Question about Hardware & Accessories
Do not know how to set theben pool timer
Do not know to set the theben pool timer
2 Suggested Answers
SOURCE: Do not know how to use Theben time switch.
I have theben timer sul181h. How to set it for lighting automatically at 6p.m. and stopping at 9p.m.?
Posted on Dec 23, 2010
How to wire a theben 24hr timer
Generally theben timers are wired same as illustrations shown on following pages
Wiring varies slightly by exact model number.
http://waterheatertimer.org/How-to-wire-DTD-1440-timer.html
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Most these timers are rated 15 amp.
Safe maximum :: 15 amp x 80% = 12 amp
230V x 12 amp = 2760 watt
For best long-term result, use timer to turn on a contactor (relay) and let the contactor handle switching heavy amp load
Fuse-protect the timer by adding inline fuse to hot wire going to timer.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 14, 2014 | General Electric GE 24-Hour Timer, 2-Pin...
The 64B 240v 50Hz 16A theben timer is not turning lights off
Copy following link for analog 24-hour timer:
http://waterheatertimer.org/How-to-set-timers.html
Is this new timer, or older timer with worn-out trippers?
Or is this the theben digital timer.
Add a comment and describe timer in detail for more possible assistance
Apr 20, 2013 | Hardware & Accessories
The supplier that fiited my swimmimng pools timers never gave me the booklet on how to set the time.
1) Unknown brand name pool timer, probably Intermatic:
Unknown if this is mechanical timer, or digital, or remote control, or air activated. Or if this is control center with circuit breakers and multiple timers to control heater, and pool pump, or if unit has firemans switch to turn pool heater off 20 minutes before pool pump, or if unit has freeze protection thermostat, etc
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
2) For Tork:
http://waterheatertimer.org/Tork-Pool-timers-and-manuals.html
3) Jan 2013.
Add a comment with model number or attach photograph and add any other information available for best possible answer based on specific product.
Jan 02, 2013 | Hardware & Accessories
I want to know how to set the time on my swimmimg pool timers
Hello Gerhard
2) For Tork:
3) Jan 2013.
I dont know how to set the timer
Question posted under Intermatic T104 series timer and pool control center.
Open following link to see how to set this timer:
Intermatic T12404R control center has 2 timers.
Each timer is set same way.
Timer must be reset after power outage. If time dial is not rotating correctly or is sticking at the tripper, then the WG1573 clock motor can be replaced by homeowner.
Both timers are 240Volts, and can be wired in variety of ways to control different voltages. For example 120Volt pool lights, and 240Volt pool pump and pool heater etc.
Each timer snaps out of control center using thumb spring located top inside box.
Each timer mechanism is sold separately. One timer is T104M. The other is T104M201.
The difference is that the 201 has a 'fireman's switch' that can be wired to pool heater, and the switch turns off heater 15-20 minutes before turning off pump.
Each timing mechanism can be repaired by homeowner using available clock motors and trippers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Timer T12404R Pool & Spa...
How to set the time using theben sul 181
how to set the time theben sul 181h and explain its components.
Jul 13, 2011 | Office Equipment & Supplies
I need to know how to set this timer for a large swimming pool, and how long I need it to run, to keep it clean. I believe it is about 35,000 gals., in-ground pool.
You have Intermatic mechanical timer connected to swimming pool pump/filter.
Open following link to read about setting timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Lift and rotate dial until current time is lined up with stationary pointer.
Put on-off trippers on outer edge of dial.
Timer comes with 2 sets of trippers, and you can order replaceable trippers. Up to 12 sets of trippers can be added to dial for a total of 12 ON and 12 OFF events each 24-hour period.
For 35000 gallon, pump should run at least 6 hours each 24-hour period. During freezing weather, if pipes are above ground, you can remove trippers from dial, set override lever to ON position, and run pump 24-hours to prevent frozen pipes.
Jul 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Apr 30, 2010 | Hardware & Accessories
Hardware & Accessories Logo
22 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
