Question about Sony VPL-ES1 Multimedia Projector
Sony vpl-es1 is projecting a green tint
Everything that is projected has a green tint and the colour is not the same as displayed n the laptop
SOURCE: blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
Posted on Jun 28, 2007
Marrie
  • 563 Answers
SOURCE: purple and green and shaking....
Hi guys
You will have to replace the LCD's .
Must warn you that it is very expensive
Posted on Mar 26, 2008
SOURCE: SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Posted on Apr 10, 2008
  • 5 Answers
SOURCE: Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Posted on Aug 04, 2009
  • 5 Answers
SOURCE: Sony VPL-ES1 projector
no thats not the solution, various vpl projectors have that problem, the red light eventually turns on after a maximum of 4-5 days... very annoying and noone understands what crazy semiconductor (thats the one causing the problem) sony put it their devices... it costs about $30 (22 €) but i have no clue where and how to replace it, didnt look closer at it so far...
How to fix the big dark circle in the middle of the screen
I think you may be having a problem with the projection bulb.
Jun 09, 2014 | Sony VPL-ES1 Multimedia Projector
Green tint to sony kds-a2020
NOT ON THIS SET YOUR LIGHT ENGINE IS DEFECTIVE CALL sONY AND SEE IF IT IS ON THE EXTENDED WARRANTY LIST.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
I have a projector (SONY VPL-ES1) and the bulb stopped working. Took the bulb out, and not sure if it's blown or not. I checked online, to see if anyone else had similar problems, and sure enough they...
usually the projector powers and cools down. if you restart it it will open the cover, not projecting anything and after 10 seconds it will close again. this happens if the lamp is shortly before the end of the measured lifetime (no fixed hours) to protect the projector. usually if you take it out once or twice it will work for 1 or 2 more times but the bulb is very likely to explode (not destroying the projector but not good anyways)
Dec 30, 2008 | Sony VPL-ES1 Multimedia Projector
Blue Bleed
Hi there
Does this only happen once a signal is inserted ?
Does it happen on both PC & Video signals ?
Have you tried using a different cable yet ?
Apr 16, 2008 | Sony SuperLite ultracompact Project...
Sony KP%&HW40 with varying background tinting
YOU HAVE 6 ADJUSTMENT BEHIDE THE SPEAKER SCREEN. THERE ARE TWO SCREWS YOU NEED TO REMOVE. ADJUST JUST THE MIDDLE BOTTOM SLOWLY. IT SHOULD CLEAR YOUR PICTURE. IF IT DOES NOT WORK IT MAYBE YOUR GREEN CRT. THIS TV IS GARBAGE. IM TRYING TO GET 100 PEOPLE CALL SONY APRIL 17,2008 AND GTHEN SEND TGHEM A LETTER AND AFTER CONTACT YOU LOCAL MEDIA FOR THIS DEFECT. SONY HAS TO PAY YOU BACK OR REPLACE THIS TV.
Feb 23, 2008 | Sony KP-57HW40 57" Rear Projection...
My Sony VPL-X600 projector has a green tint over the whole picture
the problem you are having is the RED lcd has failed and needs to be replaced only sony can do this you must contact sony for the nearest service center for repair. unfortunatly that is the only solution.
Feb 10, 2008 | Televison & Video
Purple and green and shaking....
Hi guys
Dec 07, 2007 | Sony VPL CS1 Multimedia Projector
Greenish yellowish tint on the tv
I have been advised that the color/light engine of the TV fails often and will typically create a green tint on this unit. I have one on order to get a replacement installed. BTW, it is not "user serviceable" and (for me) will require moving the TV to the repair shop for the change-out.
Nov 11, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Blue tinting appearing on the right side of screen on vpl-es1 projector
May 13, 2007 | Sony VPL-ES1 Multimedia Projector
Sony VPL-ES1 Multimedia Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
