Question about Refrigerators
My hotpoint HS3022VL fridge is freezing the food inside and all temp lights are flashing. Any ideas
The compressor seems to be running al the time and the fridge freezes regardless of the temperature setting chosen
SOURCE: Model E372b Fisher & Pykel - Beeps with Fridge Door closed periodically-Higest shelves warm lower down freezes things
First I would like to say thanks for all the information on the Fisher-Paykel active smart fridge freezer problems. This was a lot more useful than their customer support help line… After a week of hanging on for ten minutes without any answer I had a look on the net and found your site with descriptions of similar problems so I decided to investigate further
I have a Fisher Paykel fridge freezer (model 402B in the UK) about three years old. Although it didn’t seem to be as cold as normal, the first sign of a serious problem was when it started making a rattling or knocking noise from the freezer compartment. Looking inside it was obviously iced up solid and the noise was probably the fan catching the ice. So first thing I decided to try was a days de icing after which everything seemed ok except the green indicator light was now flashing about once every second.
Two weeks later it was badly iced up again so the problem was still there. At first I suspected the fans (which I could never see actually working). I disconnected one and tried it with a 6v torch battery and it spun ok. It was then I realised what was happening - the fans cut out whenever the door is opened so they are always stopped if you look inside.
A closer look at the aluminium heat exchanger(behind the plastic panel at the back of the freezer section) showed there was some kind of heater element clipped along the bottom with feed wires at either side. Obviousely part of the automatic de icing systems. It’s a bit tricky but there an electrical connector plug at the top and disconnecting this enables you to unclip the element and remove it (except that in this case one wire had been trapped at the wrong side of the coolant pipes when they had been fitted so it had to be snipped to get it out). Once out a circuit test showed there was no circuit through the element. So cutting into the two shrouded connections at each end of the element revealed some little components inside which I now know are “Thermal fuses”. One of these had “Blown”. There was a number on the side: - DF 72S which Google revealed is a thermal fuse set at 72 degrees. Although these are listed as spares in all sorts of places non was convenient to the UK. So I found a similar component at Maplins Electronics (R14) set at 92 degrees for just 69p! The reasoning being that the other thermal DF 72S fuse was still ok and the slightly higher use temp at the other end would still blow before anything melted!
By the way you cannot solder these things in so its best to use miniature screwed “block” connectors plus a good covering with insulation tape.
After putting it all back together its now been working for a month and no ice build up… The green light did still flash for a while but went out once the temperature dropped too normal freezing level.
Total cost of replacement parts was under £1 but it took a bit of time find the problem.
Posted on May 12, 2008
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
WeListen2You
  • 538 Answers
SOURCE: Hotpoint Fridge freezing the food.
thermostat is buried behind the walls of that unit, are you ready to run this one..takes quite a bit of time..but
will get the item, if you can supply the actual serial number from inside or back of that unit..
Posted on Oct 26, 2008
  • 358 Answers
SOURCE: my mini fridge freezes everything
Need to replace the termostat.
Posted on Apr 03, 2009
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Contents are freezing
Recheck the wiring on the new board, and that the board is the correct one. Your neutral sounds to be wrongly connected. Is the compressor running continuously?
Apr 25, 2014 | Hotpoint-Ariston HS3022VL Refrigerator
Everything freezes
Make sure it is level.
Nov 25, 2013 | Hotpoint Refrigerators
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
The refrigerator and the freezer are staying too cold. The temp controls are at the lowest possible and still things in fridge freeze. I can hear the compressor cycle of for a while then on for a while....
things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help out.....
Jun 09, 2011 | Refrigerators
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Ffa70 hotpoint fridge freezer
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
