Question about MicroBoards DVD-PRM-PRO-1016 10-Disc 16x DVD/48x CD Duplicator
Firmware update need firmware update
How do I physically update the firmware on my new
It usually requires you to download the new Firmware version from the supplier site (or any site where it may be hosted - follow this link for new version from Fuji New Firmware
Then you copy the firmware onto your memory card, insert it into the camera, select Firmware update and follow instructions from there.
Aug 28, 2013 | Cameras
I have a Ricoh 161 but after a firmware update erro (NIB) the machine tries to continue the update. How I cancel the firmware update or reset the firmware in the machine? ----------------- Eu tenho uma...
You can not stop a firmware update.
Did you turn the machine off while the firmware update? If you did that your NVram is broken
I think that the only chance you have is with a new NVram. Sorry but you will have to put a new NVram.
Jun 10, 2011 | Ricoh Aficio MP 161 Black and White Copier
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
Jun 05, 2011 | Computers & Internet
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
Is it normal that when you r updating the firmware of it,much of time is needed?..the MB is increasing while updating
Usually firmware update takes much time depending on the speed of the Internet connection which you have.
First nokia updater have to be downloaded and when you try updating your mobile firmware then the nokia updator downloads the necessary update files from internet which takes again some time. After the firmware download then actual firmware updation happens. This will take some minutes.
Please note that interruption in firmware update may make your mobile unusable. Then you have to make a service call if anything happens like that. so perform firmware update with a high speed Internet connection and have UPS for your system.
I hope this is helpful to you.
Thanks
Mar 07, 2010 | Nokia N97 mini Smartphone
I have a lg DVD-RAM Model no GH22NP20 its not run data cds & DVD-RAM.
need to check firmware version then update it
Here's how to get LG's Auto Firmware Updater
Go here :
http://www.lge.com/support/software.jsp
Select
> Location = North America > USA/ Canada
Then
> Product = DVD-ROM (writer)
> Operating System = Vista
> Subject = LG Auto Firmware Download
Download the .zip file to your Desktop
You'll need to "Extract All" from the .zip
and then run the setup file
You'll need to allow Internet Access ( AV/IS )
The Updater will probably need to Update itself - before being active
To Manually Search For Firmware Updates
> Subject = Firmware
Look through the Listings for your Specific Drive
I would recommend Disabling the LG Auto Firmware Updater
- from Windows Start-up
You can open the Updater at any time - from All Programs
Apr 26, 2009 | Computers & Internet
Firmware for e-studio 282
I need firmware becuas the machine in errer f 103 i chage the HDD
than HDD need the softwer Pleas Give me a free softwe side
Feb 05, 2009 | Toshiba e-Studio 350 Copier
Sansa e260 will not power up
Okay what you do for this is hold down the power button for 20-25 seconds or so. This will reset your Sansa e260 and then it will power up like normal. I have had this problem before. If that doesn't work then I don't know what will.
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
Pic and vidos
I believe all you need to do is go to SanDisk's website, under Downloads, then download the Firmware Updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
After installation of Sansa Firmware Updater
* Please make sure your Sansa player is in MSC mode before plugging it in.
* Plug in your Sansa player and it will automatically check for updates.
Common questions about the Sansa Updater
Q: What does the Sansa Firmware Updater do?
A: The Sansa Updater is an application that checks for the latest firmware updates then downloads and installs the firmware to your Sansa device. The Sansa Updater is NOT a firmware.
Q: Why do I need to install the Sansa Firmware Updater to download "firmwares"?
A: Once you install the Sansa Updater, you don't have to worry about which firmware to download for your device. Sansa Updater downloads and installs the right firmware for your Sansa device.
Q: Do I need to install the Sansa Firmware Updater everytime there's a new firmware?
A: No, once the Sansa Firmware Updater is installed, future firmware updates are done by just plugging in your device.
Q: What does a "firmware" do?
A: Firmwares contain miscelleneous bug fixes and enhancements.
Q: Which Sansa players is the Sansa Updater compatible with?
A: The e200, c200 and m200 series
Q: Should I "Open","Run" or "Save" when i click on "Download Sansa Firmware Updater"?
