Question about Belling Kitchen Ranges
Belling M385TCS microwave replace bulb
Unable to locate where /how to replace bulb. Is access point on outside ? if so where and how to replace bulb?
2 Suggested Answers
SOURCE: Kitchenaid Microwave Bulb Replacement
I just replaced the bulb on my KEMS308GSS2 and it wasn't too difficult. The bulb was $36.45 delivered from A-1appliance.com.
To change the bulb first turn off the power, then remove the plastic grills above and below the microwave unit. The bottom grill comes out easily, but the upper grill has a flange which makes it difficult to reinstall unless the flange is sawed off or the control panel is partially removed. To remove the control panel open the lower oven door and remove the screw at the bottom of each trim piece. Remove the trim pieces and then the two screws securing the control panel. With the two grills removed take out the two screws below the microwave which hold it in place. carefully slide the microwave out about half way, remove the insulation pad over the bulb and replace the bulb.
Posted on Dec 10, 2008
How do i gain access to the bulb to replace it?
I assume you're talking about the light that is inside the microwave & not the cook top light. Unplug unit. Normally your microwave will have a plastic or metal panel on the top front or back of the unit. (The bulb is not always changed from the inside of the unit.) Simply remove the few screws that hold the panel on & remove it. This should give you simple access to the bad bulb. Replace bulb then reassemble. Some free standing units require the entire outside enclosure be removed.
Mar 01, 2016 | Microwave Ovens
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
GE JES1288SH03 Microwave browning oven (2006. How/where do I access to replace interior light bulb?
The lamp is located inside your microwave oven. The outside enclosure has to be removed to access it. Beware of dangerous voltages exposed when the cover is removed.
Feb 10, 2015 | GE Microwave Ovens
How to change light bulb in microwave
Ensure the microwave is un-plugged.
The procedure differs depending on the microwave.
Some microwaves will have a glass panel covering the bulb which can be unclipped or unscrewed from the inside of the oven or there may be an access panel on the outside. On other ovens the complete outer shell has to be removed to get at the bulb. Bulbs can normally be unscrewed but sometimes you need to push and twist anti-clockwise to remove.
When you have replaced the bulb, ensure that all panels and screws are replaced securely.
Sep 05, 2011 | Microwave Ovens
How do I replace light bulb
Do you mean you want to replace light bulb for your microwave? If yes follow the instructions below;
  1. PLEASE UNPLUG YOUR MICROWAVE!
  2. Picture of your microwave with a phone or camera so that you don't forget how to assemble it back.
  3. Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
  4. Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
  5. Locate a small access cavity on the left.
  6. Remove the screw that is located near the front of the microwave door.
  7. Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
  8. Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
  9. Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
  10. The bulb connection should come right out.
  11. After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
  12. Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
I hope this helps to solve your problem.
Good luck.
Apr 08, 2011 | Daewoo Microwave Ovens
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
I have a belling triplette 333 combination microwave/oven which i need to replace the bulb for. i do not have the manual and it seems that you cannot get to it without taking the whole machine appart. do...
TO CHANGE BULB ON BELLING TRIPLETTE 333
You must remove outer cover and bulb is located from the front on left hand side 15w bulb hope ttis helps
Bill
May 14, 2009 | Ovens
Light has stopped working in microwave
Do you have an owners manual, if not go to the manufacturers website and download one, or call and get one, it should have instructions on changing the bulb, I have changed bulbs in a variety of microwave type ovens, and not one was the same access, some you have to remove the side control panel face, others a top plastic case part, too many to list, you need to find out the manufacturer's directions and or study the unit, with enough looking you will find an access point, generally this is somewhat complex, a few screws minimum, next is to be careful in the disassembling of a microwave, if you are not sure where or what you are taking off, you can take off, parts that allow the microwave to leak, or become dangerous to be around, find the specific instructions, it will make life much easier for you.
Will
Nov 30, 2008 | Belling Microwave Ovens
Replacing interior light bulb in m/n 63694
On many recent models, it is necessary to remove the mircowave from the wall, then remove the cover to change the cavity bulb. They suggest that only an authoirzed servider replace them, in order to avoid liability. You can enter your actual, full model number (63694 is not enough) and get helpful exploded view drawings and order parts at http://www3.sears.com (the three is correct). Do not handle the bulbs with bare skin, it will shorten their lives. Use a clean dry cloth or gloves.
Apr 29, 2007 | Kenmore 63692 / 63694 / 63699 900 Watts...
Kitchen Ranges Logo
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
