Question about Clothing Accessories
Thread loops not wrapping around stitch finger
Trying to serge on my serger machine and thread loops are not wrapping around stitch finger. This prevents me from sewing on my serger
MakikiChris
  • 84 Answers
SOURCE: stitch and looper problems
Hi softy...please regain your patience and optimism and I'll do my best to help you correct the issues that are plaguing your serger. It is obvious that you are skilled in your craft and operation of your serger, so I have very little doubt that we have a minute issue that's causing your headaches, so I'd like to begin with the very basics, and as we communicate through our posts we can advance until we resolve your issue. Your confidence tells me that you do not have a threading error, and as you have experienced in the past, thread that lays down while leaving the presser foot commonly indicates improper or no tension on the blades. I have a feeling that you have color coded "marks" on your tension dial's for standard settings per fabric/weight. So let's turn all of your tension dials to maximum. Ensure that your presser foot lever is in the full up position, and lay your thread between the tension discs, of a single tension dial that you want to begin with. After visually verifying that your thread is thoroughly between discs, lower your presser foot, grasp either ends of your thread, and "floss" the tension. Do you feel appropriate resistance being applied on the thread? If yes, repeat the same steps until you have cycled all 4 tensioners. If you did not, or do not feel appropriate tension on any or all of your discs, then the following arm, located in the head, immediately above your presser foot lever has become lodged, and is not releasing. Using lightweight sewing machine oil, apply 1 drop at a time on the following arm, and using your fingers, work at it until it becomes free. If you have determined that you do not have any tension issues...on the serger...not your mind hehe...then open the blade cover. Turn the serger 90 degrees so that you are looking at it from the head facing you. Examine the trueness of your blades, meaning, do any blades look bent either towards the serger or away from the serger? If yes, I'm sure you know what you need to do. However, if they do appear to be true, then get a piece of toilet tissue, and separate it so that it becomes single ply. Place the single ply of tissue on any finger, ensuring that it is smooth and taut, and gently press against your blades and rub them back and forth using slow even strokes. If you felt any resistance, stuttering or tearing of the tissue, repeat again with a new tissue to verify what you had felt. If you did discover any verified flaw using this method..again....you know what you need to do. Please update your post after you have completed these first steps regardless of resolution or not, so that other's with similar issues can gain the information of your experience, and perhaps not have to endure post-tag-you're-it-and-wrong and correct their issues on their own. I will monitor your post, and should we need to advance our troubleshooting, I will update you within 1 day of your follow-up post.....good luck my friend.
Posted on Aug 03, 2007
  • 12 Answers
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
Posted on Jan 19, 2008
  • 24 Answers
SOURCE: serger/sewing machine
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit www.stevessewandvac.com you can contact them and have a bobbin case sent to you.
Posted on Aug 13, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
HELP! I have a brother 1034d the thread is stacking up on the little fingers on the needle plate
I have the same problem. The serger is making the chain, but it's not moving off the stitch finger! I have to pull it while im operating it (with force) and when i put fabric, it bunches up like crazy and i just broke a needle... Any clue anyone?? Here is a picture... https://goo.gl/fhqq15
Apr 23, 2017 | Brother Sewing Machines
Singer 14T967dc serger runs but does not stitch
Hello Laura
Make sure that the lower looper thread is in front of and over the upper looper thread when threading the serger; when threading for overlocking.
Please let me know how this worked out for you
Happy serging
Feb 24, 2017 | Singer Sewing Machines
Why won't my sl370 work?
Hello Mary.
By the question, it looks like the lower looper is making loops? If so, check that you are using the correct needles for your serger and that the needle or needles is/are inserted correctly:
- needles must be all the way up into the needle shaft
- needles must face with the flat side to the back and the groove to the front
- use at least needle size 12/80, not smaller
Check these few items, if the loops are still not forming:
- re-thread the serger from the start, keeping in mind to thread in the proper sequence (upper looper, lower looper, needles)
- make sure that the lower looper thread lays on top of the upper looper thread and is passed to the back of the serger and then under the presser foot when threading
- make sure that the thread are securely engaged IN the tension assembly
- make sure that the serger is set for 3-thread or 4-thread overlock (i.e. that the upper looper converter is not engaged)
- check all tension setting
- stitch length should be around 2.5 - 3.5
Let me know how it goes.
Happy serging!
May 02, 2015 | Sewing Machines
Needle Broke/Not Serging Properly
I haven't tried this to make sure, but my best guess (5 months late...) is that you are serging with three threads and that when you replaced the broken needle, you mounted the needle on the left mount. If you are serging with three threads the needle needs to be on the right.
The fourth thread goes through the needle on the left and provides what looks like a straight stitch. The lower looper catches the fourth thread underneath the fabric, but the upper looper does not reach it on the top side. If you use the left needle, but not the right one, I imagine you would only get a straight stitch.
Another guess is that you replaced the broken needle with a standard sized sewing machine needle. The 5280E uses a shorter needle. (DC x 1F). If the needle is too long, it may not rise high enough to loop with the upper looper properly. It probably still catches the lower looper and leaves you with a straight stitch.
I hope you solved your problem a long time ago. If not, I hope this helps.
Jun 10, 2010 | Baby Lock Miter Bit
Changed thread on serge pro SW 432. Now no chain or stitch.
Sergers can be tricky to thread.
Remove the thread.
Raise the antenna to it's highest position.
Open the tensions - setting zero.
Lift the presser foot.
Open the door on the serger and turn the handwheel until the upper looper is at it's highest point.
There should be a threading guide on the front of the machine or on the inside of the door.
Follow the threading sequence as this greatly affects the stitching.
Mar 13, 2010 | Simplicity Serge Pro SW432 Mechanical...
Where can I get parts for my 1034D Brother sergers? I have 4 of them and just broke my last ..... I don't know what it is called, but you pop it in and the thread goes around it as it serges where all the...
I don't know if you still need this information but you're looking for the stitch finger. If you contact Ron at a1sewingmachine.com he can get you the part.
Jun 25, 2008 | Brother 925D Serger
Clothing Accessories Logo
616 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