A: "Open" and "Run" would automatically start installing the software,. "Save" would save it to your computer and you can run it in the future. We suggest you "Open" or "Run" the installer.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC"
Q: How to check for firmware version?:
A: On the e200 and c200, press "menu" and go to "Settings" then "Info"/ "System Info". For m200, press "menu" then "Information".
Nov 12, 2008 | SanDisk Sansa e260 MP3 Player
Open Questions:
The printer won't work on disclabel or other software. It only works good on the testing in the printer setup. Macbook with Microboards MX 2. It goes on till the printing fase. ERROR LOG:Process: DiscPrinter [607] Path: /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter Identifier: DiscPrinter Version: 2.1.0 (2.1.0.6) Code Type: X86-64 (Native) Parent Process: cupsd [577] Responsible: DiscPrinter [607] User ID: 26 Date/Time: 2015-11-03 12:41:50.899 +0100 OS Version: Mac OS X 10.11.1 (15B42) Report Version: 11 Anonymous UUID: AA3DFA29-60FC-5C3B-34A4-014DDC5F4116 Time Awake Since Boot: 1000 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY VM Regions Near 0: --> __TEXT 0000000100000000-00000001001f9000 [ 2020K] r-x/rwx SM=COW /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.Microboards.print.driver.cups.disc_printer 0x00000001000b2488 bool com_sps_cups_disc_printer_util_2_1_0::ABucket::FindNoThrow(std::string const&, EIOTypeValue&) const + 126094 1 com.Microboards.print.driver.cups.disc_printer 0x000000010001ac1d 0x100000000 + 109597 2 com.Microboards.print.driver.cups.disc_printer 0x000000010001b3a6 0x100000000 + 111526 3 com.Microboards.print.driver.cups.disc_printer 0x000000010001dada 0x100000000 + 121562 4 com.Microboards.print.driver.cups.disc_printer 0x000000010001ed07 0x100000000 + 126215 5 com.Microboards.print.driver.cups.disc_printer 0x0000000100028a1a void com_sps_cups_disc_printer_util_2_1_0::ABucket::Set(std::string const&, com_sps_cups_disc_printer_util_2_1_0::AHPString const&) + 34458 6 com.Microboards.print.driver.cups.disc_printer 0x000000010001917a 0x100000000 + 102778 7 com.Microboards.print.driver.cups.disc_printer 0x0000000100019462 0x100000000 + 103522 8 com.Microboards.print.driver.cups.disc_printer 0x0000000100010ef0 0x100000000 + 69360 Thread 1: 0 libsystem_kernel.dylib 0x00007fff8927350a read + 10 1 com.Microboards.print.driver.cups.disc_printer 0x000000010002919b void com_sps_cups_disc_printer_util_2_1_0::ABucket::Set(std::string const&, com_sps_cups_disc_printer_util_2_1_0::AHPString const&) + 36379 2 libsystem_pthread.dylib 0x00007fff9d56c9b1 _pthread_body + 131 3 libsystem_pthread.dylib 0x00007fff9d56c92e _pthread_start + 168 4 libsystem_pthread.dylib 0x00007fff9d56a385 thread_start + 13 Thread 2: 0 libsystem_kernel.dylib 0x00007fff8927278a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9d56c58c _pthread_wqthread + 1283 2 libsystem_pthread.dylib 0x00007fff9d56a375 start_wqthread + 13 Thread 3:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x00007fff892730a2 kevent_qos + 10 1 libdispatch.dylib 0x00007fff8ce2711d _dispatch_mgr_invoke + 216 2 libdispatch.dylib 0x00007fff8ce26d85 _dispatch_mgr_thread + 52 Thread 4: 0 libsystem_kernel.dylib 0x00007fff8927278a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9d56c58c _pthread_wqthread + 1283 2 libsystem_pthread.dylib 0x00007fff9d56a375 start_wqthread + 13 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000000000000 rbx: 0x0000000000000000 rcx: 0x00000000001f8100 rdx: 0x0000000000000000 rdi: 0x0000000000000000 rsi: 0x0000000000000020 rbp: 0x00007fff5fbfe480 rsp: 0x00007fff5fbfe350 r8: 0x0000000000000001 r9: 0x0000000000000001 r10: 0x0000000000000002 r11: 0x0000000101d00000 r12: 0x0000000101d6ec10 r13: 0x00007fff5fbfe710 r14: 0x00007fff5fbfe710 