ViewSonic pjd 5122 unit only runs few seconds and the power button turn red and shuts off
My viewsonic pjd 5122 runs few second and the power button turn red and restarted
  • 2,005 Answers
Bad battery
Posted on Nov 18, 2013
Testimonial: "thanks jim how can i solve that issue? and where is the battery on the projector?"
SOURCE: Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Posted on Feb 11, 2009
  • 9 Answers
SOURCE: Red lights flashing on ViewSonic PJ750
This is a sign of overheating, its a thermal issue, I solved the problem with some compressed air, but absolutely DO NOT blow in the ldc assembly or you will get dust in the lens system. You want to blow the cmpresed air on the electronics not ont he optics. I found that over time dust hair ect collected on the thermosistor and caused the over temp error. Cleaning it resolved the issue.
Posted on Mar 01, 2009
projdoc
  • 2237 Answers
SOURCE: The unit powers up, the fan runs for a few
one or more of the fans are not working.
Posted on Jan 28, 2010
  • 146 Answers
SOURCE: I turn on my Viewsonic
sounds like a bad bulb
projectors get a resistance reading from the bulb and if it doesnt get right value it will give you the double red lights
only other thing it could be is if the fans in projector are not turning on
call viewsonic and tell them issue and make them resolve issue
or
if unit is only 2 weeks old bring it back to store and get replacement or call viewsonic and get them to send you replacement unit - it is too new to mess with it yourself and take chance on voiding warranty
Posted on Mar 24, 2011
salt56
  • 373 Answers
SOURCE: I have a Viewsonic PJ558D
You need to reset the lamp timer. This is likely your problem since you changed the lamp.
Turn the projector on. open the menu. Go to advanced. Scroll down to the first option which should be auto source. Make sure this option is checked. While on this option press right once, left twice, right 3 times, then left 4 times. Another menu will appear. Scroll to lamp time and push enter. This will take it back to zero.
Posted on Jun 12, 2011
Viewsonic PJ558D shuts off after a few seconds
Sounds like the ballast board for the lamp stopped working.
Nov 19, 2014 | ViewSonic PJ558D DLP Projector
Tip
Viewsonic monitor Lock and Unlock instructions
OSD and Power Lock Settings
OSD Lock: Press and hold [1] and the up arrow UP for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
OSD Unlock: Press and hold [1] and the up arrow UP again for 10 seconds.
Power Button Lock: Press and hold [1] and the down arrow DOWN for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display?s power will automatically
turn ON when power is restored.
Power Button Unlock: Press and hold [1] and the down arrow DOWN again for 10 seconds.
May not work on ALL Viewsonics
http://www.viewsonic.com/assets/027/7939.pdf
Service manuals: http://ftpkuban.com/FTP/Manual/ViewSonic/
on Apr 14, 2010 | Computers & Internet
P191w
The Acer p191w uses the same power supply as the Viewsonic VX1962wm that your problem is a well known issues with that power supply. The filter capacitors go out and that causes the power supply to shut down within a few seconds. The monitor is easy to repair, you will just need to replace the bad capacitors on the power supply board. Here is a link to a repair guide for the Viewsonic VX1962wm and the information will be the same since the boards are the same in both units.
http://www.ccl-la.com/blog/index.php/viewsonic-vx1962wm-monitor-repair/
Dec 22, 2012 | Acer P191W 19" LCD Monitor
HI I have a new View Sonic DLP PJD 6221 It does not have very many hours, It turns on normally, after three to four minutes, it blinks for a few seconds and then shuts down. The red lamp light...
is the filter timer enabled. what are the total filter hours it has recorded.
is the air filter and vents clean etc.
it seems to be getting too hot as you suggest
Apr 20, 2011 | ViewSonic Office Equipment & Supplies
I turn on my Viewsonic PJD6251 but the lamp does not come on, and after a few seconds I get 2 red lights TEMP and LAMP. It is new, only 2 weeks I barely used. Good care.
or
Mar 24, 2011 | ViewSonic PJD6251 Projector
I have a viewsonic pjd 6221 projector. The OSD has been set to one second. How can I change this setting as it does,t give me enough time to make any changes? Regards Keith
There is a setting called OSD timeout. You should set its value to 60 secs(recommended). Select the OSD timeout setting and press the volume up button(up arrow to increase the value.
Feb 15, 2010 | ViewSonic Televison & Video
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
167 people viewed this question
k24674
jasbo
jasbo
