Renco tv cable converter channel loc how to remove
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
1) On your Renco Cable Controller Remote Controller, Press on/off switch to off then press -/--/--- Button for about 12 times then press 2 to restore all UHF channels.
2) Press off again then 0 for about 12 times then 2 to restore all VHF channels. This will also remove the Lock of channels.
Posted on Sep 10, 2014
Bought 42in Philips SmartTV from Singapore and used in Philippines, attached to cable but reception is rainy. i tried to connect a renco digital converter, got sounds but black screen on TV. Pls help.
Sound like you HDMI settings is not set right. put it back the way you had it so you can change different setting for you HDMI.. like 1080i or p or ip or 720i or p or ip...
Maybe that will help
Good luck.
Apr 24, 2015 | Philips Televison & Video
I have a mga tv 1988' model cs1946R. I only get 11 channels from comcast my cable provider, my other tv (newer) get all channels. How do I programe my old mga to get more channels( I know i won't get as...
Your old tv does not have more than 11 slots to store channel .
Thats why you are not able to get more than 11 channels .
But let me confirm it .
SAM ANDERSON
Sep 18, 2008 | Televison & Video
Renco remote how to reset tv channels
On your Renco Cable Controller Remote Controller, Press on/off switch to off then press -/--/--- Button for about 12 times then press 2 to restore all UHF channels. Press off again then 0 for about 12 times then 2 to restore all VHF channels.
Jul 13, 2014 | Televison & Video
Do you have a user manual for a renco cable converter remote?
Jun 06, 2012 | Televison & Video
I have a sharp crt tv model:25c-bs370,although i'm using cable signal which more than 100 channels,still the channel it receive is limited only to 35 channels...how to rechannel the unit?my tv came...
Hi,The Television from japan have no lowband channel,It can be rechannel but the channel additional is onlly the lowband channel it maybe add only 2 channel.So the best things you do is to buy and install a channel converter to your TV.A channel converter is 100 plus channel thats why you can use your cable to japan television.To install the channel converter you need to set your television to Video setting and use RCA connector and plug it to video/sound input of your TV and video/sound output of channel converter.The cable connected plug it to channel converter.
Jul 11, 2011 | Sharp Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Can I watch tv on 1 channel while recording another?
Unfortunately no, unless you get a second converter box. You're using the converter box to select channels, and it can only be on one channel at a time. With a second converter box, you might find you need a second antenna too (so you can get a signal on both channels). And you can't program your VCR to record on different channels (since it can't control the coverter box to change channels).
(This is a case of history repeating itself. When cable TV was new, and most TV's and VCR's weren't cable-ready, you needed to use the cable company's converter box. The same problems came up then too!)
Nov 30, 2008 | Insignia Digital-to-Analog Converter for...
How do I connect a line output converter to my factory head unit
depending on the type of line out converter that you have you simply just take the speaker wires coming from the head unit (you must know the color codes for the wires or you can do the process of elimination by pulling off the door panels and and viewing the colors and matching them at the wire harness behind the head unit). Pull out electric fuse for radio so you dont blow it while hooking up the wires. After you have done that just connect the speaker wires coming out of the head unit to the line out converter this will pre-amp your signal. After you have done that step on the other side of the loc you will have to connect and run rca audio cables to the back of your car to hook into your amplifier. The last step is to splice the power and ground wire coming from the wire harness and connect the radio power wire and loc power wire to the main power wire and then connect the radio ground wire and the loc ground wire to the main ground wire. Test and your done with the loc.
Aug 12, 2008 | 2008 Chevrolet Impala
Televison & Video Logo
2,290 people viewed this question
Top Televison & Video Experts
Electro Med Services...