r15: 0x0000000000000000 rip: 0x00000001000b2488 rfl: 0x0000000000010206 cr2: 0x000000010a8aa000 Logical CPU: 0 Error Code: 0x02000170 Trap Number: 133 Binary Images: 0x100000000 - 0x1001f8fef +com.Microboards.print.driver.cups.disc_printer (2.1.0 - 2.1.0.6) /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter 0x10024a000 - 0x10024ffff libcupsimage.2.dylib (435) /usr/lib/libcupsimage.2.dylib 0x100254000 - 0x1002eefef +libspsutils.dylib (1.2) /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/lib/libspsutils.dylib 0x7fff6c1ad000 - 0x7fff6c1e3f5f dyld (360.17) /usr/lib/dyld 0x7fff88482000 - 0x7fff8857dff7 libFontParser.dylib (158.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff8857e000 - 0x7fff88805ff3 com.apple.CFNetwork (760.1.2 - 760.1.2) /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff88bdf000 - 0x7fff88beeffb com.apple.LangAnalysis (1.7.0 - 1.7.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff88c00000 - 0x7fff88c05fff com.apple.TCC (1.0 - 1) /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff88c06000 - 0x7fff88c0efef libsystem_platform.dylib (73.1.1) /usr/lib/system/libsystem_platform.dylib 0x7fff88d9c000 - 0x7fff8925afcf com.apple.vImage (8.0 - 8.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff8925b000 - 0x7fff89279fff libsystem_kernel.dylib (3247.10.11) /usr/lib/system/libsystem_kernel.dylib 0x7fff8927a000 - 0x7fff8927bfff libsystem_secinit.dylib (20) /usr/lib/system/libsystem_secinit.dylib 0x7fff89282000 - 0x7fff89285fff libCoreVMClient.dylib (119.5) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff89286000 - 0x7fff8928fff3 com.apple.CommonAuth (4.0 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff89299000 - 0x7fff892a4ff7 libChineseTokenizer.dylib (16) /usr/lib/libChineseTokenizer.dylib 0x7fff8951e000 - 0x7fff89523ff7 libmacho.dylib (875.1) /usr/lib/system/libmacho.dylib 0x7fff89524000 - 0x7fff89582fff com.apple.SystemConfiguration (1.14 - 1.14) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff8967b000 - 0x7fff8976afff libxml2.2.dylib (29) /usr/lib/libxml2.2.dylib 0x7fff897a7000 - 0x7fff897c2ff7 libCRFSuite.dylib (34) /usr/lib/libCRFSuite.dylib 0x7fff897c3000 - 0x7fff897c6ff7 libsystem_sandbox.dylib (459.10.4) /usr/lib/system/libsystem_sandbox.dylib 0x7fff8aade000 - 0x7fff8ab0fffb com.apple.GSS (4.0 - 2.0) /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff8ab7a000 - 0x7fff8ab93fff com.apple.CFOpenDirectory (10.11 - 194) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff8ae6f000 - 0x7fff8b0eefff com.apple.security (7.0 - 57336.10.29) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff8b0ef000 - 0x7fff8b0f5fff com.apple.IOAccelerator (203.10 - 203.10) /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fff8b29e000 - 0x7fff8b2d8fff com.apple.QD (3.12 - 302) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff8b2dc000 - 0x7fff8b30aff7 com.apple.DictionaryServices (1.2 - 250) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff8b343000 - 0x7fff8b460fff libsqlite3.dylib (216.4) /usr/lib/libsqlite3.dylib 0x7fff8c222000 - 0x7fff8c34efff com.apple.CoreText (352.0 - 494.5.1) /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff8c34f000 - 0x7fff8c351ff7 libRadiance.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff8c355000 - 0x7fff8c3aafff com.apple.AE (701 - 701) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff8c6c7000 - 0x7fff8c6d5ff7 libbz2.1.0.dylib (38) /usr/lib/libbz2.1.0.dylib 0x7fff8c6d6000 - 0x7fff8c749fff com.apple.framework.IOKit (2.0.2 - 1178.10.1) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff8c9e7000 - 0x7fff8c9f2fff libkxld.dylib (3247.10.11) /usr/lib/system/libkxld.dylib 0x7fff8cc1c000 - 0x7fff8cc32ff7 libLinearAlgebra.