Question about Magimix Kitchen Appliances - Others
Doesnt boil doesnt finish boiling
jerryg50
  • 1667 Answers
SOURCE: kettle lights but doesn't boil
Most likely the thermo fuse is blown.
You have to take the kettle apart and see the spec for the thermo fuse. You can get these at most any electronics parts supplier for appliances.
To change the thermo fuse you will need the proper crimp type connectors and the crimp tool. This is not able to be soldered. It runs too hot, and soldering in a circuit close to a heating element is not able to be used.
Before changing the thermo fuse, you can test it with an ohm meter. It should typicaly read about 0.1 to 0.2 ohms. The heating element resistance should typicaly read about 8 to 12 ohms.
If the heating element reads below 6 to 7 ohms on a well calibrated ohm meter, or above 15 ohms, it is defective.
If the thermo fuse is blown, the kettle may have been left running when boiled out and over heated, or there is a short in the heating element.
If you feel that you are not comfortable to do this type of repair, it would be best to give the kettle out to an appliance service centre to have it serviced.
When you change the thermo fuse, and if it blows again the heating element is probably damaged. It must be replaced if possible, or if worth the cost.
On the other hand, if the kettle is more than a few years old and you don't want to go to all this trouble, you may want to consider to simply get a new one.
Jerry G.
Posted on Apr 29, 2008
  • 389 Answers
SOURCE: kettle not switching off
To state the obvious, the steam sensor has failed. Unless you are quite adventurous, and confident dealing with electrics, there's nothing for it but to get a new kettle (unless the kettle is still within warranty, in which case you should be entitled to a replacement of course).
Posted on Oct 11, 2009
Obertelli
  • 3006 Answers
SOURCE: i have a kenwood sjm350 and it keeps stopping
Either the boil thermostat is faulty or the protective overheat cut-off is operating prematurely.
There is nothing you can do to fix either problem: it's a cheap kettle (no better or worse than average) and definitely not designed to be repaired. If the kettle is still under warranty you can get it repaired (in practice, Kenwood will usually just replace it). If the kettle is out of warranty then all you can do is to bin it and buy a replacement.
Note that if you're in the UK then you'll also have Sale of Goods Act protection; this means it's your right to demand that the retailer gives you a refund (full or partial, depending upon how long the product has lasted) or replacement as the goods have proven not to be of durable quality. The Act covers you for up to six years (five in Scotland), but allows for the fact that you can't expect a £32 kettle (current typical retail price) to last much more than perhaps a year to eighteen months. In reality, most UK retailers will try to insist you use the manufacturers warranty as it's usually more convenient for all concerned but you do have the legal right to insist that the retailer provides the remedy.
I hope that you've found my reply to be of use and in return I ask only that you return the favour by rating my answer.
Posted on Nov 05, 2009
Testimonial: "very quick response and accurate, although i would say that i don't consider it to be a cheap kettle, and bought what i thought was a good brand"
bayyagg
  • 1672 Answers
SOURCE: No longer boiling. Light
Ur thermal fuse just got BLOWN, if u have a knowledge to repalce it, u could buy the parts in any electronic shop. Just be sure u have the same temperature value!
Hope that helps u out!
Posted on Dec 03, 2010
homemender
  • 158 Answers
SOURCE: When filled with water & put on to boil it
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle.
Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Posted on Dec 23, 2010
Electric kettle switches on and off every 10 seconds and doesnt boil
Hello Tobi. Is it still under warranty?
If yes send it back (don't tell them about the milk thing!)
If not I sugest you bin it... You've knackered the thermostat me thinks... :-(
May 28, 2016 | Kitchen Appliances - Others
What is the boiling point or kelvin
The boiling point of what?
Water boils at 373.15 Kelvin.
Gold boils at 3243 Kelvin.
Apr 02, 2014 | Office Equipment & Supplies
Instruction manual is in french ,need it in english
Egg Genie cooks up to 7 eggs at once-with no guesswork, no underdone or overdone eggs.
Just add the indicated amount of water.
Press "on"and your work is done.
The Egg Genie automatically steams eggs and alerts you when they're ready.
Here are the amounts in teaspoons of water:
4 tsp = 6 soft boiled eggs
5 tsp = 5 soft boiled eggs
6 tsp = 3 soft boiled eggs
7 tsp = 1 soft or 7 med
8 tsp = 6 med boiled eggs
9 tsp = 5 med boiled eggs
10 tsp = 3 med boiled eggs
11 tsp = 2 med boiled eggs
12 tsp = 1 med boiled egg
14 tsp = 7 hard boiled eggs
15 tsp = 6 hard boiled eggs
17 tsp = 5 hard boiled eggs
18 tsp = 4 hard boiled eggs
20 tsp = 3 hard boiled eggs
21 tsp = 2 hard boiled eggs
23 tsp = 1 hard boiled egg
May 22, 2011 | Emson EggGenie Egg Genie Electric Egg...
I have misplaced my directions for my Egg Genie and would like a copy to print up.
Here you go! Put the water in the base of the unit.
  • 14 tsp = 7 hard boiled eggs
  • 15 tsp = 6 hard boiled eggs
  • 17 tsp = 5 hard boiled eggs
  • 18 tsp = 4 hard boiled eggs
  • 20 tsp = 3 hard boiled eggs
  • 21 tsp = 2 hard boiled eggs
  • 23 tsp = 1 hard boiled egg
12 tsp = 1/4 cup
Apr 01, 2011 | Computers & Internet
How much water and where do I put it
12 tsp = 1/4 cup
Mar 07, 2011 | Emson EggGenie Egg Genie Electric Egg...
Can you boil in a slow cooker?
Generally, with enough heat and good insulation, water will boil. Boiling is caused by non-uniform heating - some spots are hotter.
My wife's slow cooker boils even on the low setting -slowly, but it boils.
Our rice cooker never used to boil until I burned tomato rice in it (OOPs). Don't make tomato rice in a rice cooker.
Mar 21, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
Kettle doesn't turn off
Our first Smart Kettle was great and worked well for years, finally died so we bought another. Right from the first boil it seemed to boil for about 2 or 3 minutes before turning off and then either didn't boil or made beeping sounds when not being used so after a couple of weeks we returned it and it was replaced. Great. But now this new one seems to boil and boil before turning off so maybe they are just faulty now. Any suggestions?
Jul 04, 2009 | Breville "Ikon" Tea Kettle Electric Kettle
Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
Feb 20, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
MAchine Boils the water
if the temp sensor is operating ok but the element doesnt switch off there may be a problem with the power board/timer just follow the wires back to find problem.
Oct 18, 2007 | Hoover AL130 Front Load Washer
Kitchen Appliances - Others Logo
Top Magimix Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Magimix Kitchen Appliances - Other Expert? Answer questions, earn points and help others
