Hotpoint wml 730
Machine wont start, just clicks at me like the door is opening but it doesnt
  • 146 Answers
SOURCE: door lock flashes
Your switch bracket or switch is either broken or you have no either to or from it. Check your switch first.
Posted on Dec 18, 2007
SOURCE: hotpoint aquarius washing machine
where is the filter for hotpoint aquarius wma54 washing machine
Posted on Sep 12, 2008
  • 200 Answers
SOURCE: Hotpoint ultima wt741 F11 fault code
HI
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
  • A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
  • If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
  • A faulty door interlock
  • The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank you
Posted on Dec 06, 2008
e-Guru
  • 3917 Answers
SOURCE: washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Posted on Nov 07, 2009
beltronic205
  • 1461 Answers
SOURCE: hotpoint aquarius wf101 washing machine wont start
fit new door interlock switch not too expesive parts about £15
Posted on Apr 07, 2010
Hotpoint wml 730
Sounds like it could be an unlevel washer. That is one thing to check.
Make sure the filter is clean. The filter is located behind the kick panel and will be a screw in filter. You will need a shallow bowl or pan to catch the excess water. Clean the entrance for the filter is clean and free of dedri.Make sure to unplug your machine before this procedure.
There are other problems it could be but, lets try this and see if it helps.
Aug 27, 2014 | Washing Machines
How do i remove the drum from a Hotpoint Aquarius WML 560 P
There is not much you can do to remove the drum of your WML 560 P Washing Machine...you can remove the bearings and door but you can't remove the drum personally. You'll have to take it in for service but here is a manual for you which you can read through to see if there is anything about removing the drum. Click on the link below to be directed to your Hotpoint Aquarius WML 560 P User Manual homepage...
Hotpoint WML 560 Instructions For Use Manual
Aug 26, 2014 | Washing Machines
Hotpoint WML 730
Possible this seems to be an error. You need to start by check the inlet water flow, check the free flow, if not check the inlet valve or the valve drive. Also check the drain pump and see if there is no clogging, Now switch on and check voltage on the inlet valve, if absent check the main program controller. If water flows check
Nov 21, 2013 | Washing Machines
Hotpoint wml 730
use hotter water.
Sep 20, 2013 | Washing Machines
Hotpoint wml 450
Click this link for tips: door locked
Jan 19, 2013 | Washing Machines
I have no power to a Hotpoint Aquarius washer, Model WML 730. Is there a line fuse and if so where is it?
Chance is its the two pole off/on switch or door interlock , check switch first.....
Mar 03, 2011 | Washing Machines
I have a hotpoint wml 540 p/g/a/k and the cycle will not start. The machine allows me to turn it all on etc but when i press the start button the door does not click and the red key symbol flashes. There...
I have had this problem with mine. Turn off the machine at the mains (might be awkward if the switch is behind the machine!) wait a couple of mins and then turn back on again. It should now work!
Nov 16, 2010 | Hotpoint Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