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff8cc33000 - 0x7fff8cc83fff libcups.2.dylib (435) /usr/lib/libcups.2.dylib 0x7fff8cc84000 - 0x7fff8ccc2ff7 libGLImage.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff8ccc3000 - 0x7fff8cde8ff7 com.apple.LaunchServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff8ce1f000 - 0x7fff8ce4cfff libdispatch.dylib (500.10.1) /usr/lib/system/libdispatch.dylib 0x7fff8ce4d000 - 0x7fff8ce50ff7 libCoreFSCache.dylib (119.5) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fff8d075000 - 0x7fff8d092fff com.apple.AppleVPAFramework (2.0.15 - 2.0.15) /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA 0x7fff8d12a000 - 0x7fff8d199fff com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff8d410000 - 0x7fff8d414fff libcache.dylib (75) /usr/lib/system/libcache.dylib 0x7fff8d41b000 - 0x7fff8d4d4ff7 libvMisc.dylib (563.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff8dc7e000 - 0x7fff8dcadfc3 libsystem_m.dylib (3105) /usr/lib/system/libsystem_m.dylib 0x7fff8dd01000 - 0x7fff8dd43ff7 com.apple.Metal (54.26.3 - 54.26.3) /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fff8dec4000 - 0x7fff8f12fff7 com.apple.CoreGraphics (1.600.0 - 938) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff8f137000 - 0x7fff8f13ffff com.apple.CoreServices.FSEvents (1222.1.1 - 1222.1.1) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff8f146000 - 0x7fff8f14efff libGFXShared.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff8f573000 - 0x7fff8f57dfff com.apple.NetAuth (6.0 - 6.0) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff8f57e000 - 0x7fff8f5c9ffb com.apple.print.framework.PrintCore (11.0 - 472) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff8f6be000 - 0x7fff8f6d8fff com.apple.Kerberos (3.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff8f6d9000 - 0x7fff8f7cbff7 libiconv.2.dylib (44) /usr/lib/libiconv.2.dylib 0x7fff8f7cc000 - 0x7fff8f811ff3 libFontRegistry.dylib (155) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff8f93d000 - 0x7fff8f940fff com.apple.IOSurface (108.0.1 - 108.0.1) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff8fc06000 - 0x7fff8fc07ffb libSystem.B.dylib (1225.1.1) /usr/lib/libSystem.B.dylib 0x7fff8fc08000 - 0x7fff8fc0dff7 libheimdal-asn1.dylib (452.1.1) /usr/lib/libheimdal-asn1.dylib 0x7fff8fc0e000 - 0x7fff8fc1cfff com.apple.opengl (12.0.34 - 12.0.34) /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff8fc30000 - 0x7fff8fc4cff7 libextension.dylib (78) /usr/lib/libextension.dylib 0x7fff8fc4d000 - 0x7fff8fc58ff7 libcommonCrypto.dylib (60074) /usr/lib/system/libcommonCrypto.dylib 0x7fff8fd0b000 - 0x7fff8fd0bfff com.apple.CoreServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff90895000 - 0x7fff908baff7 libPng.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff9092d000 - 0x7fff90939fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff90959000 - 0x7fff90a6bfef libvDSP.dylib (563.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff90d13000 - 0x7fff90d16ffb libdyld.dylib (360.17) /usr/lib/system/libdyld.dylib 0x7fff90d31000 - 0x7fff90d33fff libsystem_coreservices.dylib (19) /usr/lib/system/libsystem_coreservices.dylib 0x7fff90f60000 - 0x7fff90f64fff libpam.2.dylib (20) /usr/lib/libpam.2.dylib 0x7fff90fa2000 - 0x7fff91016ff3 com.apple.securityfoundation (6.0 - 55126) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff912e5000 - 0x7fff912e7ff7 libquarantine.dylib (80) /usr/lib/system/libquarantine.dylib 0x7fff91302000 - 0x7fff91306fff libGIF.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff91374000 - 0x7fff913e7ffb com.apple.Heimdal (4.0 - 2.0) /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff91ba2000 - 0x7fff91bc6ff7 libJPEG.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff91cc4000 - 0x7fff91cc4ff7 liblaunch.dylib (755.1.19) /usr/lib/system/liblaunch.dylib 0x7fff92319000 - 0x7fff9235eff7 com.apple.coreservices.SharedFileList (24.4 - 24.