Question about Microsoft Office Word 2003 for PC
Low speed hesitation 2003 ford taurus 3.0 dohc
Replaced coil fuel pressure ok cleaned mass air flow sensor new plugs and wires just at low speed during takeoff
  • 1,869 Answers
Replace the :thin film" ignition module also check the distributor magnetic reluctor for slip
Posted on Nov 18, 2013
Testimonial: "Thanks for the help however I am not familiar with these 2 parts. Could you help me with their locations and what they look like?"
Engen problem and missing
Sir, your question is not very clear, but I will still try to post a solution here. Engine missing could be due to any problem in fuel system, ignition system, engine or ECM as well.
LOW ENGINE IDLE SPEED (Poor idling):
-Throttle body (do the cleaning and idle speed learning)
-A /C signal circuit
-Fuel pump control circuit
-Fuel pump
-Intake system
-P C V valve (clogged or open) and hose
ROUGH IDLING:
-Cylinder Compression
-Ignition system (Igniters, spark plugs, wiring harness)
-Spark plug fouled, gap too wide or too short. (1.00-1.1 mm)
-Fuel injector circuit
-E C M power source circuit
-Fuel pump (required pressure 44 psi - 49 psi)
-Throttle body (cleaning)
-Intake system
-P C V valve and hose
-Air fuel ratio sensor
-Heated oxygen s ens or
-Mass air flow meter
-Idle hunting
-Throttle body
-Intake system
HESITATION/ POOR ACCELERATION:
-Fuel pump
-Spark plug
-Ignition system
-Throttle body (do cleaning)
-Intake system
-Valve timing
Jan 18, 2014 | 2008 Toyota Corolla
2003 ford taurus 3.0 dohc intermitant motor hesitation and stall
Check and clean mass air flow sensor according to directions on can. BE VERY CAREFUL< THIS SENSOR IS VERY DELICATE. Hope this helps.
Nov 10, 2013 | Cars & Trucks
2003 windstar stalls when driving, idles high in neutral, now 4 codes
ok so much done owell next is the mass air flow to be checked then the fuel regulator to check pressure and the fuel pump for pressure and then check the cat,s for back pressure wood be my next thing and Last is the how many Km,s does it Have ?sounds like filter needs lookin at in the tranny if she,s got High Km,s if not then check the intake for leaks it,s Plastic so don,t hurt gone this far Let me Know What Happens,s Thank,s
Apr 08, 2013 | 2003 Ford Windstar
2003 Grand Am Has P0102
It is not an ECM/PCM problem.
P0102 - Mass or Volume Air Flow Circuit Low Input
Possible causes- Faulty mass air flow sensor
- Dirty mass air flow sensor
- Dirty air filter
- Mass air flow sensor harness is open or shorted
- Mass air flow sensor electrical circuit poor connection
- Intake air leaks Tech notes Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor
Sep 27, 2012 | 2003 Pontiac Grand Am
2001 Taurus 24Valve DOHC that runs rough, no power off stand still
Wow, all of those parts, and did the mechanic check the fuel pump pressure ??
The a/c problem is another issue.
Jun 29, 2012 | 2001 Ford Taurus
2003 Ford Taurus, 81,000 miles. MPG down to 19-20. Car has no mechanical or electronic issues and runs great. Good brakes, no drag in chassis. New plugs, wires, Cam position sensor and air filter....
I would check for vacuum leaks. And clean the mass air flow sensor and the throttle body. (use break clean) spray the sensor and use a toothbrush on the throttle plate and as far as you can reach in it. I would also replace the air and fuel filters if you haven't done this with in a year.
Sep 03, 2011 | 2003 Ford Taurus
I need to clean/replace the mass air inflow sensor. How to?
In your vehicle, the Mass Airflow Sensor is attached to the air filter assembly.
Fig. The exposed -hot wire- of the MAF sensor
The MAF sensor uses a hot wire sensing element to measure the amount of air entering the engine. Air passing over the hot wire causes it to cool. This hot wire is maintained at 200°C (392°F) above the ambient temperature as measured by a constant cold wire. If the hot wire electronic sensing element must be replaced, then the entire assembly must be replaced. Replacing only the element may change the air flow calibration.
The current required to maintain the temperature of the hot wire is proportional to the mass air flow. The MAF sensor then outputs an analog voltage signal to the PCM proportional to the intake air mass. The PCM calculates the required fuel injector pulse width in order to provide the desired air/fuel ratio. This input is also used in determining transmission electronic pressure control (EPC), shift and torque converter clutch scheduling.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect the battery ground cable.
  3. Disconnect the MAF sensor electrical connector.
  4. Remove the two retaining screws and the MAF sensor.
  5. To install, reverse the removal procedure.
Fig. Mass Air Flow sensor
hope this help (remember rated and comment this help).
Mar 19, 2010 | 2003 Ford Taurus
2003ford taurus bucks at cruising speed 30 to50
Sounds like your mass air flow sensor....or your intake air temperature sensor. Have the vehicle DTC codes checked....Youo may not have a check engine light but a fault code could be stored in the ECM computer. Most auto parts stores will check it for free.
You can't beat free!!!
My car did the same thing with no check engine light and I changed the intake air temp sensor and it fix the problem right away.
Oct 13, 2009 | 2003 Ford Taurus
1996 Ford Taurus power hesitation
If you disconnected the Mass air flow sensor the car should have die out at idle. Check fuel pump pressure at the fuel rail should be 30 psi at idle. Low fuel pressure will cause your po 171, 172, problems which could cause the other to problems. You might be needing a fuel pump and filter.
Jun 24, 2009 | 1996 Ford Taurus
1999 Ford Taurus mechanical problem
your problem appears to be the idle control motor located on the air intake manifold it is a small motor that goes bad quite often. Other items that can cause this is a bad /clogged air filter or a tune up (spark plugs and wires), or clogged fuel injectors. to clean the injectors you can buy a container of fuel system cleaner and pour it into the gas tank and as you drive it cleans the system.
Once the fuel system is cleaned via a tankful of cleaner & gas then the idle controller motor would be next on the list to be replaced.
Good Luck !
Rich Lilja
Dec 03, 2008 | 1999 Ford Taurus
Microsoft Office Word 2003 for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
