Question about Mtd Garden Tiller (Mtd)
Clean carburetor 21a-332b729 - Mtd Garden Tiller (Mtd)
2 cycle tecumseh missing and white smoke
Try adjusting the carburetor to a richer mixture.
Dec 14, 2013 | Yard Machines Tecumseh 148cc Front Tine...
21A-121R900 Won't stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ~~
Feb 14, 2012 | Yard Machines Garden
Gas is leaking around top edge of the carburetor bowl. Is the float defective and causing overflow? Or something as simple as the gasket that seals the rim? Happens when I push the primer button.
Sounds like it would be the gasket seals or its just where its got to much gas in the carburetor. It shouldn't be a problem though as long as it doesn't leak while its running. My gokart does it sometimes. Its not that big of a problem.
Feb 10, 2011 | Yard Machines Tecumseh 148cc Front Tine...
Ifound a Tecumseh Yard Machine Front Tine Tiller. It has a 5.50 HP. The tiller seems to choke out every time i crank it up. Can Someone tell mewhere the fuel filter is located???? i have replaced the air...
It sounds as if you still have Carburetor problems.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 05, 2010 | Yard Machines Tecumseh 148cc Front Tine...
2 stroke won't run not getting fuel
Clean the carb and make sure your fuel lines are in good condition.
Jul 18, 2010 | Yard Machines Tecumseh 148cc Front Tine...
I have a Bolens 6.0 OHV tiller M# 21A-332C163 and S# 1C283K40098. It will start on first pull but only run 2 or 3 mintues then quites. You then have to choke it to restart it then again it will only run...
Has it sat with gas in it ? if so carburetor needs cleaned,The other thing could be water in gas look in tank for something that looks like a bubble floating in bottom of tank if you see one its water you remove tank clean out then if carburetor has bowl you must remove carburetor bowl clean out water.
May 04, 2009 | Garden
We have a mtd yard machine roto tiller model 21A-340-06295208
i need a part list for a tiller model 21a
Mar 28, 2009 | Mtd Garden
HELP WITH A HUSKEE TILLER #21A-340-131
The pdf manual can be found at mtdproducts.com. You need to know your model and serial number to access the download. Really not that good a manual.
Mar 23, 2009 | Mtd 21a 643b066 Bronco Rear Tine Tiller
Maxon GMRS-21a
I Just had Batteries Plus rebuild mine with 600mah cells $ 23 each.
Apr 18, 2007 | Maxon Gmrs Two-way Radio...
Mtd Garden Tiller (Mtd) Logo
63 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