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fff928b9000 - 0x7fff928bafff liblangid.dylib (122) /usr/lib/liblangid.dylib 0x7fff9313c000 - 0x7fff93141fff com.apple.DiskArbitration (2.7 - 2.7) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff934f9000 - 0x7fff93557fff libsystem_network.dylib (582.1.4) /usr/lib/system/libsystem_network.dylib 0x7fff94247000 - 0x7fff94249fff libCVMSPluginSupport.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff94393000 - 0x7fff94393fff com.apple.ApplicationServices (48 - 48) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff94470000 - 0x7fff94506ff7 com.apple.ColorSync (4.9.0 - 4.9.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff94542000 - 0x7fff94542fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff9454c000 - 0x7fff94551ff3 libunwind.dylib (35.3) /usr/lib/system/libunwind.dylib 0x7fff945d1000 - 0x7fff945d1fff libOpenScriptingUtil.dylib (169) /usr/lib/libOpenScriptingUtil.dylib 0x7fff945d2000 - 0x7fff949d4fff libLAPACK.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff95587000 - 0x7fff959fcff7 com.apple.CoreFoundation (6.9 - 1255.1) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff95a62000 - 0x7fff95a70fff libxar.1.dylib (302) /usr/lib/libxar.1.dylib 0x7fff95b84000 - 0x7fff95b94fff libbsm.0.dylib (34) /usr/lib/libbsm.0.dylib 0x7fff95b95000 - 0x7fff95b9cff7 libcompiler_rt.dylib (62) /usr/lib/system/libcompiler_rt.dylib 0x7fff95d16000 - 0x7fff95ebbff3 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff95ebc000 - 0x7fff960c9fff libicucore.A.dylib (551.30) /usr/lib/libicucore.A.dylib 0x7fff96188000 - 0x7fff961d6ff7 libstdc++.6.dylib (104.1) /usr/lib/libstdc++.6.dylib 0x7fff965e2000 - 0x7fff9666fdd7 com.apple.AppleJPEG (1.0 - 1) /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fff96673000 - 0x7fff966e1ff7 com.apple.ApplicationServices.ATS (377 - 394.1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff966e2000 - 0x7fff96782fff com.apple.Metadata (10.7.0 - 972.9) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff967dd000 - 0x7fff967f9ff7 libsystem_malloc.dylib (67) /usr/lib/system/libsystem_malloc.dylib 0x7fff967fa000 - 0x7fff968ecff7 libJP2.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff968ed000 - 0x7fff968edfff libmetal_timestamp.dylib (600.0.41.2) /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib 0x7fff968fc000 - 0x7fff96959fff com.apple.CoreServices.OSServices (728.4 - 728.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff9695a000 - 0x7fff96971fff libmarisa.dylib (4) /usr/lib/libmarisa.dylib 0x7fff96b6c000 - 0x7fff96e01fff libmecabra.dylib (696.1) /usr/lib/libmecabra.dylib 0x7fff96e55000 - 0x7fff96e89ff7 com.apple.CoreVideo (1.8 - 191.1) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff96f38000 - 0x7fff96f49fff libz.1.dylib (60) /usr/lib/libz.1.dylib 0x7fff9701e000 - 0x7fff97038ff3 liblzma.5.dylib (10) /usr/lib/liblzma.5.dylib 0x7fff97507000 - 0x7fff97508fff libsystem_blocks.dylib (65) /usr/lib/system/libsystem_blocks.dylib 0x7fff97fcd000 - 0x7fff97fd5fff libcopyfile.dylib (127) /usr/lib/system/libcopyfile.dylib 0x7fff98031000 - 0x7fff98032fff libDiagnosticMessagesClient.dylib (100) /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff98033000 - 0x7fff9839dddf libobjc.A.dylib (680) /usr/lib/libobjc.A.dylib 0x7fff9839e000 - 0x7fff9839eff7 libkeymgr.dylib (28) /usr/lib/system/libkeymgr.dylib 0x7fff983c1000 - 0x7fff983d1fff libSparseBLAS.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fff98ca3000 - 0x7fff98d30fe7 libsystem_c.dylib (1081.1.3) /usr/lib/system/libsystem_c.dylib 0x7fff98ea0000 - 0x7fff98ef3ff7 libc++.1.dylib (120.1) /usr/lib/libc++.1.dylib 0x7fff99073000 - 0x7fff9907bfff com.apple.NetFS (6.