Question about Zanussi Washing Machines
Gain access to zanussi aquacycle 1100 change drive belt
SOURCE: Zanussi IZ 12
I've just spent an hour taking mine to bits. On the back there are 2 x 9mm silver nuts at the bottom, below the star head screws you removed to get the top off. Then there are two more sneaky ones at the bottom of each side panel, just next to the gap about half way along on both sides., with a plastic cover hiding them from view. Make sure you release the mains cable holder from the top of the back by pressing the plastic clips down, then the whole shebang should slide off easily.
Regards. Paul C
Posted on Jun 28, 2008
  • 1462 Answers
SOURCE: My zanussi Aquacycle 1100 wont
door interlock is easy to replace.
undo the plastic clamp that holds door gasket to cabinet. peel back in area of door lock. door lock is held by 2 screws on outside. undo these ans lock comes off. there may also be a small diameter hose as well to door lock which take off as well.
reassembly is just the reverse
Posted on Jun 30, 2008
SOURCE: Zanussi aquacycle 1200 smells.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Posted on Aug 13, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Posted on Dec 31, 2009
SOURCE: I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Posted on Jan 12, 2010
My Zanussi aquacycle 1100 is not spinning continually (very weakly) and leaving the clothes very damp.
Motor coupling or equal. Most likely. This happens by over filling washer or placing carpets. Bed blankets etc
Feb 16, 2015 | Zanussi Washing Machines
Access motor belt zanussi aquacycle 1000
There is usually a hatch at the back of the washing machine.
Mar 17, 2014 | Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
I want to change a belt on a Zanussi Aquacycle Washing Machine. How do I access the rear of the machine
There is a panel at the rear of the machine that you can remove to access the belts and pulleys etc. Make sure that the machine is unplugged before removing the back panel, opening it will expose live terminals etc.
Mar 06, 2011 | Zanussi Washing Machines
Wiring Details
if you have just two wire on thermostat then it is
immaterial where you connect on thermostat.
ONLY IF HAVE TWO WIRE THERMOSTAT.
Feb 16, 2009 | Zanussi FJS1225W Front Load Washer
I need to know what the model no is for a zanussi aquacycle 1100 xc washing machine as I have a problem with the drain um and would like to urchase a new one but do not know the model no of the machine
if you look on the back of the machine there should be a label there with the model number. (Or inside the users manual)
http://www.zanussi.co.uk/ or go here and click on 'Contact Us' to find out directly fron Zanussi.
Nov 08, 2008 | Washing Machines
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
