Question about Breville Opula Collection VKJ567 Stainless Steel Jug Kettle, Opal White
Lid snapped on my breville opula jug kettle where can i by a new one
  • 274 Answers
SOURCE: new kettle breville
There's several home remedies you can try: Try 50% "White Vinegar", 50% Hot Water or 2 Denture tablets in warm water over night or Baking soda in warm water. These remove the alkaline, minerals, and nitrates that build up on the surface. There is even a commercial product you can use to clean it. I can't recall the name but look in any supermarket, you should be able to locate it.
Posted on Sep 11, 2007
SOURCE: Spares for Breville Electric Kettle
Okay. I took the base off the kettle (made a special screwdriver). Saw that one of the contacts was loose on its 'swage'. Used a pin punch to re-swage it. Bingo! it worked.
Jeff.
Posted on Sep 15, 2008
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
  • 7 Answers
SOURCE: the on/off switch on my breville jk164 kettle has
Ring breville and ask if this part available,if so ask for price of part and repair costs .
Total it up, might be cheaper to buy a new one these days.
But do not repair yourself unless you are a competent electrical trades person.
Electricity is dangerous.
Posted on Sep 12, 2010
ginko
  • 19396 Answers
SOURCE: I have a Breville Kettle
Hi.
The switch does not get red because reach of adequate temperature is not detected. The problem is either thermostat or element. Both parts are tested using a multimeter set on Ohms to read impedance. if the part reads open, then it must be replaced.
Problem will be locating the part.
First call Breville and find out repair price and warranty status.
Here Breville USA:Breville . See also: Parts ' Breville
Here Australia:Breville
UK:Breville
If the unit is out of warranty call EReplacementParts, they sell parts and do repair. number is 866-802-6383
Here a disassembly diagram.
Posted on May 17, 2011
Where can I find a replacement filter spout?
About 683,000 results (0.79 seconds) Search Results
    Buy Kettle Spare Parts ' Calcium filters, Lids and More ...
    www.espares.co.uk/browse/at1102/kettles/small-appliances
    Buy spares for your kettle; kettle filters, kettle lids, kettle descalers and more. We carry parts for all home and garden appliances. ... Find Kettle Spares. Black & Decker. Bosch. Braun. Breville. Brita ... Kettle Spout Filter. Genuine spare part for ...
Feb 05, 2016 | Kitchen Appliances - Others
Bulb in Ikon kettle no longer lights up
I had this problem recently; I think my kettle have accidentally been turned on empty. The kettle has a safety for that, described as follows in the manual:
"The kettle is fitted with a safety device, which protects against overheating should the appliance be operated with insufficient water. If this occurs the kettle will stop heating. Switch 'Off' at the power
point and allow kettle to cool before refilling. The safety device will automatically reset when the kettle has cooled down."
Then they go on to tell you that there is an additional thermal cut-out, and if that is tripped, you have to send it back to Breville for servicing. However, it might not be that bad-- it wasn't in my case.
The heating connector and control is made by Otter, here's information that I was able to find about it on their website (Otter A1 and CS7 control and connector-- I think the kettle actually uses a CS4 connector, but the thermal cut out isn't described on that data sheet):
"The A1 control integrates to 360° cordless plug with element
dry boil protection. Two bimetals spring loaded against the
element surface make a fast response during dry boil. One
bimetal disconnects the live side of the electric circuit and the
other disconnects the neutral. A latch out function prevents
dry boil cycling. This automatically resets when the kettle or
jug is lifted from the cordless base."
http://www.ottercontrols.co.uk/support-downloads/domestic-data-sheets
So what does this mean to you? If you look at the bottom of the kettle jug, there is a circular indentation that slots into the base. There are two white plastic things which I believe are part of the "latch out" described above in Otter's documentation. If you see them sticking out, they may be stuck in position instead of resetting as they should. Use something like a pencil eraser to gently poke them so they unstick, then put the jug back on the base. That should cause them to retract, and at that point your kettle should work again.
Nov 07, 2013 | Breville SK500XL Stainless Steel Cordless...
How to descale a breville one cup
NOTE: Not my instructions i just found something similar.
According to the instructions for Breville Hot Cup (presumably similar to yours - the adjustable flow one):
1. Fill it to the max and dispense one cup of water.
2. Add a citric based descaling product into the cup and stir.
3. Tip contents into kettle and close lid.
4. Dispense water from the kettle, discarding the water until it reaches the 'min' mark.
5. Empty remaining water into sink, rinse out with clean water.
6. Fill kettle with fresh water and dispense cups of water until it reaches the 'min' mark. Empty the rest into the sink, then refill ready for use.
Nov 24, 2011 | Breville Coffee Makers & Espresso Machines
The on/off switch on my breville jk164 kettle has snapped off. Can it be repaired or a new switch put in?
Sep 12, 2010 | Breville Kitchen Appliances - Others
Dualit glacier blue kettle spare lid
Our kettle has just broken so if you'd like our lid? - if so I'll pop it on ebay?!
Apr 04, 2010 | Dualit 72102 / 72100 Cordless Electric...
Broken blender jug for breville FP12
Hi Contact Breville customer services on:
http://www.breville.co.uk/contactus.html
Either phone them or email them - they should be able to sort you out with a replacement jug.
Mar 28, 2009 | Food Processors
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
Apr 21, 2008 | Breville SK500-XL Stainless Steel Cordless...
Breville Opula Collection VKJ567 Stainless Steel Jug Kettle, Opal White Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
