Question about Samsung SCX-3400 All-in-one Laser printer SAMSUNG
Orange light on the samsung printer indicate what?
The orange light under toner option indicate what?
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Posted on Jan 30, 2010
SOURCE: Hi have samsung ml 2240 printer top light is
its of Paper count problem. tourn of printer power and open the back cover and find the IC 366...... ita a small 8 pin ic just short Pin NO 1 And 4 just restart the printer ur problem has been resolaved
Posted on Jul 28, 2010
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
http://dell.to/1at80gm
Feb 24, 2017 | Dell Office Equipment & Supplies
Tip
Printer error (orange or blinking light)
<b>Printererror (orange or blinking light)</b> After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
on Mar 31, 2011 | Office Equipment & Supplies
Orange light mean
ERROR/PAPER JAM/TONER OR INK IS ALMOST FINISH
Nov 17, 2013 | Samsung ML-2851ND Laser Printer
Solid Orange Light
The "6 balls in a basket" is telling you that your either low on toner or completely out of toner. Good luck !
Feb 04, 2013 | HP LaserJet P2014 Printer
I have a brother 5250dn printer that's on strike right now. At first it wouldn't print indicating a drum problem. We addressed that issue by resetting the drum counter (took out the toner/drum and held...
Try this.... no guarantees but I have seen this work.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jan 19, 2011 | Brother HL 5250DN Laser Printer
Hp deskjet d1560 printer light flashing
After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.
Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Deskjet+D1560+Printer&product=3374275&tmp_qt=power+light+flashing&lc=en&dlc=en&cc=us
Aug 06, 2010 | HP D1560 Deskjet Printer InkJet
Flashing orange light far right... offline...having replaced toner
Flashing orange light, far right, indicates a paper jam. If you just replaced toner, check that the toner cartridge is installed properly.
Jan 06, 2010 | OKI B4250n Laser Printer
What does the flashing orange light mean on my 7300 as it wont print at all
The flashing light indicates a warning state - such as low toner - but it will not stop the printer working, so there must be more than one issue if it is not printing at all. A flashing orange will be accompanied by a message on the screen to indicate which item(s) is/are in a low state.
Sep 14, 2009 | Xerox Phaser 7300DN Laser Printer
I have a lexmark e250dn printer. Today the printer has stopped working. The help ! indicator on the printer is an orange color as well as the toner/and drum indicator is an orange color.The ready indicator...
Here is how to reset the photoconductor kit counter:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
May 25, 2008 | Lexmark Office Equipment & Supplies
Paper Jam?
add toner or image unit waste toner full check page count. check switch in duplex section same one for the fuser exit.
Apr 30, 2008 | Kyocera Mita FS-1030D Laser Printer
Samsung SCX-3400 All-in-one Laser printer SAMSUNG Logo
162 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
