Question about Clothing Accessories
Stitch finger thread loops around the stitch finger are not forming stitches
MakikiChris
  • 84 Answers
SOURCE: stitch and looper problems
Hi softy...please regain your patience and optimism and I'll do my best to help you correct the issues that are plaguing your serger. It is obvious that you are skilled in your craft and operation of your serger, so I have very little doubt that we have a minute issue that's causing your headaches, so I'd like to begin with the very basics, and as we communicate through our posts we can advance until we resolve your issue. Your confidence tells me that you do not have a threading error, and as you have experienced in the past, thread that lays down while leaving the presser foot commonly indicates improper or no tension on the blades. I have a feeling that you have color coded "marks" on your tension dial's for standard settings per fabric/weight. So let's turn all of your tension dials to maximum. Ensure that your presser foot lever is in the full up position, and lay your thread between the tension discs, of a single tension dial that you want to begin with. After visually verifying that your thread is thoroughly between discs, lower your presser foot, grasp either ends of your thread, and "floss" the tension. Do you feel appropriate resistance being applied on the thread? If yes, repeat the same steps until you have cycled all 4 tensioners. If you did not, or do not feel appropriate tension on any or all of your discs, then the following arm, located in the head, immediately above your presser foot lever has become lodged, and is not releasing. Using lightweight sewing machine oil, apply 1 drop at a time on the following arm, and using your fingers, work at it until it becomes free. If you have determined that you do not have any tension issues...on the serger...not your mind hehe...then open the blade cover. Turn the serger 90 degrees so that you are looking at it from the head facing you. Examine the trueness of your blades, meaning, do any blades look bent either towards the serger or away from the serger? If yes, I'm sure you know what you need to do. However, if they do appear to be true, then get a piece of toilet tissue, and separate it so that it becomes single ply. Place the single ply of tissue on any finger, ensuring that it is smooth and taut, and gently press against your blades and rub them back and forth using slow even strokes. If you felt any resistance, stuttering or tearing of the tissue, repeat again with a new tissue to verify what you had felt. If you did discover any verified flaw using this method..again....you know what you need to do. Please update your post after you have completed these first steps regardless of resolution or not, so that other's with similar issues can gain the information of your experience, and perhaps not have to endure post-tag-you're-it-and-wrong and correct their issues on their own. I will monitor your post, and should we need to advance our troubleshooting, I will update you within 1 day of your follow-up post.....good luck my friend.
Posted on Aug 03, 2007
SewExpress
  • 41 Answers
SOURCE: Stitches not forming!
Good Morning,
A few things to try:
  1. Loosen the needle screw, make sure the needle is fully up in the needle hole and re-tighten the screw. Vibration can sometimes cause the needle to slip...and the needle not fully inserted can cause this problem.
  2. Make sure the bobbin is turning the proper direction. If your machine has a standard bobbin case that comes out of the machine, turn the case so the bobbin is facing towards you. Pull the thread tail and make sure the bobbin turns clockwise. If it's turning counter-clockwise, flip it over and try your machine again. If your machine has a drop-in bobbin, double-check your particular machine instructions to make sure it's going the right direction (clockwise or counterclockwise depending on the machine).
  3. Make sure you have tension on the upper thread. Do this by lowering the presser foot (make sure the thread tail is NOT under the foot) and give the thread a tug. You should feel tension on the thread. If not, the thread isn't fully down in the upper tension disks. You should be able to give it a further tug to pull it down into the disks. No tension on the upper thread can cause the stitches to not form.
  4. If none of the above seems to help, you'll need to get your dealer involved (provided you purchased your machine from a sewing machine dealer). They can determine if it's just something happening during threading or if the machine is out of timing. They are there to help you before AND after the sale and should be willing to take care of whatever is happening.
  5. If you did NOT purchase your machine from a dealer, and the store you purchased from does not have a sewing machine technician, we would suggest that you return/exchange it for a new machine and see if the new machine has the same problem (most department/big box stores that carry machines have a very liberal return policy since they do not have personnel dedicated to sewing machines).
  6. If the new/replacement machine has the same issue, we would suggest you return it (no sense frustrating yourself) and perhaps find a local sewing machine dealer to purchase a machine from. Authorized sewing machine dealers are geared towards providing machines and service (before and after sale) and are worth the extra $ for the peace of mind and knowledge that you'll have someone local to call on for help.
Best of luck with your machine - we hope it's something minor and you're up and sewing soon! Don't hesitate to reply to this post if we can offer further help, ideas or suggestions.