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff990cc000 - 0x7fff990ceff7 com.apple.xpc.ServiceManagement (1.0 - 1) /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff992b2000 - 0x7fff992c9fff libsystem_asl.dylib (322) /usr/lib/system/libsystem_asl.dylib 0x7fff992cd000 - 0x7fff99573fff com.apple.CoreData (120 - 640) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff9a401000 - 0x7fff9a5caff7 com.apple.ImageIO.framework (3.3.0 - 1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff9a5cb000 - 0x7fff9a5d6fff libGL.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff9a5d7000 - 0x7fff9a5d7fff com.apple.Accelerate (1.10 - Accelerate 1.10) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff9a6aa000 - 0x7fff9a6fbff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff9a6fc000 - 0x7fff9a725ff7 libsystem_info.dylib (476) /usr/lib/system/libsystem_info.dylib 0x7fff9a89d000 - 0x7fff9a8a6ffb libsystem_notify.dylib (149) /usr/lib/system/libsystem_notify.dylib 0x7fff9aa0d000 - 0x7fff9aa36fff libxpc.dylib (755.1.19) /usr/lib/system/libxpc.dylib 0x7fff9aa37000 - 0x7fff9aa39ff7 libsystem_configuration.dylib (801.10.2) /usr/lib/system/libsystem_configuration.dylib 0x7fff9aa6c000 - 0x7fff9aa7dff7 libsystem_trace.dylib (200) /usr/lib/system/libsystem_trace.dylib 0x7fff9aa7e000 - 0x7fff9aa86fff libsystem_networkextension.dylib (384.1.2) /usr/lib/system/libsystem_networkextension.dylib 0x7fff9ac9f000 - 0x7fff9acc8ff7 libxslt.1.dylib (14) /usr/lib/libxslt.1.dylib 0x7fff9adec000 - 0x7fff9adedffb libremovefile.dylib (41) /usr/lib/system/libremovefile.dylib 0x7fff9b218000 - 0x7fff9b218fff libenergytrace.dylib (10) /usr/lib/libenergytrace.dylib 0x7fff9b219000 - 0x7fff9b25aff7 libGLU.dylib (12.0.34.12) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff9b396000 - 0x7fff9b398fff com.apple.loginsupport (1.0 - 1) /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fff9bbf9000 - 0x7fff9bc1dfff com.apple.MultitouchSupport.framework (304.9 - 304.9) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff9bc7f000 - 0x7fff9bc87ffb libsystem_dnssd.dylib (624.10.1) /usr/lib/system/libsystem_dnssd.dylib 0x7fff9bc88000 - 0x7fff9bca4ff3 libresolv.9.dylib (60) /usr/lib/libresolv.9.dylib 0x7fff9cd6e000 - 0x7fff9cd7ffff libcmph.dylib (6) /usr/lib/libcmph.dylib 0x7fff9cd80000 - 0x7fff9cdabffb libarchive.2.dylib (32.10.1) /usr/lib/libarchive.2.dylib 0x7fff9cdaf000 - 0x7fff9d094ff3 com.apple.CoreServices.CarbonCore (1136 - 1136) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff9d095000 - 0x7fff9d0adfc7 libcompression.dylib (23) /usr/lib/libcompression.dylib 0x7fff9d0c4000 - 0x7fff9d13bfc7 libcorecrypto.dylib (334) /usr/lib/system/libcorecrypto.dylib 0x7fff9d13c000 - 0x7fff9d148ff7 com.apple.OpenDirectory (10.11 - 194) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff9d14c000 - 0x7fff9d198ffb com.apple.HIServices (1.22 - 548) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff9d19f000 - 0x7fff9d4f3fff com.apple.Foundation (6.9 - 1255.1) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff9d569000 - 0x7fff9d572ff7 libsystem_pthread.dylib (137.1.1) /usr/lib/system/libsystem_pthread.dylib 0x7fff9db15000 - 0x7fff9dcd5feb libBLAS.dylib (1159) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff9dee0000 - 0x7fff9dee0ff7 libunc.dylib (29) /usr/lib/system/libunc.dylib 0x7fff9dee1000 - 0x7fff9df27ff7 libauto.dylib (186) /usr/lib/libauto.dylib 0x7fff9e491000 - 0x7fff9e4bafff libc++abi.dylib (125) /usr/lib/libc++abi.dylib 0x7fff9e529000 - 0x7fff9e53dfff libsystem_coretls.dylib (82) /usr/lib/system/libsystem_coretls.dylib 0x7fff9eacf000 - 0x7fff9eb76fff com.apple.LanguageModeling (1.0 - 1) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff9eb88000 - 0x7fff9ebe3ff7 libTIFF.dylib (1440) /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 912 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=178.5M resident=0K(0%) swapped_out_or_unallocated=178.5M(100%) Writable regions: Total=39.