted on May 06, 2008
  • 3 Answers
SOURCE: Ice maker is not working
make sure you remove the ice bucket when you press the reset button. if the ice level arm gets stuck it will not rotate. also if the rotating spindle at the back is jammed nothing will move.
Posted on Sep 10, 2008
  • 3 Answers
SOURCE: Ice Maker quit making ice cubes
Look on the bottom of the rectangular motor housing for the ice maker. This is the white box that holds the front end of the ice tray. In the past, this was normally a small patch of black 'runner' that covered the switch and helped kkep moisture out.
If you cannot locate it by feel, try using a small mirror and a flashlight to help you locate it.
Posted on Jan 14, 2009
  • 1891 Answers
SOURCE: Ice maker quit working
go back to your sales people this is under warranty and it's propably a system problem . don't void warranty . // hold on i thought the sysem had failed . ice maker must be 15 deg or lower . to work ... close the drawer and give it 24 and see what it will do . but it is still under mfg warranty . **** ..
Posted on Jan 06, 2010
what was reset button for? is it something like defrost the unit when press. you said that it is already replaced then likely your problem is with the unit thermostat all ref unit has it and most likely to fail overtime, it is also possible that there is leak on the sealing doors which makes your ice melts faster when the motor stop pumping freon
Feb 28, 2014 | Refrigerators
Ice marker stopped making ice
There is a test button underneath of the motor side of the ice maker. Unplug your refrigerator for 5 minutes then push the test button on the ice maker if it doesn't move you need an ice maker if it does move and you still don't get any water the metal tube that supplies the water to the ice maker is frozen up and blocking water from coming into the mold.
Nov 07, 2013 | Samsung Refrigerators
Electrical hot smell from fan area, not has quit
Hello, electrical hot smell from the fan area means you have a burnt fan which inturn affected other parts of the ice maker. That is the reason why the ice maker fails to start up when you plug it.
You can only fix it by replacing the fan and probably other affected areas by troubleshooting it.
There is nothing like reset.
Take care
Jul 12, 2010 | Continental PortableCE-IM65151 Ice Maker...
Try and check the water valve for proper operation.
then check and see if there is a kind of ice blocking the fill tube to the ice maker.
there maybe a reset button on the ice maker that just might reset the unitif nothing else is wrong then you need to replace the ice maker. there might be a cover on the front of the ice maker that you can remove and youmight be able to advance the ice maker manuallyby using a screwdrive to turn the gear clockwise just until it starts to turn on it own and see what happens if you can advance it by hand
Feb 07, 2010 | GALAXY Microsystems 25.4 cu. ft....
Ice maker
replace micro switch above the ice maker lever in the dispensor housing
Jan 22, 2009 | Amana ARS2464B Side by Side Refrigerator
Aug 02, 2008 | Samsung RS2534 Side by Side Refrigerator
Apr 21, 2008 | Samsung RB215LASH
what happened you reset the computer (mother board) chances are you had a brief glitch in your power and it made the computer go hey wire
Dec 15, 2007 | Whirlpool ED5FHEXMQ Side by Side...
Samsung RF261BEAESR Logo
54 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