Happy sewing,
Kim & Linnette
www.sewingexpressions.com
Posted on Jul 23, 2008
bibleman01
  • 334 Answers
SOURCE: CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Posted on Jan 18, 2009
  • 46 Answers
SOURCE: My Evolve serger is skipping stitches while using
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Posted on Nov 27, 2009
Testimonial: "Thanks I am going to try this as soon as I can, but right now occupied with a job with my industrial machine. My only issue may be with the needle."
HansPP
  • 2510 Answers
SOURCE: Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Posted on Feb 24, 2011
HELP! I have a brother 1034d the thread is stacking up on the little fingers on the needle plate
I have the same problem. The serger is making the chain, but it's not moving off the stitch finger! I have to pull it while im operating it (with force) and when i put fabric, it bunches up like crazy and i just broke a needle... Any clue anyone?? Here is a picture... https://goo.gl/fhqq15
Apr 23, 2017 | Brother Sewing Machines
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
How do I create a rolled hem with this machine. I see the stitch width knob, but do I need to remove one of the threads for this?
Making a rolled hem on any overlocker is achieved in the following way:
use right hand needle only and top and bottom loopers. Turn stitch length down so threads are closed up (on mine this is 0.5). Your stitch length dial will be one on the right hand side near the flywheel usually. Loosen off the the top looper tension and tighten up the bottom looper tension (these are the right and 2nd right tension dials on front of the machine). On my Bernette I leave the needle at the usual 5, 2 on the top looper and 6.5 to 7 on the bottom looper thread. Move cutting blade position to the right so that you are trimming the fabric quite a bit wider than your stitch, this makes the fabric "roll" underneath inside the stitching to form the rolled edge or hem.
There is also another step that needs to happen where you change or remove a little stitch finger that sits in the pressure foot or just under it. On the Bernettes, you flick a lever to move this stitch finger back towards the operator so it is out of the stitch forming area. On some machines, it is a case of changing the little stitch finger which is screwed onto the pressure foot with a screwdriver.
I really don't know with your Necchi which it is but have a good look at the pressure foot, and around the blade cutting area and see if you can see a lever or check out the accessory bag and see if there is another stitch finger in there, it would be smaller than the one on the foot now. In effect, this finger sits out and the threads wrap around it to form your normal overlock but for rolled hem you want a much smaller finger in place to make a very little seam.
The other variable which makes a very neat job is to use a thread called "wooly Overlock" in the upper looper only. This thread when pulled under tension is tight looking but when you let it go, it fluffs out. So when seaming on a rolled hem it fills out the stitching and covers the edge of the fabric fully giving a smooth look. You can do it without but wooly thread makes a great job and you'll see it on all Ready to Wear seams usually for this reason.
If I am going to roll hem a fine sheer woven fabric like organza or chiffon I will change the needle to make sure it is nice and sharp and also ensure it is a regular point, not a ball point (I seam lots of knits so have ball points in most of the time on mine) Usually a size 80 is fine.
I hope this gets you going with your overlocker, I usually test stitch quite a bit with the stitch length at the normal 2.5 setting and adjust the looper tensions until I've got the stitch looking good, then turn it down to the very close 0.5, just to not waste a ton of thread.
Sep 09, 2011 | Necchi 6002 Sewing Machine
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
How can I use this machine as a MERROW machine ?
For best results, use Maxi-Lock cone thread.
Remove the left needle.
Slide the stitch forming finger towards you, away from where the stitch forms.
Set the stitch length to around 1.
Set the needle tension 4 or 5.
Set the upper looper tension at 4.
Set the lower looper tension at 7.
Adjust the stitch width, if needed.
Jan 24, 2010 | Juki MO-644D Mechanical Sewing Machine
Loops cross over on both sides - wavy pattern develops
Several things may be causing this.
First, make sure that the wire rack is DIRECTLY above the cones of thread (it may be backward). The thread must come straight up from the cone as it pulls off. Not coming straight up will cause a wavy stitch because of the thread dragging on one side of the cone.
Make sure that the threads are fully pulled into the tensioners, not riding on top of the discs.
Inspect the needle plate and ensure that the stitch forming pins and or fingers are intact.
Aug 18, 2009 | Juki MO-644D Mechanical Sewing Machine
When appliqueing in stitch 11 the thread kees looping...
I believe stitch 11 is a zig zag so you are probably decreasing the length to get a satin stitch. You will get a better satin stitch if you select it directly. I think that it is about 29. The machine forms the satin stitch differently than the zig zag and it should look better. If you still get loops on top, you may need to have a qualified technician check the needle to hook clearance. If this distance is too great, the machine skips stitches and you will form loops. Several other adjustments may be needed to get a perfect stitch and a qualified Husqvarna technician should be able to take care of this problem for you.
Nov 23, 2008 | Husqvarna Viking 1
Clothing Accessories Logo
613 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