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=39.5M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Activity Tracing 2048K 2 Dispatch continuations 4096K 2 Kernel Alloc Once 4K 2 MALLOC 21.6M 18 MALLOC guard page 32K 7 Process Corpse Info 2048K 2 STACK GUARD 56.0M 6 Stack 9824K 6 VM_ALLOCATE 20K 3 __DATA 8572K 144 __LINKEDIT 91.2M 6 __TEXT 87.3M 149 __UNICODE 552K 2 mapped file 25.1M 2 shared memory 20K 5 =========== ======= ======= TOTAL 307.8M 341 E [03/Nov/2015:12:41:50 +0100] [Job 31] Job stopped due to filter errors; please consult the error_log file for details. D [03/Nov/2015:12:41:50 +0100] [Job 31] The following messages were recorded from 12:41:50 to 12:41:50 D [03/Nov/2015:12:41:50 +0100] [Job 31] Adding start banner page "none". D [03/Nov/2015:12:41:50 +0100] [Job 31] Queued on "Microboards_PF_Pro" by "dennis". D [03/Nov/2015:12:41:50 +0100] [Job 31] File of type application/pdf queued by "dennis". D [03/Nov/2015:12:41:50 +0100] [Job 31] Setting job-hold-until to no-hold D [03/Nov/2015:12:41:50 +0100] [Job 31] Adding end banner page "none". D [03/Nov/2015:12:41:50 +0100] [Job 31] Job released by user. D [03/Nov/2015:12:41:50 +0100] [Job 31] time-at-processing=1446550910 D [03/Nov/2015:12:41:50 +0100] [Job 31] 1 filters for job: D [03/Nov/2015:12:41:50 +0100] [Job 31] /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter (application/pdf to printer/Microboards_PF_Pro, cost 100) D [03/Nov/2015:12:41:50 +0100] [Job 31] job-sheets=none,none D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[0]="Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[1]="31" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[2]="dennis" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[3]="Microboards PF-Pro - Untitled1 - DiscLabel" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[4]="1" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[5]="AP_ColorMatchingMode=AP_VendorColorMatching AP_D_InputSlot= noBookletBinding..b. BookletType..n.=0 nocollate com.apple.print.DocumentTicket.PMSpoolFormat=application/pdf com.apple.print.JobInfo.PMApplicationName=DiscLabel com.apple.print.JobInfo.PMJobName=Microboards\ PF-Pro\ -\ Untitled1\ -\ DiscLabel com.apple.print.JobInfo.PMJobOwner=Dennis com.apple.print.PageToPaperMappingMediaName=cd-120mm com.apple.print.PageToPaperMappingType..n.=1 com.apple.print.PrinterInfo.PMColorDeviceID..n.=16828 com.apple.print.PrintSettings.PMColorSpaceModel..n.=2 com.apple.print.PrintSettings.PMCopies..n.=1 com.apple.print.PrintSettings.PMCopyCollate..b. com.apple.print.PrintSettings.PMDestinationType..n.=1 com.apple.print.PrintSettings.PMFirstPage..n.=1 com.apple.print.PrintSettings.PMLastPage..n.=2147483647 com.apple.print.PrintSettings.PMLayoutColumns..n.=1 com.apple.print.PrintSettings.PMLayoutRows..n.=1 com.apple.print.PrintSettings.PMPageRange..a.0..n.=1 com.apple.print.PrintSettings.PMPageRange..a.1..n.=2147483647 DestinationPrinterID=Microboards_PF_Pro media=cd-120mm PaperInfoIsSuggested..b. pserrorhandler-requested=standard SPSClippingDiameters={\ Inner=360\ Outer=1180\ } SPSClippingHubDiameters={\ Inner=220\ Outer=360\ } job-uuid=urn:uuid:484af430-bba9-369f-4b62-be25bc4f6ac7 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1446550910 time-at-processing=1446550910 document-name-supplied=Microboards\ PF-Pro\ -\ Untitled1\ -\ DiscLabel job-impressions=1 com.apple.print.PrintSettings.PMTotalSidesImaged..n.=1 sides=one-sided Duplex=None com.apple.print.PrintSettings.PMTotalBeginPages..n.