Question about Bosch TDA2135 Iron
Sensixx b22L descaled iron yesterday as the light was flashing & the tank had plenty of water in, this morning after switch on red light still flashing! Iron seems to operate ok but it's clearly not happy or wouldn't still be trying to tell me something, help?
5 Suggested Answers
SOURCE: bosch sensixx 2400w
The cleaning process is to fill up, heat to max, then hold steam lever across to "calc and clean" position whilst shaking gently over a sink.
Manual is available to download from Bosch.co.uk.
Posted on Jul 07, 2009
SOURCE: i have an bosch sensixx b5 iron and the calc clean
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Posted on Feb 13, 2011
SOURCE: bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Posted on Apr 20, 2011
ercupa190
  • 12223 Answers
SOURCE: Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Posted on Aug 01, 2012
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
My bosch sensixx B22L makes every 5 to 10 min a roaring noice
My iron is leaking water from the plate when using it on the steam why is this?
Jan 02, 2013 | Irons
Bosch TDS 1445/05 Sensixx station doesn't making steam
HI!
I HAVE AN Bosch TDS 1445/05 Sensixx AND THE IRON PLADE NOT WORM AT ALL. I CHECK THE POWER.I CHANGE THE THERMOSTAT/THE CONDENSER WITH THE LAMP/.BUT STILL NOT WORK. THE BOILER WORK GOOD.PLEASE HELP ME.WHAT CAN I DO MORE. THANK YOU
Oct 06, 2012 | Irons
Bosch sensixx b25l manual
Though tpmy iron is heating up it won't take the water in and so doesn't steam It has been cleaned and no scale is in the bottom. It worked fine yesterday.
Jan 11, 2012 | Irons
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Jan 25, 2011 | Bosch Irons
Bosh sensixx B25L iron spraying brown water
Feb 22, 2010 | Bosch Irons
Sensixx cosmo - how do I drain & clean this
Go to wallmart, they sell steam iron cleaning either solution or powder. It is not too dear.
Aug 03, 2009 | Irons
HOW DO I DESCALE A STEAM GENERATOR IRON
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Dec 19, 2008 | Maytag MLI7500A Iron
Bosch sensixx 2400w
Aug 27, 2008 | Bosch TDA8340 Iron
Bosch TDA2135 Iron Logo
61 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
Mark Chaney
Mark Chaney
matt
matt
Are you a Bosch Iron Expert? Answer questions, earn points and help others
