Question about ReliOn Reli On Blood Pressure Monitor
Relion automatic blood pressure monitor keep inflating without showing anything on screen
Once batteries are installed it stars inflating without stopping need to remove batteries to stop inflating. During such process it shows nothing on screen
How do I inflate my blood pressure device it is a CVS model BM 35
Here is a link to the manual. You simply put on the cuff, then press the POWER ON button to take the reading. The cuff should inflate automatically and take the measurement. If it is not working properly, ensure that the batteries are correctly installed and that they are not depleted.
https://www.beurer.com/web/we-dokumente/gebrauchsanweisungen/GA_USA/753.902_1012_BM35_CVS.pdf
Dec 30, 2015 | Health & Beauty
What does error 3 on my microlife blood pressure monitor
Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
Jan 10, 2015 | Microlife Health & Beauty
How to clear memory on a ReliaMed wrist blood preassure machine
  • Make sure the unit is off
  • Hold down on the memory button until you see "CL" (clear)
  • Once you see CL appear on the screen release the memory button then tap memory once
  • You will hear a series of beeps
  • Memory is now cleared
  • Apr 10, 2010 | American Diagnostic Corp ADC Advantage...
    Where is omron bp monitor service center in india my bp monitor doesnot get enough preesure and shows no 50 on the screen.
    call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
    Jan 19, 2010 | Omron Automatic Blood Pressure Monitor...
    Homemedics 518730--Will not inflate with either AC adaptor or fresh batteries
    call the manufacturer and inform them and/or take the monitor back to walgreens for exchange.
    Jan 12, 2010 | Walgreens By Homedics Automatic Blood...
    Omron hem-704C blood pressure monitor show down
    If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
    Dec 04, 2009 | Timex Health & Beauty
    Omron model 650 not inflating and measuring
    Lucky! Wrist BP monitors never provide accurate consistent measurements.
    Mar 13, 2009 | Health & Beauty
    WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
    E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
    Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
    When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
    EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
    Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
    ReliOn Reli On Blood Pressure Monitor Logo
    35 people viewed this question
    Top ReliOn Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a ReliOn Health and Beauty Expert? Answer questions, earn points and help others
