Question about JVC Th-bc1 Sound Bar System
No pcm light or optical audio
Sound bar stopped working; pcm light out and connect through optical audio.
I have a 42 Insignia TV and a Vizio 3821 sound bar. I also have Dish Network Hopper on this TV. I have tried all sorts of hook ups, but still no sound. Help
Soundbar & TV connection issues...Please Help!! - TV - Audio
www.tomsguide.com/answers/id.../soundbar-connection-issues.html
Aug 5, 2013 - the tv does have an optical output according to the website, it may just look hidden because ... I am trying(without success) to connect a JBL SB100soundbar to a Samsung ... Since your sound bar has an optical in then problem solved. .... a b x TV. August 5, 2013 10:32:42 AM. something like this should do ...
How to Connect a Soundbar to TV audio - YouTube
? 3:19
https://www.youtube.com/watch?v=Z27WtBy4IUs
Nov 22, 2013 - Uploaded by All About Home Electronics.com
The issue is not how to plug the cables in, it's all color coded and easy. ... I have a Sanyo sound bar but it won't connect to my LGtv nor my ps4!
Amazon.com: Sound Bars
Jan 10, 2016 | Vizio Televison & Video
LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Bush 4.1 sound bar cuts out, connected via optical sound cuts out it is intermittent, happens on tv, dvd/blue ray and media player setting. Any ideas how to stop this happening. Have tried rca cables etc
I get a similar issue from my Bush sound bar. The sound drops out when the tv programme/movie etc has a period of silence in the audio track or just very low background music (no speech). As soon as someone begins to speak it starts up, but usually it misses the first couple of words. Bar is connected directly to a Samsung tv via the optical cable. Any ideas?
Aug 12, 2013 | Audio Players & Recorders
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
I have a VSB200. It worked until last night. No sound coming out of it now.
I have the same sound bar and in the middle of watching a movie, it just stopped working. I came to the conclusion that it was the optical hookup on the back of the speaker that had an issue. The problem with the entire situation is that I had only owned the sound bar for around two to three weeks and only watched around four movies on it until this problem. Either a fluke or bad quality. Check your optical connection if that is what you have it hooked up to.
Apr 28, 2011 | Vizio VSB210WS Soundbar
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Dec 31, 2010 | LG 47LG50 47 in. LCD HDTV
Need help connecting to surround sound to a vizio sound bar
hi,
did u mean connecting the sound bar to ur tv.
u didn't mentioned the model number of ur sound bar.
any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices.
if u are using a satellite receiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input.
ok
Dec 18, 2010 | Emerson LC320EM9 32 in. LCD HDTV
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Nov 29, 2008 | Panasonic Home Theater System System
PS3 Surround SOund
go to the audio settings, i'm not sure what it was it was called like linear pcm or something like that...it worked for em
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
JVC Th-bc1 Sound Bar System Logo
64 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
