Question about Sharp XR-10X Multimedia Projector
Does not turn on
MY Sharp XR-10X Multimedia Projector was working fine. Now, it does not start up. The fan is not heard either. It has an indicator lit that always turned on when I turned on the device. Now, nothing appears. Dead. No sounds, no lights, nothing. Should I replace the lamp? I took it out and inspected it, shows no burnout signs. Thanks, J.POVEDA Eagle Mountain,UT mpovedam@yahoo.com
  • howeywood Aug 14, 2008
    same issue...I wonder if this is like a pc power supply issue? Can the internal power supply be bad? I have replaced many of those...is there a trick to this fix?
  • Anonymous May 08, 2009
    checked thermal sw . checked fuse . no fain or indicator l.e.d.s
The unit has an internal timer , this has happened to me several times  , i changed bulbs thinking that was the problem , when the bulb timer reaches 2000 hrs or the if you change bulbs and dont reset it the machine will not respond , check your manual and reset the timer
Posted on Sep 17, 2008
    Problem Solver:
  • 5 Answers
Check if the thermal fuse has triped you will have to open the covers.
If you dont want to open the machine then take it to the nearist agent to check.
Posted on Oct 10, 2007
Problem with Sharp XR-10X The power light blinks red
According to the manual, a red blinking light indicates that the lamp cover is open. Try reseating the lamp and making sure everything closes up right. If the light is still blinking, it is most likely a problem with the projector itself and you may need to find out about getting it serviced.
Jun 27, 2011 | Sharp XR-10X Multimedia Projector
Sharp Projector XR-10X/XR-10S
did you chk the fan is working fine?
Jun 10, 2008 | Sharp XR-10X Multimedia Projector
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Jan 24, 2011 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector. Makes a loud whirring noise when trying to turn on. Bulb starts to turn on then doesn't. It's not the fans because I opened up the projector, disconnected the fans and it still...
the colorwheel motor bearings are starting to go. you'll need to replace the colorwheel. you can get the part from a sharp service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 14, 2010 | Sharp XR-10X Multimedia Projector
New bulb in now wont work - no power - wont turn on to reset lamp
first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
May 30, 2009 | Sharp XR-10X Multimedia Projector
XR-10x bulb timer has timed out. How do I reset the projector?
you need to reset the lamp timer see http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
Apr 07, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X projector, but missing the projector bulb.
if you plug it in and turn it on, you should at least hear fans running, then it'll shut down because there is no lamp. that's about it.
Apr 01, 2009 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Bulb works once then nothing
this is something which sharp didnt foresee!!!!!!!!!!
sharp has two identical models
sharp xr10x & the newer model xr10xl.both the lamps look alike , however both have a different rating & reverse connector!!
i.e both cannot be interchanged!however if u have the old xr10x & if u try to fit the new bulb which is lower in wattage, it will explode in 20 mins
if you have bought a used projector , then u wont know if someone has interchanged the ballast!!
as this model was discontinued 2 years back!!!!
so confirm the model , it is mentioned under sharp name or at the bottom
good luck
Feb 05, 2009 | Sharp XR-10X Multimedia Projector
Sharp xr 10x
You will need to open it up and flip this little breaker switch. It has gotten to hot and tripped itself. Dust it out while you are in there.
Apr 26, 2008 | Sharp XR-10X Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
803 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
