Question about Gatehouse Springfield Satin Nickel Residential Single-Lock Door Handle
Door knob loose
Inside door knob is loose and needs tightened
How to tighten-up loose door knob?
What door knob are we talking about,, a door knob has screws on the back side, usually a #2 phillips head screwdriver will work in the screws.. If you are talking about a different knob.. please repiy on here... please mark as helpful..
Jul 18, 2017 | Hardware & Accessories
A LOOSE BATHROOM SINK HOT WATER HANDLE
Is it the whole tap or just the knob/lever?
Whole tap, there is a nut underneath that needs tightening. Don't over tighten it.
Just the knob or lever that you turn to turn on and off? You will find a small screw at the rear. It is a set screw, so it doesn't have a head, it just sits in a hole. Usually a hex key to tighten it. The hole is often filled with gunk so clean it first with an old toothbrush. The set screw is often sticky so undo it I turn before you tighten, lift the knob off, screw the screw in until you see it coming out of the inside to clean the threads. Unscrew the screw back out, replace the knob and tighten it.
Oct 10, 2015 | Plumbing
Weiser door knob GA9771A-S. Loose interior door knob. How do I tighten?
Remove the knob by pushing in the small pin on the edge of the knob shaft. Then use a screwdriver in the small inset on the edge of the handle cover to pop the cover off. Tighten the 2 screws under the cover, replace parts.
Mar 25, 2014 | Hardware & Accessories
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
Back door handle on my back door is loose and has alot of play on it
If it is not the OLD style door knob, tighten the two screws next to the knob. If that does not fix it it will probably need repleced.
Feb 21, 2011 | Garden
The door knob (lever door knob to exterior fancy door) came off.
When you first tightened the screws, the mechanism may have been loose enough to allow the actuator bar the connects the inside knob to the outside lever to work loose. When you tightened it you may have jambed that tight so things didn't work. When you disassembled everything, you may have lost that part. The springs are usually integrated into the catch part and are not removeable. Sometimes it helps to take everything completely off the door including the catch that goes in the edge of the door. Then reassemble it on a table to see what works and what doesn't. If that doesn't help, take all the pieces into Lowes at the key desk and they will be glad to help you.
Jun 18, 2009 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Door lock is loose
Inside plate arond the base of the knob needs to pop off.
Try removing the knob from the inside. Look for a place the push in with a flat head screwdriver. A release point is there some where.
After the knob is off the plate should come off and reveal the screws.
Mar 30, 2009 | Kwikset Professional Door Lock...
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Door knob
A couple of ideas: Sometimes the top of the knob is a cap which can be levered off with a sharp blade. Or, there is a grub screw (which may need a hex key to turn it) in a hole on the underside of the knob.
Sep 21, 2007 | Computers & Internet
Gatehouse Springfield Satin Nickel Residential Single-Lock Door Handle Logo
49 people viewed this question
Top Gatehouse Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Gatehouse Hardware and Accessory Expert? Answer questions, earn points and help others
