Question about RCA P52926 52" Rear Projection Television
Image problems I just bought a 56" RCA Projection tv model P56926. The couple I got it from said that it basically has a dual image problem...if that makes any sense at all....I have no idea what to look for, how to fix it and not sure what it's going to cost me. Any help at all would be great, thanks. Mikael
  • 1,694 Answers
Dual image problem is generally a convergence issue.
A repair of replacement of convergence amp IC(s) and
possible fuse device in power supply will be needed.Ask a
local repair shop w/good reputation what the cost would be.
Posted on Oct 17, 2007
Crescent shaped image on screen - RCA 56" P56926
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Apr 07, 2010 | RCA P52926 52" Rear Projection Television
How to remove screen on projection screen tv 56"rca model#p56926
Remove the speaker cover on the front, it just pulls off. Pry each side a little at a time. There are 4 screws that hold the screen on. Remove them and the screen just lifts off. There are wires attached to the controls so, keep that in mind when lifting the screen.
Aug 10, 2009 | RCA P52926 52" Rear Projection Television
I need a lamp number for my RCA P56926 model TV. Can anyone help me??
bluestar international componets 1 800-522-2701 1-631-385-8171 or web site bulb 115.00
Jul 01, 2009 | RCA P52926 52" Rear Projection Television
on my rca projection, it let me access all of those functions under the menu button, right on the front of the tv
Oct 07, 2008 | RCA P52926 52" Rear Projection Television
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
56" RCA projection, model P56930BL, no power up.
#1 problem in this model for not powering up is the color wheel needs to be replaced or it could be the lamp is burn out or it could be the ballast it bad. But the #1 problem is the color wheel.
Mar 28, 2008 | RCA P56930BL 56" Rear Projection...
Rca p56926 convergence problem
Your set has a repair issue with the convergence circuit.
Adjustments in the service menu will not help.............I agree
with Guest comment.... circuit board repair or replacement is
what you both need.....................T.
Nov 23, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