=1 PageSize=cd-120mm" D [03/Nov/2015:12:41:50 +0100] [Job 31] argv[6]="/private/var/spool/cups/d00031-001" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[0]="" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[1]="CUPS_CACHEDIR=/private/var/spool/cups/cache" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[2]="CUPS_DATADIR=/usr/share/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[3]="CUPS_DOCROOT=/usr/share/doc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[4]="CUPS_FONTPATH=/usr/share/cups/fonts" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[5]="CUPS_REQUESTROOT=/private/var/spool/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[6]="CUPS_SERVERBIN=/usr/libexec/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[7]="CUPS_SERVERROOT=/private/etc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[8]="CUPS_STATEDIR=/private/etc/cups" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[9]="HOME=/private/var/spool/cups/tmp" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[10]="PATH=/usr/libexec/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[11]="SERVER_ADMIN=root@macbookandennis.lan" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[12]="SOFTWARE=CUPS/2.1.0" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[13]="TMPDIR=/private/var/spool/cups/tmp" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[14]="USER=root" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[15]="CUPS_MAX_MESSAGE=2047" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[16]="CUPS_SERVER=/private/var/run/cupsd" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[17]="CUPS_ENCRYPTION=IfRequested" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[18]="IPP_PORT=631" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[19]="CHARSET=utf-8" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[20]="LANG=nl.UTF-8" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[21]="APPLE_LANGUAGE=nl" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[22]="PPD=/private/etc/cups/ppd/Microboards_PF_Pro.ppd" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[23]="RIP_MAX_CACHE=128m" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[24]="CONTENT_TYPE=application/pdf" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[25]="DEVICE_URI=usb://Microboards/PF-Pro?serial=PFP0004319" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[26]="PRINTER_INFO=Microboards PF-Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[27]="PRINTER_LOCATION=MacBook van Dennis" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[28]="PRINTER=Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[29]="PRINTER_STATE_REASONS=none" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[30]="CUPS_FILETYPE=document" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[31]="FINAL_CONTENT_TYPE=printer/Microboards_PF_Pro" D [03/Nov/2015:12:41:50 +0100] [Job 31] envp[32]="AUTH_I****" D [03/Nov/2015:12:41:50 +0100] [Job 31] Started filter /Library/Printers/Microboards/cups/DiscPrinter.driver/Contents/MacOS/DiscPrinter (PID 607) D [03/Nov/2015:12:41:50 +0100] [Job 31] Started backend /usr/libexec/cups/backend/usb (PID 608) D [03/Nov/2015:12:41:50 +0100] [Job 31] usb: AppleLanguages="nl" D [03/Nov/2015:12:41:50 +0100] [Job 31] STATE: +connecting-to-device D [03/Nov/2015:12:41:50 +0100] [Job 31] Looking for 'Microboards PF-Pro' D [03/Nov/2015:12:41:50 +0100] [Job 31] Opening connection D [03/Nov/2015:12:41:50 +0100] [Job 31] Directory '/System/Library/Printers/Libraries/USBGenericPrintingClass.plugin' heeft juiste bevoegdheden (040755/uid=0/gid=0). D [03/Nov/2015:12:41:50 +0100] [Job 31] load_classdriver(/Sys
Nov 03, 2015 | MicroBoards MX-2 Disc Publisher MX21000
MicroBoards DVD-PRM-PRO-1016 10-Disc 16x DVD/48x CD Duplicator Logo
Top MicroBoards Computers & Internet Experts
Rick Moore
Rick Moore
 Grubhead
Grubhead
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
