Question about Philips Health & Beauty
Razor qc5530 works for a couple of seconds then makes a high pitched squeaking sound and stops
SOURCE: High pitched squeaking sound
THIS PROBLEM IS CAUSED BY THE LINE LINEARITY COIL VIBRATING AT LINE FREQUENCY [15.625KHZ] WHICH IS AUDIABLE TO THE HUMAN EAR AS A SQUEEL . THE CURE IS TO DEPOSIT HOT GLUE AROUND ALL COILS SITUATED AROUND THE LINE OUTPUT TRANSFORMER
Posted on Apr 23, 2007
  • 25 Answers
SOURCE: kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Posted on Mar 26, 2008
SOURCE: Washing machine squeak
Same squeak on spin -LW8203 shortly before that she ran an off balance load and now wonders why it squeaks..
Posted on Jan 13, 2009
  • 50 Answers
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Posted on Jan 25, 2009
SOURCE: 2003 Lancer ES High pitch squeal and constant squeak
Shortly after replacing the serpentine belt in my lancer, the same thing happened. It is NOT the timing belt. Belts squeal when they slip. If your timing belt slipped it would cause your car to run funny.
have somebody check the belt for wear (or do it yourself), replace if necessary. If it doesn't need replacement, just tighten it.
If you have the 4cyl engine that I have, the tightening is kind of a pain in the ****. Not a great design by mitsubishi. There's a pulley near the front right corner of the engine in front of the alternator. the belt should be running around this pulley GROOVE SIDE OUT. This is the tension pulley.
To tighten:
1) Lightly loosen the bolt in the center of the pulley (slightly loosen, DO NOT REMOVE).
2) Under that pulley there's another bolt. You can see that the bolt goes through a piece of metal
attached to the back of the pulley. Figure out which way you need to turn the bolt to move the
pulley toward the front of the car. (i don't remember if it's right hand thread, or left hand) This
puts extra tension on the belt. You probably don't need much. Over tensioning the belt can
cause pulley bearing failure. If you haven't done this work before, ask someone for
help
. It's better to tighten a little bit, a few times rather than overtighten once.
3) Don't forget to ReTighten the bolt in the center of the pulley.
If there's lots of cracks and pieces missing on the ribs or grooves of the belt you should replace it first.
Happy repairing,
Cliff
Posted on Mar 09, 2009
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
Squeaking and grinding noise when I apply the brakes
Try replacing or resurfacing your rotors and brake hardware. Using brake pads similar to the oem will also help stop any problems.
Dec 15, 2013 | 2005 Pontiac Montana SV6
I have a 97 RAV4 which runs well but is making noise - most often when sitting at a stop - whne moving, or if shifted to neural it goes away??
Depends on the noise you're getting, but that sounds like it might be a belt issue. They make a whiny, high pitched sound like a loud squeak especially at low rpm's.
Mar 22, 2011 | 1997 Toyota RAV4
Front shocks have a high pitch squeak.
try putting some wd40 on the fork legs then pump them up and down a couple of times then wipe them clean as it may be just a little dirt is causing the squeek and the wd will solve it.
Apr 05, 2009 | 2005 Honda VT 1100 C2 Shadow Sabre
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
High Pitched Noise on TV
THIS NOISE IS NORMAL. IS THE DEGAUSING COIL
Sep 16, 2007 | Televison & Video
Mar 06, 2007 | Beko 324250WN 28" TV
Health & Beauty Logo
74 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
